Question about Singer Sewing Machines
We have a Singer 328. Need to know how to thread the machine and the bobbin.
  • 340 Answers
You can download a feee manual for the 328 Style-O-Matic from the Singer site.
http://www.singerco.com/accessories/manuals.html
Just type in 328 and click on search.
On the next page click on free download!
The manual will tell you how to corretcly thread the machine and bobbin.
Hope this helps!
Posted on Nov 13, 2010
3 Suggested Answers
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
marigold1m
  • 3 Answers
SOURCE: singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Posted on Nov 28, 2011
How to wind bobbin on model 4411
Do you mean the Singer 4411 Heavy Duty sewing machine? If so,
first place the spool on the spool pin with an appropriate sized spool holder, if you are starting the project. Snap the thread into the thread guide to the left of the of the spool pin. Wrap the thread clockwise around the bobbin winder tension discs (slightly to the left and forward of the thread guide). Bring thread towards the bobbin spindle. Thread the bobbin (put the thread through the hole in the bobbin). Place the bobbin on the spindle with the hole up. Move the bobbin spindle to the right. Hold onto the thread above the bobbin and step on the foot control pedal. When the bobbin finishes winding the thread, cut the thread at the top of the bobbin and the incoming thread from the spool. Move the bobbin spindle to the left and remove the bobbin. If you have already threaded the machine for sewing, you will need to remove it from the various guides and tension discs that are used in sewing. Then after winding the bobbin, re-thread the top thread.
The directions to wind the bobbin are in the manual on page 12 (page 19 of the PDF). You can find many Singer manuals at the Singer support page: https://www.singer.com/support . The 4411 support page is https://www.singer.com/search/support?lp=support&title=4411 . The current link to the manual is https://www.singer.com/sites/default/files/product_manual/SINGER%204411%20Heavy%20Duty%20Sewing%20Machine.pdf .
I hope this helps.
Apr 30, 2018 | Sewing Machines
I'm trying to load my bobbin on my singer 628 and the bobbin doesn't wind. Any ideas?
Anon, Found links to help with bobbin does not wind, make sure to read the articles in the forums, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://ca.answers.yahoo.com/question/index?qid=20070630202938AAGRwx2
Singer 628 Touch and Sew sewing machine manual smm043 Machines name begins...
Thread Singer 628 Touch and Sew Questions
Apr 05, 2016 | Singer Sewing Machines
Singer 328 is not stiching
if upper thread correct, check bobbin is wound and inserted correctly. Pulling bobbin thread, the bobbin should turn counter clockwise. make sure thread is under bobbin case tension spring. With cover plate open hold needle thread and turn hand wheel towards you to see if hook picks up needle thread and passes it around bobbin case. if not check hook timing
Jan 05, 2014 | Sewing Machines
My Simple Singer sewing machine will not thread the bobbin thread. For some reason it will not pick up the bobbin thread from the bottom of the machine, does anyone know how to fix this problem?
Your needle may be in backwards, flat side should face rear of the machine or you bobbin is unwinding in the wrong direction, refer to your manual and dvd. Call Singer at 1-800-4singer if problem persists. Good luck
May 30, 2010 | Singer 3116 Simple
Singer 301a sewing machine does not sew for more than 2 secs...top thread just knots into a huge ball on bottom of fabric...everything is threaded correctly and all tension set well...next step is trash...
Recheck the top thread and bobbin tension for equal balance of thread when sewing. The knotting of thread problem is usually because the tensions are too tight or too loose and/or thread may not be properly threaded. Another reason is when the bobbin thread is wind imbalanced it will cause the thread to knot-up when sewing. This problem is notorious when the bobbin is winded within the bobbin case on some machines. The bobbin thread need to be wind smoothly in the bobbin to avoid this problem.
Jan 24, 2010 | Singer Sewing Machines
How to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Oct 31, 2009 | Singer 3116 Simple
Sewing Machines Logo
626 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
