Question about Sony STR-DA2000ES Receiver
How to hook up external equalizer to Sony STR-DA 2000 ES. Equalizer is a Denon
    President:
  • 1,285 Answers
You need a empty in/out tape slot (jacks in back of Sony, if tape deck is connected you can use "Y" connectors) connect jacks to EQ tape in & out.... (press EQ button Bypass)
Posted on Nov 13, 2010
How can i hook-up a 901 series vi equalizer to a str-de897?
I own 901's(since new) with the active equalizer powered with a non-Sony surround sound receiver.
Basically, you use the MD/Tape in/out jacks to route the signal to the Bose active equalizer. Switch the Tape Monitor switch if no sound is heard.
Here are some references.
https://docs.sony.com/release/STRDE897.pdf http://products.bose.com/pdf/customer_service/owners/901_guide.pdf
Connect equalizer cables (4 total) to the MD/TAPE section of your receiver. OUT from the receiver to the equalizer IN and Out from the equalizer to IN on the receiver.
One issue with the equalizer running through the MD/Tape jacks is that it may affect any other speakers hooked up to your system.
Mar 15, 2016 | Audio Players & Recorders
I Bought a Sony STR-DH130 2-Channel Hi-Fi Receiver and a AudioSource EQ 200 Graphic Equalizer. I connected them and the equalizer does not make a difference nor does it change the sound, can someone
Well i have a equalizer, some times and just(studio gear) the output from my mixer connected to my equalizer and that output to the monitors., It might be a wrong connection orrrr have you put the equalizer on the receiver input signal, that signal has to be the right impedance and your receiver will propably make the signal linair, so that,s useless
Oct 05, 2014 | Audio Players & Recorders
Using an equalizer with a Sony STR-DE 475
I think I must have missed something. Where does the EQ get hooked up to on the Sony STRDE 475? Thanks, Nicolas
I’m happy to help further over the phone at https://www.6ya.com/expert/nicolas_4f0c0a1a713e87a8
Nov 22, 2012 | Audio Players & Recorders
Can I hook up a fisher (EQ-961) to a sony
Yes, see the other request you posted:
http://www.fixya.com/PostComment.aspx?thid=4196867&prdid=0&ctgid=109
Feb 23, 2010 | Audio Players & Recorders
PROBLEM CONNECTION SONY STR-DH800 TO BOSE 901 PASSIVE EQUALIZER
on my sony STR-DH800 only center speaker is heard the side speakers is very very low
Feb 18, 2010 | Bose 901 EQ1915 Home Equalizer
Protect flashing
es posible que un canal se ha dañado por lo que primero daño el fusible con la sobrecarga y posteriormente se daño el canal. es necesario se revisen las polarizaciones de los transistores para determinar el canal dañado,es seguro que el daño se encuentra en uno de los frontales.
Mar 21, 2009 | Sony STR-DE345 Receiver
Equalizer hookup
record out from receiver to line in in equalizer and line out from equalizer to playback in receiver-------but you have to check the result by yourself and watch if it is better than befor or not,
Aug 17, 2008 | Audio Players & Recorders
Equalizer connections
Usually you hook your equalizer between the pre out and main in RCA jacks and then open the connection between the pre and main with a switch. If your unit doesn't have pre out/ main in jacks then I have seen it done by putting your equalizer between the tape in and tape out jacks and then select that tape function on your front panel. The tape out goes to eq. in and the eq. out goes to tape in. Good luck.
Jul 25, 2008 | Sony STR-DE485 Receiver
Hooking up a Equalizer
take audio out from equalizer and put in-aux in or line in-or cd in your receiver.
May 30, 2008 | Audio Players & Recorders
Sony STR-DA2000ES Receiver Logo
379 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
