Question about Lands Phones
How to replace microsd card - Lands Phones
    President:
  • 1,285 Answers
Open back off phone, take battery out replace card
Posted on Nov 13, 2010
How do I change the SD card
Removing the microSD Card
To safely remove the microSD card from your device, you first need to unmount it.
WARNING: On the Android OS 2.3, you can download applications from Android Market and store them
on a microSD card as well as on the device. Due to this feature, skipping the unmount procedure can cause an error because information between the microSD card and the device is not accorded properly. In the worst case, the microSD card can be corrupted or damaged.
1. Press > > Settings>Storage>Unmount SD card.
Confirm your selection by tapping
OK.Now you can safely remove the microSD card.
2.Remove the back cover using the fingertip cutout at the bottom of the cover.
3. Gently press the microSD card in to release it and carefully pull it out of the slot.
Inserting the microSD Card
1. Remove the back cover using the fingertip cutout at the bottom of the cover.
2. Position the microSD card with the label side facing up and slide it into place until it is fully inserted
and locked in place.
Note
Be sure to
use only recommended microSD cards (up to 32GB). Using non-recommended microSD cards could cause data
loss and damage your device
Oct 19, 2014 | LG Optimus Slider
How to repair samsung gt-s5230 which doesn't read memory card
1. Turn off the phone. When inserting or removing a microSD card with your Samsung Rogue, it is advisable to turn off the phone. Hold down the power button and turn off the Rogue before proceeding.
2. Remove and rotate the microSD card cover out of the way. The cover is located on the right side of the phone (when viewing the screen) toward the bottom.
3. Insert the microSD card into the phone. It is critical to ensure that the "microSD" logo on the card is facing up (same side as screen). Press in the card into the slot until you feel it lock into replace.
4. Replace the card cover to keep dirt and debris out of the device.
5. Reverse the directions to remove the microSD card from the Samsung Rogue. Note that after removing the card cover, you will need to press in on the microSD card to get it to eject from the phone.
Aug 18, 2012 | Samsung GT-S5230 Unlocked Phone with...
Microsd card won't read
You need to use a microSD card, not a microSDHC card. microSD cards max out at 2GB, anything larger is a microSDHC.
The 1390t works with microSD cards. Your 8GB card is actually a microSDHC card. While it fits into the slot, it will not work in older devices.
Feb 09, 2012 | Garmin nuvi 1390T Car GPS Receiver
Memory card unlocker
Micro SD (secure data) cards store information such as Word, image and video files.
Kingston microSD cards are used in many settings, such as schools, businesses and government offices, to protect data.
Some Kingston microSD cards are locked for added protection.
In the locked position, you cannot add or delete data from a microSD card.
You will need to unlock your Kingston microSD card in order to save data on it or delete data from it.
Remove the Kingston microSD card from whatever device it is kept in, whether it's a storage case, a digital camera or a GPS.
Find the small plastic switch on your Kingston microSD card.
If you are looking at the microSD card with the arrow pointing away from you, the switch will be on the right side of the card.
Flip the switch on the card to the unlocked position.
This will enable you to store and remove files on your Kingston microSD card.
http://www.kingston.com/flash/securedigital.asp
Jan 24, 2012 | Kingston 1 GB microSD Card with USB 20...
How can i download songs to my cellular memory card?
Hi welcome to Fixya.com. Please follow the Instructions. Instructions
  1. Insert the microSD memory card inside the microSD memory card USB adapter by removing the cover to the USB adapter and slipping the memory card inside it before replacing the cover.
  2. Plug the microSD memory card USB adapter into your computer's USB port.
  3. Locate the music files that you wish to add to your cell phone and drag and drop the files to the USB drive to move them to your microSD memory card.
  4. Remove the USB adapter from the computer and remove the microSD memory card from the USB adapter.
  5. Open the microSD memory card slot located on the side of your cell phone and press the microSD memory card within the slot until it clicks into place.
  6. Go the "Menu" on your phone and click on "Settings and Tools."
  7. Click on "Memory" and then "Card Memory."
  8. Click on "My Music" and then click on "Options" and then "Move."
  9. Check all the music files that you wish to add to your cell phone and then click "OK." Click "Yes" when prompted to confirm that you want to move the files to your cell phone.
Hope this solves your problem. Please feel free to ask questions on Fixya . Have a nice day. Bye
Mar 12, 2011 | Cell Phones
Add music directly from mac?
If your Mac system has a MicroSD reader, you can add music directly from MAC to the MicroSD Card. You can also insert the MicroSD card into USB compatible phone connect the phone to your MAC and Load your Music to your MicroSD card.
Jun 01, 2010 | PNY 2GB microSD Memory Card
Sandisk 16gb microsd formatting incorrectly
Hi unfortuanley you have been sold a fake card
http://memory-cards-blog.blogspot.com/2009/12/dane-elec-8-gb-compactflash-memory-card.html
Please can i ask that you leave ffedback and vote if this has been useful
Feb 09, 2010 | SanDisk 4GB microSD High Capacity Memory...
Where do i find the micro sd on the nokia 6300
Insert a microSD card
Use only compatible microSD cards approved by Nokia for use with this device. Nokia
uses approved industry standards for memory cards, but some brands may not be fully
compatible with this device. Incompatible cards may damage the card and the device
and corrupt data stored on the card.
1. Remove the back cover of the device.
2. Insert the card into the microSD card slot with the contact
surface facing down, and press it until it locks into place.
3. Close the back cover of the device.
Remove the microSD card
Important: Do not remove the memory card in the middle of an operation when
the card is being accessed. Removing the card in the middle of an operation may damage
the memory card as well as the device, and data stored on the card may be corrupted.
You can remove or replace the microSD card during phone operation without switching
the device off.
1. Make sure that no application is currently accessing the microSD memory card.
2. Remove the back cover of the device.
3. Press the microSD card slightly in to release the lock.
4. Remove the microSD card from the slot.
Nov 28, 2009 | Samsung SGH-D900 Cellular Phone
Sandisk microsd 1gb help
Try doing a complete formatting again.
If that does not work, delete partition and try doing formatting with a tool like the one below.
If the software below does not fix the problem, then replace the card.
Sd Card Partition Software Downloads
Partition recovery software
Free download corrupt hard disk partition data repair software
Jul 15, 2009 | SanDisk 1GB microSD Memory Card
Memory card cant be read My 4gb SanDisk microSD memory doesn't read on my computer. I bought it today at Radio Shack.
Are you using a card reader? If yes, you need to isolate the problem. Please follow the steps below:
1. Try connecting your memory card reader into different USB port of the computer.
2. Try using different card reader to see if there's a problem with the card or with the reader.
3. Connect it into different computer.
4. Remove and reinsert the MicroSD in the card reader and make sure that the card is properly seated.
5. If the card reader and the computer are working but still unable to detect the MicroSD, try to reformat the card.
6. If same problem persist, return it to the store and have it replaced.
Have a great day!
May 26, 2009 | SanDisk 2GB microSD Memory Card
Lands Phones Logo
11 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
