Question about Canon PowerShot SD800 IS / IXUS 850 IS Digital Camera
Batteries die quickly possibly a short - Canon PowerShot SD800 IS / IXUS 850 IS Digital Camera
  • 1,606 Answers
The battery is probably just bad. There is enough energy in these batterys that if there is a short you will definitely see it spark or smoke or even catch fire.
If you use the batterys till they are drained before charging, or if they are a few years old then the batteries are not going to be able to hold that much of a charge anymore. The camera might only start then shut off or take one or two pictures and be dead. That is typical of old batteries needing replacement. If you charge your batteries then take them and the camera to a camera shop and ask if they would check. they should be able ot put a battery into the camera or try your batteries in another camera so you can see what is wrong.
Posted on Nov 13, 2010
How to solve the shorting battery problem when I use PPT button?
What make and model of camera are you having this problem with ?
Aug 21, 2016 | Cameras
Dsc60 battery drains quickly
First of all, you need to use alkaline batteries with you camera, if you use mercury ones they wont last long.
Mar 14, 2008 | Sony Cyber-Shot DSC-S60 Digital Camera
Tip
Properly recharge the battery of a laptop
<span><span>The</span> <span>best use</span> <span>of a</span> <span>battery,</span> <span>regardless of</span> <span>its use</span> <span>(</span><span>PC</span><span>, car</span><span>,</span> <span>rechargeable lamp</span><span>)</span> <span>is</span> <span>still</span> <span>work</span> <span>to do</span> <span>in</span> <span>charges</span> <span>and</span> <span>discharges,</span> <span>otherwise</span> <span>it</span> <span>gets used</span> <span>(</span><span>it</span> <span>keeps the</span> <span>memory</span><span>)</span> <span>load</span> <span>short</span> <span>and</span> <span>even</span> <span>totally</span> <span>d&eacute;cherg&eacute;e</span><span>,</span> <span>most</span> <span>will not resume</span> <span>its</span> <span>initial capacity</span><span>.</span><br /><span>A</span> <span>laptop</span> <span>is</span> <span>made</span> <span>to go</span> <span>in nature</span> <span>and</span> <span>therefore</span> <span>to work</span> <span>regularly</span> <span>on</span> <span>drums</span><span>.</span> <span>A</span> <span>PC</span> <span>that</span> <span>remains</span> <span>permanently</span> <span>in the office</span> <span>sector</span> <span>will see</span> <span>its</span> <span>battery</span> <span>quickly</span> <span>died</span><span>.</span></span> <span><span>The</span> <span>best solution</span> <span>is</span> <span>to</span> <span>unplug</span> <span>the</span> <span>power cord</span> <span>as</span> <span>often</span> <span>as possible when</span> <span>the</span> <span>battery</span> <span>is</span> <span>fully</span> <span>charged</span> <span>and allowed to</span> <span>drain</span> <span>up to 30</span><span>%</span> <span>capacity</span><span>.</span></span> <img src="nidalkom01_10.jpg" />
on Jan 08, 2011 | Computers & Internet
Quickly loses charge
if its more than a year old scooter thenu have to change the pack of batteries
to check batteries short the both terminals of battery and check the level of sparking
note just a touch of wire from negative to possivte when its fully charged and discharged
Mar 19, 2013 | UPG 12V 10Ah Currie eZip 400, E-400, E400...
Zune white 30 gig. Im having problems with the charging. the battery life is too short and it dies quick. can you please let me know what's the problem?
Hi rasshatta357,
If the battery is fully charged and get low quickly after an operation, this is an indication that the battery itself is dying. You have to replaced it with new one to back in normal operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 21, 2011 | Microsoft Zune JS8-00001 Digital Media...
My ipod classic 5th generation freezes up every time I use it and the battery dies quickly
If the i pod freezes and the battery dies quickly then i pod seems to short the main board seems to be short please do not try to use it anymore because this will hamper the i pod permanently instead of that take it to any local service center for repairing.
Feb 20, 2010 | Audio Players & Recorders
Charging batteries
at a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity it says it fully charged but will die quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential resulting in short battery life
Dec 21, 2008 | Golden Technologies Compass Electric...
Brand new battery and alternator but the battery still goes dead over night.
Possible short in electrical system....Something is discharging this battery. Have you recently installed a sound system? That where my short was.
Dec 20, 2008 | 2000 Suzuki Swift
Electrical loss of battery charging
sounds like you have shorting to ground, check the ignition switch , or melted wires, bad connections,something is causing a short when ignition is forward, could be a radio or any other electrical hook up ,tests with a volt meter will need to be done to check for continuity when there should not be and other
test will need to be done to start to eliminate possible causes
Dec 10, 2008 | 1996 Honda Accord
Hello , I have a 2006 chevy silverado. engine turns but wont start, battery dies quick if playing radio for a short time could it be the battery
there are two possible solutions, one its the battery which everyone accuses when there is no start, two the alternator could be not charging the battery the way it should. I hope that helps.
Nov 25, 2008 | 2006 Chevrolet Silverado 1500 2WD
Canon PowerShot  SD800 IS / IXUS 850 IS Digital Camera Logo
57 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
