Question about Husqvarna Garden
Drive belt on yth20k46 husqvarna lawn tractor is wearing out every year . the tractor will barely move
4 Suggested Answers
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
gisvc
  • 40 Answers
SOURCE: drive belt slips on lawn tractor, cannot see an adjustment.
hi,
i would check with the owners manual to see if it shows an adjustment for the belt drive. most mowers today are equipped with a self adjusting arm witha pulley tensioner with a spring attatched to it. as the belt stretches the tensioner spring pulls against the arm causing it to apply tension to the belt thus tightening it. it sounds as if your belt is stretched beyond the limits of the tensioner. at least every new season it would be a good idea to inspect the belt tensioner for room or space of free play. that is to check to see if it will move opposite the pulley allowing the belt to tighten. if there is not enough sufficient room then i suggest replacement of the drive belt.
Posted on Mar 29, 2009
  • 61 Answers
SOURCE: Roper 16 hp Lawn Tractor: belt replacement
you need to remove the mower deck there you will see the pullys.
Posted on Sep 06, 2009
Husqvarna YTH20K46 lawnmower does not move forward when in drive
Check the drive belt and pulleys. Make sure the belt is tensioned when you release the brake.
Aug 25, 2014 | Husqvarna Garden
Husqvarna YTH20K46 Lawn Tractor Will not Crank due to battery issue
Check the start fuse, under dash and back side of engine.
Jun 02, 2012 | Husqvarna Garden
The drive belt on my husqvarna yth20k46 is off at the pulley above the transmission. How do I get it back on? Do I have to remove the nut at the transmission shaft?
I would remove the nut and pulley. Get belt top of pulley. Start the edge of belt in broove on pully and run it around. You get easyer belt in pulley and install it. May have pull little against spring.
Mar 31, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Hi,was rolling my lawn with a yth2454 husqvarna.i released then pushed on drive pedal and it wont move.i replace the motion belt now it moves but barely.the old belt was stretched.also now there is a...
hay
it sounds like the new belt you fitted neads more tension on it find the tension pully again and get that belt a bit tighter make sure that you can get it tight enough not to slip!!!!
good luck
andrew
May 01, 2011 | Husqvarna 24HP 54" Yard Tractor ()
I have a Husqvarna Lawn Mower YTH1542XP. when it is in gear to move, i have to use my foot to hold the pedal back for it to go. if i don't hold the pedal back, it barely moves. any suggestions are...
It sounds like the transmission drive belt is slipping. When you pull the pedal back you are increasing the tension on the belt. You may also want to make sure the spring that pulls tension on the idler pulley is in tact. Hope this gets you in the right direction.
Feb 23, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Yes I need help on a Husqvarna model #YTH20K46-960450004 this is a 46" riding tractor. I need a drive belt and deck belt. can someone supply me p/n so I can order plz. thx..Eric
My name is Dane and I am going to help you solve your problem.
Drive belt: 532 13 09-69 Deck Belt: 532 40 51-43
Here's a link to your manuals!!!
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=yth20k46&types=O,I
I hope I've helped! Thank you! Dane
Dec 30, 2010 | Husqvarna Garden
Drive belt
Sounds like u think someone has moved a pulley.
If not, u already know that the back of the v-belt, or flat side runs against flat pulley, most of the time just taking up slack.
The belt probably pulls over the top of the pulley with the back side of the belt rolling on it. Your drive and blade pulleys will keep it in line.
Where's the belt tinsion come from? Spring idler or slide adjustment?
Some times it takes some head scratching but u can figure this out.
ballping
Jul 28, 2010 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Drive (motion) belt has come off the rear pulley twice in a month
husqvarna yth20k46
drive belt came off
fix
transmission boltes were not installed
replaced fix problem
Jul 16, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna yth20k46 - When turning transmission does not work
I only had my mower 3 months and that problem started. I was told to change the drive belt, It got worse. Now the transmission will only drive the mower for about 15 min and will come to a complete stop. I have to let it sit about 30 min before the drive will work again. No solution yet but I'm looking at replacing the "sealed" drive assy. I do have a very healthy yard of St Augustine which is tough. I can mow a thinner yard a little longer.n
Apr 06, 2010 | Husqvarna Garden
Garden Logo
322 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
