Question about Insignia NS-LCD19 19 in. LCD TV
Tengo un tv insignia modelo ns-32LCD el mismo enciende pero no tiene imagen muchas gracias Frank.
SOURCE: How to remove the back from Insignia NS-32LCD?
I unscrewed all the screws in the back, detached the tv from the base, and was able to get the back off. I ordered a new power supply board and will install it to see if it fixes the problem with the tv (won't turn on, insignia light alternates between red and blue). I didn't notice any problems with "swollen" capacitors, so if the new power board fixes the problem I'll update this website.
Posted on Jan 28, 2009
navamoises
  • 6 Answers
SOURCE: tengo un reproductor insignia NS-DV2G
Si es una buena pregunta porque el driver de insignia esta configurado para que trabaje mejor con un programa de musica especifico (puede trabajar con WMP pero con algunos bugs) este aparato hecho por una afiliada de Best Buy usa Rhapsody si tienes Windows 98 click aqui para el programa
http://www.insignia-products.com/skins/Skin_1/Topics/Drivers/RhapsodyBestBuy3.exe
Si tienes Windows xp o vista cliquea:
http://insignia-products.com/skins/Skin_1/Topics/Drivers/RhapsodyBestBuy4.exe
Avisame si pudiste resolverlo de esta manera, estamos para servir.
Recuerda dejar buen feedback
Moises
Posted on Feb 06, 2009
ginko
  • 19396 Answers
SOURCE: Insignia NS-32LCD has sound but no picture -
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Jul 18, 2009
  • 1779 Answers
SOURCE: I have an insignia NS-32LCD and it will not turn
Capacitors are probably bulged in the power supply. Need replaced, not expensive.
Posted on Oct 10, 2009
SOURCE: bunas dias , mi problema
Que tal yo tambien tengo el mismo problema con mi tv insignia de 32ยจ , mi problema es que la tv insignia no enciende a pesar de que la fuente genera todos los voltajes, al dar power el led cambia de rojo a azul pero no hace nada, como dije todos los voltajes estan presentes a la salida de la fuente, cambie todos los filtros de la fuente pero nada, gracias por su ayuda.
mi corre es carlitoswwway@hotmail.com
Posted on Dec 27, 2010
NECESITO EL CODIGO DE UN TELEVISOR SANYO CON UN CONTROL REMOTO DE JVC
These are the codes for Sanyo TV: 0049 0097 0110 0004 0268 0012 0108 0180
Aug 19, 2012 | RCA Universal Remote Control
Porq no enciende pantalla del radio mitsubishi lancer 2009
donde va el relay que mencionas amigo? me paso el mismo problema
Jun 07, 2012 | Cars & Trucks
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
Tengo un plasma sanyo 50 pulgadas modelo dp50747m lo que tiene es que: no prende y le cambie los fusibles que estban quemados pero ahora se oye que prende pero no se ve nada solamente se enciende el...
Amigo yo tengo el mismo problema con el mismo plasma..y no encuentro solucion...Tu ya pudiste arreglarala?? Ojala pudieras decirme como lo resolviste o cualquier info al respecto...gracias.
Sep 05, 2010 | Sanyo DP50747 50 in. Plasma TV
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Tengo un tv que tiene la falla en la convergencia de colores
Hola, gracias por visitatar fix ya.
Mira, tienes un fusible abierto, que no te permite entrar a los ajustes.
A un lado del fly back hay tres pastillitas colo cafe ( fusibles), el de enmedio es el que tienes que cambiar (400ma), pero tienes que resoldar toda el area del fly back, por que ahi tienes falsos o loose connections.
Si tienes alguna pregunta, aqui estare.
Gracias.
Jul 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Monitor XVM-R70, NO SE ENCIENDE NI SE PONE EN MARCHA.
Tengo el mismo problema, lo pudiste solucionar.?, gracias
Mar 15, 2009 | Sony XVM-R70 7 in. Car Monitor
TV Konka modelo K2038U. No enciende.
Muchas televisiones tienen reguladores ,si ese regulador no esta dando lo que tiene que dar hay que cambiarlo,tambien puede haber un corto en la linea y eso esta manteniendo bajo el voltaje,hay que chequiar los filtros(capacitadores).Suerte
Sep 06, 2006 | Konka K1369U 13" TV
Insignia NS-LCD19 19 in. LCD TV Logo
111 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
