Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
My son hit the quick focus button to much on my Hitachi monitor srs bbe 57f500 and now the picture is in double vision
  • 1,476 Answers
Dustinis,
While it may be true that your son hit the button on the quick focus, I doubt that he caused the problem. Why was he hitting it in the first place? Probably because the unit was not in focus, I would bet. The better answer would be that you have a problem with the focus on you unit.
It is the convergence circuit which needs reapaired, you need to replace the convergence ICs and your son did not cause the problem. To solve this problem go to my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which will walk you through the precedure of changing the ICs as well as where to get the parts at the best prices.
Thanks for using FixYa and for the excellent rating. Great ratings will keep the experts solving problems.
hardrocko
Posted on Nov 13, 2010
Srs bbe
SRS means SurRound Sound which is simulated to what is called BBE high definition sound enhancement i believe this was got from a car radio device from the word PREMIO it was a toyota premio
its used in tv sets and hi fi audio and car audio systems and NO its not a tv but a monitor, u will need a dvd car audio thats compatible and given they r custom made for premio u will need the exact march to use it.
Jul 14, 2013 | Televison & Video
We cannot get the color to align. It appears like there is a blue or yellow background around words
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 02, 2011 | Hitachi 57F500 57" Rear Projection...
My t.v.focus is like double vision and the color is not right.
convergence failure that tv has 3 CRTs-cathode ray tube- and it has a circuit that keeps each picture projected from the tubes aligned together called convergence. so if you have a picture that has 3 pictures of the same image in red green and blue then it is defintely a convergence failure. the part numbers of the parts causing the failure are STK394-160 and there also can be some burnt resistors in the same circuit.
Jan 06, 2011 | Hitachi 57F500 57" Rear Projection...
When watchin tv there is a blur or double vision
I think that is a convergence error and/or a lens focus issue. A professional repair tech or equivalently experienced person can repair this rather inexpensively.
Dec 26, 2009 | Hitachi 57F500 57" Rear Projection...
The picture is blurred (double vision) and the picture is also bowed. It appears the bulbs are out of focus. Is this fixable?
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 05, 2009 | Sony KP-53HS20 TV
Hitachi Projection TV 57F500A red looks double.
You need to replace both of the convergence IC's and any bad resistors around them that protect them from damaging the power supply.
This repair can usually be done in the home and takes about an hour; I have done hundreds of them and now is a slow time of year for TV shops; look around if you are not able to do this repair; you can buy the chips on Ebay for less than 15 dollars for a pair plus shipping.
This is a very common problem in projection sets.
If this has helped you give me a vote here as I do this for free. If you have questions or need help:
etower.766@netzero.net
Aug 23, 2009 | Hitachi 57F500 57" Rear Projection...
Weird warped lines
Try the Magic Focus option on the menu.
Jan 19, 2009 | Hitachi 57F500 57" Rear Projection...
How to adjust the color on a HITACHI ultra vision HD
you have to hit the menue button, then go th the video section,,may say picture, dee if there is a reset in there, if not, put the color at 55, and make sure the tint is in the middle of red and green, aldo put it on Dynamic
Jan 11, 2009 | Hitachi 57F500 57" Rear Projection...
Hitachi 57f500
You may have a bad convergance chip, a bad CRT( picture tube ), CRT Board ( board pluged into the picture tube),or a bad video chip. Although this is somwhat a common problem on this model of set, I have found many different fixes. Sorry I can't be of more help. Good Luck
Ed
NC Electronic
Mills, Wyoming
Nov 12, 2007 | Hitachi 57F500 57" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
66 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
