Question about Garmin nuvi 255W GPS Receiver
My garmin gps wont start anymore. It shows a picture of a computer on in, but my computer doesn't read it. what do i do?
  • jveriatch Nov 13, 2010
    Its still stuck on that screen. It doesn't let me go anywhere.
  • 421 Answers
Not sure what the other guys have posted but hopefully I may be able to help.
As you know the computer picture usually comes up when the unit is connected to a PC for updates etc. It is possible however for the unit to not realise that it has been disconnected from the PC, sometimes this happens when the batteries run flat during an update. Hence your unit is now stuck in USB mass storage mode.
I am presuming that the unit hasn't been dropped or been in contact with any liquids because obviously that would mean a repair rather than hopefully a fix.
So, lets try the obvious first.
The nuvi 255W will have a reset bottom on the bottom (underneath the serial number sticker), press this in and see if the unit will reboot normally.
If not slide the power button to the on/off position for 8 seconds (hold it there) and then release and turn on, see if it will reboot normally.
Hold your finger on the lower left corner of the screen whilst turning on the unit, see if it boots normally.
Connect the unit to a pc with a different USB cable and see if the updater software picks up the unit when turned on. I would also try this on more than one pc, maybe a laptop. Then see if it boots normally (it is important to connect to a USB port and not a USB hub).
Hope this helps you with your unit. If it does please rate my help, I would appreciate it.
Thanks
Adam
Posted on Nov 13, 2010
  • 12,061 Answers
Try resetting the unit, via the rest button, Please have a look in the manual below, it will show you what to do, and how to fix your unit.
www8.garmin.com/manuals/2675_OwnersManual.pdf
www8.garmin.com/support/
use the support site if the reset doesn't work.
I have lost all my maps on my garmin nuvi 255W-
Do a hard reset on your GPS. Download and install Garmin Express from Garmin. Plug your GPS into your computer. The software will identify your GPS and allow you to download new maps to it.
Mar 19, 2017 | Garmin Nuvi 200 205 250 255 260 W
Garmin shows picture computer
The computer picture shows if the usb cable connects to a computer. If the picture shows when the usb socket is connected to the cigar lighter power supply, it could be that the socket in the Garmin has got damaged. I had a Nuvi 200 like this where the socket had broken away from the circuit board inside, but the repair was difficult, involving micro-soldering!
Nov 01, 2014 | Garmin Nuvi 370 3.5 in. Car GPS Receiver
Geocache list doesn't show on gps
Basecamp is displaying the contents of the gpx file. This means you've correctly imported the gpx file into Basecamp.
A copy of the gpx file needs to be separately saved into the "GARMIN/GPX" folder on your GPS via USB and your computer. (Note: I believe your Oregon has the same file structure as my Garmin Montana).
On startup, your GPS will read the new data and display the caches.
Mar 27, 2013 | Garmin Oregon 450 Handheld GPS Receiver
My garmin shows a computer picture and doesn't switch on anymore!
Connect it with the USB cable to a PC / Mac - does it communicate with Mygarmin.com? If so look for a software update and load it. Make absolutely sure it's connected to external power - so the battery won't die when updating. Then wait for it to restart.
If no connection then hold the power button for more than 20 seconds - this triggers the auto reset.
If that doesn't help - let it sit like this till the battery has been drained. Then try to restart while charging it.
If still the same - let it drain again and while pressing the On button, hold the lower right corner of the screen for at least 20 seconds. This will trigger a master reset - reverting back to factory mode. It will erase all user data.
Jul 04, 2011 | Garmin GPS
GPS garmin nuvi 265w It does start up after
you can update ur gps and it will work again and it wont freeze anymore
Mar 24, 2011 | Garmin Nuvi 265W GPS Receiver
When i plug in my garmin gps it shows a picture of a computer and a wire plugged into it
MY GARMIN NUVI WONT SHOW MAPS AND CHARGE AT THE SAME TIME, WHAT SHOULD I DO
Mar 06, 2011 | Garmin nuvi 200W GPS Receiver
Garmin wont read street names anymore
To activate the voice prompts, go to 1. Tools, 2. Settings, 3. Language, 4. Voice Language Option, 5 Select a Voice Option that includes a persons Name, eg Jack or TTS, Select OK and that should resolve your problem.
Dec 08, 2008 | Garmin nuvi 200W GPS Receiver
My Garmin Etrex wont turn on on batteries but it works fine on external usb power.
I have the same problem. The unit works until I connect it to whatever computer via USB (Mac or PC). The screen blanks out as soon as I plug in the USB cable. I have to disconnect the device and only then I am able to turn it on again. That started after Firmware update from V 2.90 to 3.00 . I am not sure this is causing problem. What about the firmware versions of your devices ? Are they all on the latest ?
However, does anybody know if there is a way to go back to firmware version 2.9 if it is not possible anymore to connect the device to any computer (evtl. through putting data on the microSD card ?).
Thanks,
Martin
Jul 04, 2008 | Garmin eTrex Legend Cx GPS Receiver
Garmin 660 wont operate on power lead
Are you using the Garmin AC adapter or the Garmin car adapter? Using the wrong cable and the Garmin will think that you are trying to connect to a computer. Not all USB cable are alike.
When connected to your computer it thinks that you want to upload or donwload information.
Jan 26, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
304 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
