Insignia lcd ns-ltdvd26 will not power on... Is their a fuse I can replace ?
  • 1,606 Answers
Unfortunately no. While there are fuses you have to take the tv apart to get at them and that probably would not fix what caused the fuse to blow.
From your description the problem will be something in the power supply. This can be simple/cheap or expensive/not worth fixing. You want to check to see if you have any warranty either em or extended store. Then you need to talk to Insignia or the store you bought it from and find out where/who can fix it. You also want to do a bit of window shopping and find out what a replacement tv is worth. When you know that then you can get an estimate for repairs from the repair depot. If the cost gets too high then just buy a new tv. While this type of problem is repairable it isn;t always worth doing. If the shop just replaces boards instead of doing board repairs then the repair could even cost more than the new tv does.
Regardless of brand this is a common problem on tv's., that is if the repair is cost effective to do or if its is cheaper to get a new one. As long as you know the replacement cost its easier to know when to repair or replace.
Posted on Nov 13, 2010
Is there a repair manual for insignia NS-LT-DVD-26?
Service manuals are hard to find now a days, even service parts. Check the link provided to find the main board for your LCD.
Finding the tuner alone might be hard or if you do, it might cost you the same as replacing the entire main board.
Let me know if you need further assistance. Insignia E23546 Main Board For Insignia E15318G NS LTDVD26 09 V260B1 LN1
May 06, 2014 | Insignia Televison & Video
NS-LTDVD26-09 power
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Insignia NS-LTDVD19-09 LCD TV
My insignia model ns-ltdvd26 will cut off on its own. will turn right back on but will only stay on for a few minutes then cuts back off
Power supply board is the cause.The power supply board is shutting down,not giving the right voltage to the tv anymore.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 12, 2010 | Insignia NSLTDVD26 LCD TV
I need a Power Supply For Insignia TV Model NS-LTDVD26 and Part Number DTV2600.PCB How Much
You can order parts for your TV here. Select your exact model for available parts.
Sep 27, 2009 | Insignia NSLTDVD26 LCD TV
Insignia NS-LTDVD26 won't turn on
It is always recommended to ensure that your TV is powered down before connecting or disconnecting cables. Unfortunately, it is likely that your TV requires service for the power issue.
Aug 06, 2009 | Insignia NSLTDVD26 LCD TV
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
POWER CORD
Try calling MCM Electronics as they are the only ones who supply parts for this specific unit.
Feb 24, 2008 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Open Questions:
I'm hoping to get some clarification as to whether the below is correct or whether I have been taken for a ride. My LG was picked up by a repair service because it started displaying horizonal lines with the picture hazily in the background. I undertook some research and learned that in most cases of the boards needed replacing and it wasn't a panel issue (usually panel issues are associated with vertical lines). After having my TV for 5 days the repair service advised that it required a new power board and a small repair required on another board. They repaired the small repair and I was going to purchase a new power board however the TV has been returned to me dead. It now doesn't even turn on. The power/channel/indicator lights at the bottom flash on then switch off automatically. After getting consumer affairs involved, I finally received a call from the sub contractor and aside from a number of different excuses given based on my questioning of each explanation, all were contrary to the initial diagnosis discussed with me in early June. I documented the conversation which I summarise as follows: - he contacted numerous times however I never received any voicemail. I asked why - after "numerous phone calls" he didn't send a txt msg to which he replied that he's not allowed to send messages. - he initially alleged that the power board was repaired and video board needed replacing which I was quoted for. I corrected him advising that I was told and quoted for a new power board ($530) and the video board was to be repaired. He then changed his story agreeing with me and alleged that found and apparently quoted me $445 for a generic power board but I declined....Just to clarify, I never received this 2nd quote which is evidenced within the emails and messages I sent after receiving no response over a number of weeks. - he continued to claim that the TV now has panel problems and is now not repairable. - I recited the discussion the owner had with me which was consistent with the information when he provided me with the original quote of $530. He then altered his story replying that "this is a rare case... The owner doesn't know what he's saying". - When I challenged why I was quoted for a power board when he is now claiming there are panel issues, his response was that a new power board was to test if the panel was cracked!! - I replied saying that the TV was delivered to them with horizontal lines and even after testing should've been returned with horizonal lines however is now dead. - his excuse changed again advising that during testing he short circuited the TV and replacing the power board would continue to short circuit the video board..When I again questioned WHY then was i quoted for a new power board (as per the owners conversation with me) he returned back to stating that it was a rare case! - I told him about the screws missing in the back panel to which he commented that "they" wouldn't have put them back in because "they" assumed I would just dispose of the TV. What I find interesting is that this was his understanding whilst I was led to believe the TV was repaired (pending a new power board). It now makes sense as to why the driver who delivered the TV literally dropped it off and ran advising that he didn't know anything. I never received a service report and asked for it again however am yet to see it. Based on this information, can anybody shed light on what they've done to the TV? Prior to them taking the TV the horizontal lines were consistent with had a faint picture in the background and didn't alter at all. They're claiming that they did nothing and the TV - claiming that the reason why the panel doesn't turn on is because it was kept on while they were testing.
Sep 25, 2017 | LG Televison & Video
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
Electro Med Services...
