Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
The dryer will not heat. The clothes will not dry and I think its the fuse. If it is, where can i find the fuse?
    Problem Solver:
  • 14 Answers
Check element for contenuity
Posted on Dec 19, 2011
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
My dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Jul 28, 2010 | Whirlpool LER4634J Electric Dryer
Dryer doesn't get hot enough to dry clothes
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this I fine then you’ll need to check the thermostat, igniter and coils. Also as its only 3 months old so it is recommended to use the warranty to avoid any further issues. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Samsung 7.3 Cu. Ft. 7-Cycle Gas Dryer -...
The dryer is not drying. The drying temperature
Hello there:
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Jan 19, 2010 | Kenmore 500 6952 Dryer
I have to dry my clothes t 2 or 3 times before they are dry
Off hand I would think that you are not getting either the proper amount of heat (or no heat) or you have plenty of heat and insufficient airflow to release all of the moisture outside.
Both of the above possibilities are connected to airflow. Most dryers when the air ducts are restricted will burn out their thermal fuse, thus you don't have any more heat to dry your cloths.
Check your dryer venting outside when it is running, see if you are getting a healthy amount of air coming out, it should also be a good deal warm if it has been running for a while on high heat.
If it is warm and not much air, stop your dryer immediately so you do not burn out your high temperature limit fuse. Then disconnect the dryer hose from your dryer, start the dryer again (no heat setting) see how much air is coming out. If it is significantly more, you'll need to clean out your dryer venting in the house, if still low, the dryer itself is plugging up and needs to be cleaned from the lint trap to the blower wheel. (90% or more of the time they do not plug up after the blower motor to the back of the dryer.)
Hope this helps
Oct 26, 2009 | Whirlpool Dryers
Dryer end cycly without cloths drying. Doesn't
IF DOESNT HEAT UP ANYTING CHECK THE THERMAL FUSE AND REPLACE IT IF NECESSARY!!!
IF IT DOES HEAT UP A LITTLE IS NOT THE FUSE!! IT COULD BE THE EXHAUST PIPE (DUCT) CHECK THAT IS NOT BLOCKED OR CLOGGED!!!!
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
44 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
