Question about Whirlpool 8531292 WHIRLPOOL 8531292 ELECTRONIC CONTROL BOARD
Whirlpool Dishwasher DU920QWDB3 control board 3375556 has been updated to 8531292..but wiring doesnot match up ...any ideas..?????
My Whirlpool GU2455 dishwasher door stopping latching all of a sudden. I press the Start button. It just blinks and nothing starts up. Seems like the door latch lost its grip and hangs loose when you touch...
the door latch actually has usually 2 microswitches on it that connect to the timing device ie: timer or control board:: if the door is not latching properly then it will not power the control board and the blinking light is a failt code telling you that... it sounds like the door latch is broke and needs replaced... i would order a new latch very easy to replace. you remove the inner door panel of the dishwasher and then will see the door latch mechanism made of plastic of course isint everything these days.... replace it and reconnect the wires ...obviously i would suggest turning your breaker off to dishwasher prior to operating on it....a few good reputable sites to order parts from
www.sears.com
www.repairclinic.com
www.apdepot.com good luck to you
Feb 11, 2011 | Whirlpool GU2455XTS Built-in Dishwasher
I have a whirlpool quiet partner i dishwasher (model DU1055XTSQ2) that has suddenly stopped working. Control panel has partial functionality. All of the buttons on the control panel have a green LED...
The control board has failed.
CLICK HERE to see the parts breakdown.
CLICK HERE to see/order the part
Open the door & remove the 8 or so allen screws. The board is simply plug and play.
Bad design - the vent is right by the board - so its subjected to moisture.
Thanks!
Nov 14, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Whirlpool dishwasher DUC600XTPQ acts like it is dead..nothing happens when I push the buttons, liek the power if off but I checked the breakers, now what? Help!
sounds like control is bad. cut the power, open door remove six screws at top of door the control panel will be loose. suport this remove black cover over control board by releaseing tabs shown by arrows. there is a fuse at lower right corner of board remove the two wires check coninuty if open replace it alongwith control board. hope this helps .haundi24
Nov 17, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher will not start
I have a quiet partner I and it is doing the same thing!
I have only had it for 3 months. It did it once before, then after about a week, I tried it again and it worked fine?
I can't find my warranty anywhere. I bought it at Lowes.
Does anyone have any kind of solution? Looks like it is a common problem.
Mar 11, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher repetes cycles continiously
yes does sound like a "stuck"button within the membrane switch cause constant restarting and/or re-cycling. wire diagram and tech sheet are generally located under the lower acesss panel(unless previous repair ***** returned it). tried looking up the part couldnt find exact model match mine all ended in Q1,Q2, ** Q3, but parts from my models ranged from 110-165
Mar 09, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold dishwasher
did you check the thermal fuse in the console part #675813? its mounted on the control board white fuse w/ 2 wire leads
Jan 26, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher won't start - non responsive
Check the door switches. Both. and the wiring going to them
Jan 23, 2008 | Whirlpool DUL300 XTL Built-in Dishwasher
Whirlpool 8531292 WHIRLPOOL 8531292 ELECTRONIC CONTROL BOARD Logo
111 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
