I have an older computer that i just had rebooted to clean out an since then it has been freezing up on the internet was wondering if maybe a driver didnt get installed properly or something but i feel that its something that we didnt get put back in that causing it please help dameatman
    President:
  • 1,285 Answers
Are you using IE7 or IE8 (this freezes a lot)... try Opera or Firefox... also try to restore system to an earlier date even though you cleaned it up some.....also find out if your model PC is up to its max in memory (ram) maybe you can purchase and add more
Posted on Nov 13, 2010
Lenovo freeze
  • if you have a driver issue then just go the site of your Laptop manufacture. Once there enter the model number OR service tag of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop
  • And if you don't have a driver issue then download RegInOut that cleans your computer of temp files, history and cookies. Its also used to fix any registry errors
Thanks
Jun 03, 2013 | Computers & Internet
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Geforce 8600 GTS recent drivers cause random freezes using vista
Are you sure that it's the driver that's causing it?
I suggest that you run an anti-virus scan. It might have been caused by a virus infection in your computer.
You can also try using RadarSync to scan your computer for driver problems (outdated drivers), then you can google the drivers and install. RadarSync will give recommendations. If you want RadarSync to do all the things for you, then you can buy the license.
I hope this helps!
David
Jan 21, 2013 | Computers & Internet
Cursor freezing
Remove viruses.
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
Gmail suddenly freezes. Everything else works
Maybe you did not download Chrome directly from Google?
Download the free version of Malwarebytes (Anti-Malware) from https://www.malwarebytes.com/ and install it; then run it (takes an hour or more) to see if it can locate and deal with any malware in your computer. Then uninstall Chrome, reboot. Finally go to https://www.google.com/chrome/ and download genuine Chrome again. Install it, run it. Le's hope it works this time!
Mar 13, 2017 | Google Gmail
When I connecting HTC P3470 (USB), after rebooting my internet-connection doesn't work
for vista you need Windows Mobile Device Centre as ActiveSync is not supported by Vista.
May 23, 2009 | HTC P3470 Cellular Phone
Asus A8V-VM SE with geForce 7100 GS crashes on load
Check your SMPS is proper output to system without any fluctatution. 12 and 5 Walts. Keep the multimeter for a while to check it.
RAM may be a culprit for frequent restart.
There is no violation on sharing of memory between system and graphics.
Sep 24, 2008 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Computer freezes continuously ..
It's obvious that your computer faces cooling system failures. if you can manage on your own, i suggest you do the following:
1. detach the cooling fan and its heat sink and check whether there are some dirty that prevent direct contact to the processor.
2.clean the dirty and get the cooling system back to its position. make sure that the sink firmly touches the system processor.
cheers
Jan 16, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
