Question about T-Mobile Dash Smartphone
Tmobile dash isn't turning on - T-Mobile Dash Smartphone
    President:
  • 556 Answers
  1. Verify that the OEM Charger and Battery are being used.
    • Only the AC charger, Car charger, or USB data cable that came with or was created for the device should be used; others can damage the device and/or battery.
  2. Is the device warm?
    • When using the device for prolonged periods of time, such as when you're talking on the phone, charging the battery or browsing the web, the device may become warm. In most cases, this condition is normal and therefore should not be interpreted as a problem with the device.The device has a protection feature that if the device becomes too warm (due to use of GPS while charging, BT while charging, using the device as a wireless modem, etc), the auto protection feature will be triggered and the charging process will be stopped. Once the device cools down, the device will then begin charging again.
  3. Check the USB Port on the device for any bent or misshapen PIN's.
    • If some are found, that is the most likely cause and this is considered physical damage not covered under the Warranty.
  4. Remove the battery and inspect the contacts.
    • Remove any debris/residue found on the device or battery contacts with a soft, dry cloth.
  5. Look closely at the battery contacts on the phone to see if they are bent out of shape.
    • If they are bent, the device will need to be exchanged.
  6. Try charging the device (try different power sources as well as chargers):
    • Plug in USB to device and PC; is the LED indicating that the device is charging?
      • Note: If the device isn't charging while connected via USB to a PC, go to Start>Settings>More>Power>Power Management and make sure that "When device is turned on, do not charge the device when connected to the PC" is set to OFF.
    • Plug in AC Charger to device and outlet; is the LED indicating that the device is charging?
      • LED indicators: Charging is indicated by a solid Amber light on the upper Left side of the face of the device.
        • Note: If the battery is completely dead, the light will be a solid RED for a few seconds while it is charging; once the device has enough power to turn on, the light will turn to Amber.
  7. Try another Power Source.
    • Try a different outlet to rule out that as the issue.
  8. Try another battery in the device.
    • If another battery doesn't work, perform a Hard Reset.
      • If the device powers up after Hard Reset, test the unit for a few days. If issue returns, device can be considered for an exchange.
      • If device shows charging with one (AC Charger or USB) and not the other, issue is with the accessory. Replace accessory.
      • If device will only power up when attached to charger (AC or USB) it is likely the battery needs to be replaced.
Device won't hold a Charge
The life of the battery between charging sessions will vary depending on which features of the unit are being used.
  1. Verify the you are using:
    • OEM AC Charger
    • OEM USB Data Cable
    • OEM Battery
  2. Fully charge the battery using the OEM AC Charger
    • USB and car chargers are trickle chargers meant to get the user through until they can get to their AC Charger.
  3. If the device is not lasting the advertised Talk time, with minimal use, try another OEM battery in the device.
  4. If the battery life still is not meeting the advertised Talk time (with minimal use), the device will need to be repair/replacement.
Device won't Power on
  1. Attempt to charge the device.
    • If the battery is dead, the device will need to charge for a few minutes and then should power on once this happens.
  2. Attempt to power the device on by pressing the Power Button for 3-5 seconds.
    • If the device doesn't power in, perform a Soft Reset using the stylus.
  3. If the device still doesn't power on, perform a Hard Reset.
  4. Try another battery.
  5. If the device still will not power on, it can then be considered for repair/replacement.
Handset Powers off
  1. Make sure that the device is actually powering off and not just going into hibernate mode by pressing the power button once.
    • If the screen comes back on, the device is not powering down.
  2. If possible, check the battery level by going to Start>Settings>More>Power>Power Management.
    • The charge should be no lower than 10%; if it is, charge the device and retest.
  3. Try another battery in the device.
    • If the device stays powered on with a different battery, the issue is with the accessory not the unit.
  4. If the device still powers off with another battery, Hard Reset the device and retest.
    • If the issue remains after the Hard Reset, the device it can then be considered for repair/replacement.
Posted on Nov 13, 2010
Tmobile dash screen is white
Yes it causes probelm in u r display , u need to replace it ,
Apr 22, 2010 | T-Mobile Dash Smartphone
Tmobile dash keeps just turning off
i had the same problum with mine so i just got a new phone
Jun 27, 2009 | T-Mobile Dash Smartphone
My tmobile dash freezes every time i try to start.
Turn the handheld off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send” button is considered as the green phone button.
How to Hard Reset a T-Mobile Dash with operating system: 1. Select Start
2. Select Accessories
3. Clear Storage
4. Type in 1234
5. Select Yes
if this helps please rate the posting..thanks
Mar 02, 2009 | Cell Phones
My phone will not turn on weird stuff !
Turn off phone, remove Media STORAGE card, not the SIM card.  Reboot phone without storage card and it should go to home screen.  Then replace STORAGE card and enjoy! :o)
Feb 18, 2009 | T-Mobile Dash Smartphone
I got a new tmobile dash and today i broke my set up cd
i have a tmobile dash and broke my format cd how can i get the software again
Dec 26, 2008 | T-Mobile Dash Smartphone
My tmobile phone will not turn
try to plug in thew charger. if it indicates that it is charging then you most likely have a broken power switch. that is a common problem with this phone. if youcan get a local cellphone repair tech to service it, contact www.fixphonenow.com they can repair it.
Nov 15, 2008 | T-Mobile Dash Smartphone
Resetting my tmobile dash?
turn off phone, press and hold the 2 top soft buttons under the screen (not the larger ones with the phones on them). Press and release the power button while still holding the other 2. Wait a few seconds, when the screen changes you can release the 2 buttons. After a few minutes it will ask you to push the call button to reset. Make sure you have your contacts on the sim card, because all personal settings are erased.
Aug 28, 2008 | T-Mobile Dash Smartphone
My tmobile dash lcd screen.
im trying it now i will post again if it works thanks
Jun 23, 2008 | HTC S620 Smartphone
T mobile dash
This happen to me more than once, the latest today (may 25 08)at 9pm. Tmobile will tell you how sorry they are and that's about it. I am on my second dash and second battery.
Try to hold both top keys (between call green and hung up red) while you are pressing on the shut off switch for 2 seconds. Whe it comes back to life, everything will have erased but supposedly, the phone will be like new.
I am collecting names and emails of people who are fed up with the Dash and Tmobile. Write to me jeanrenoux@hotmail.com
May 24, 2008 | T-Mobile Dash Smartphone
Won't Boot Up, Alternates between Windows screen and TMobile screen
Master repoot the phone. You will loose all data, but you can recover the phone.
1. PRESS AND HOLD BOTH SOFT KEYS.
2. WHILE HOLDING DOWN SOFT KEYS, PRESS AND RELEASE THE POWER BUTTON, WAIT 3-5 SEC. (PHONE SHOULD POWER ITSELF ON BY DOING THIS)
3. RELEASE THE TWO KEYS SOFT KEYS.
4. WHEN SCREEN ON DASH LOOKS LIKE IT'S IN DOS FORMAT, PRESS SEND (GREEN ANSWER KEY)
May 16, 2008 | T-Mobile Dash Smartphone
T-Mobile Dash Smartphone Logo
87 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
