Samsung syncmaster 305t integrated usb hub isn't recognised after re-booting computer. have to unplug UP cable and reconnect to reconfigure everytime computer is started. pain in the ****.
The reason is your registery, everytime you restart the computer it cleans the registery entry for the usb hub, I will update more in a day or so
Posted on Apr 18, 2009
Samsung Syncmaster 305t Not displaying full resolution with Dual Link DVI cable.
2560 x 1600 at 60 Hz support . if may v sync 75Hz need to check the adjust.
Nov 05, 2015 | Samsung Computers & Internet
Samsung 305t blue pixels
T-con board problem , the Altera chip on the T-con board is having a bad connection to the t-con board or there is some cracked solder , there is only one solution, the Altera chip needs to be reballed beaa576b-373f-400a-be08-cea2c72a8cf5.jpg 25a8ca13-36a4-4a93-bd4e-8a7562a761d6.jpg bc6d274d-e68a-427b-83a3-31f6bc5608a9.jpg SAMSUNG MONITOR 305T REBALLING REPAIR
Aug 19, 2013 | Samsung SyncMaster 305T 30 in. LCD...
I'm running dual Samsung 305T monitors and one of them has been flickering from time to time. It just starts to flash and flicker. Now, it's all green and fuzzy. Still can see everything, but it's got a...
The flickering problem you have is caused by the monitor's t-con board, The Altera chip on the T-con board is having a bad connection because of dead soldering points or cracked soldering joints, the solution for this problem is to have the T-con board Altera chip reballed, its a very advanced repair , only one place will fix it for you and I will add a link for it, you won't easily find a replacement T-con board for this monitor and Samsung is no longer supporting your monitor so that place is your only hope. 7f514c27-5c9c-4e70-b50a-29505054d67b.jpg b5ec5af6-395e-4533-b5ea-9ca10c5ae592.jpg SAMSUNG MONITOR 305T REBALLING REPAIR 728a6cd3-2218-4f75-8f0c-7348e47d15f4.jpg
Aug 02, 2013 | Samsung SyncMaster 305T 30 in. LCD...
Having issues with my samsung syncmaster 305t displaying red green blue and white. can you help me with this?
since no one answered this, I had the same issue, It was pretty basic but when nothing is connected to the screen (the DVI cable is not connected to any device) it loops in red green blue and white. So just connect something to it and it should work. This monitor is not the most practical since it has no menu and just 1 port.
Aug 05, 2011 | Samsung SyncMaster 305T 30 in. LCD...
Jonathan deleted my usb
Several conditions affect how the USB device functions. First, unplugging the USB device least with the prescribed method of shutting resources with the menu buttons provided on computer makes device loose components recognisable at replugin. usually, in such instance the computer takes time to reconfigure the device at reconnection either automatically installing mutated codes or requesting to manually download the fragmented codes. Second, computer that have undergone updates or upgrades prior to establishing the USB devices least recognies the device. Reconnect the device to momentarily reconfigure the new setting attained on computer. Depending on the type of modifications that were made to the computer would either autocompile the USB codes to attain functionality or require manual installation of missing programs. usually the computer has the recommended missing programs only requires unpacking at the system update search buttons. In the sitaution where the computer was modified beyond recognising USB device require to ascertian that compartible ssytems would allow install a program from elswhere or simple acquiring another computer thar recognises the USB device.
Feb 16, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
My samsung monitor 305t can not have a resolutuon more than 1280/800?! Please, help!
You're either using a single link DVI cable (you need a dual link DVI cable for 2560x1600 resolution), or your video card doesn't support dual link DVI (which is required).
Oct 31, 2010 | Samsung SyncMaster 305T 30 in. LCD...
I think I might have fried my Samsung SyncMaster 191T, by plugging/unplugging a dvi cable while the power was on (on both the computer and the monitor). Right now, when I enable the display using the...
Unlikely unless you discharged a large static shock into the connector as you were doing this. I have never seen a monitor or computer video port damaged by connecting the cable while power is on.
Try unplugging the power cable to the monitor for 10min or more and then reconnect and see if it starts to work.
Mar 12, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Usb hub unsafely unplugged from notebook. now
do one thing boot ur vista without usb hub then go to device manager remove your usb drivers of the hub disconnect the hub from computer, restart notebook, then connect the hub back when windows boot let vista to install the driver of that hub, after that connect your devices one by one ok let me know what happen? :-)
Aug 21, 2009 | Belkin (F5U237) 7-Port USB Hub
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
