Question about Fujitsu 24C1 Air Conditioner
Have model ASTB24LDC/AOTS24LDC Inverter Fujitsu split system. As of Thursday 11th Nov, unit stopped working. Won't respond with remote. An electrician came to test it this morning, says there is power to the unit. He cannot fix it due to warranty on the system. With this model is there a manual button that I can try to start it up? Garry
I have same problem like yours to my newlyinstalled Fujitsu multi-split system (the first time use since system installed1 week ago). I rang the electrician whodid the installation; he said it must be the units themselves nothing to dowith electricity. Okay, then I rang Fujitsu and their local service agent. Theysuggested me to switch off C/B for an hour to reset the units. I followed theinstruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired tothe outdoor unit). So I used a multi-meter to test the power terminals of indoorunits (Danger! If you have no idea about this, don't even try! ): it seemed nopower supply even C/B is on. I turned to the isolator which next to the outdoorunit. The isolator was making arcing noise when I switched it on and off. Theindoor units suddenly turned on for few minutes then died again. So I figuredout the problem is that crooked isolator. I called the unhappy electricianto replace the isolator. End story....
I hope my experience will give a littlehelp to you...
Posted on Nov 23, 2010
What is the meaning of timer flashing twice in the indoor unit of fujitsu heatpump astb24ldc?
Need to check that models error codes but for most Fujitsu A/C's, that means a "serial signal reverse error at start up" which means your outdoor controller board is stuffed. Try turning the main power switch off for 5 minutes and then back on. If the error persists, you will need a new controller.
May 06, 2015 | Fujitsu Heating & Cooling
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
ASTA12JEC Fujitsu Air Conditioning unit. Dear sir or madam. My air conditioning unit is no longer responding to remote control but stays on. It used to work fine then one day it stopped responding.
Start by replacing the batteries to your remote control and make sure there is nothing blocking the IR receiver on the unit itself. If that is blocked by something hanging on it or tape over it from something hanging on it previously.
Jan 31, 2015 | Fujitsu Heating & Cooling
We have a chunghop universal remote a/c Q-988e and are trying to locate the code for our fujitsu split system
Check in book let supplied along with your universal universal remote. If not listed, in your remote set and then press , or one by one press, still your unit responds. Where it responds, it's your code. Keep remember.
Jan 03, 2011 | Heating & Cooling
I have a Fujitsu inverter split system,(ASTA18LCC) which the power was removed for a while. Now when you start it up on any mode the red operation light is on briefely, then the green timer light flashers...
To work out what the error code ispress the orange start/stop button on the remote controller so unit operationis stopped.
Then press and hold "energy save" and "zone control" buttonsimultaneously for at least five seconds, the error code will be along thelines of En:nn where the "En:" is the error code and the":nn" indicates the indoor unit address if there are multiple indoorunits connected to the one controller. If the upper vertical bar on the capitalE is missing so it looks maybe like a 2 or something don't worry for somereasons they just do that
Some common error codes are:
E0 Communication error between indoor unit and wired remote control, check ifthere is 12VDC between terminal 1 + 3 at remote control and 8-9VDC pulsatingbetween terminal 2 + 3. If DC volts out of Indoor pcb is below about 11.6VDC itwill cause this error, the problem is normally dry capacitors in the 12 VDCpower supply section. This model has two power supply sections on indoor pcb.
E1 Communication error between indoor unit and outdoor unit,
EF Discharge temperature abnormal
Is it helpful?
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
Flashing lights on system
Maybe the unit is on test run, try to push the test run button of remote control pointing the remote to the unit receiver.6d9792c.jpg
Jan 07, 2008 | Heating & Cooling
Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Dec 01, 2007 | Heating & Cooling
Fujitsu 24C1 Air Conditioner Logo
758 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
