Question about Samsung RS2630WW Side by Side Refrigerator
My samsung is making a constant chirping noise.
3 Suggested Answers
  • 375 Answers
SOURCE: Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Posted on Sep 13, 2007
  • 395 Answers
SOURCE: Samsung PCL542R Chirping noise
the high pitch chirping noise is coming from the power supply. there is a short circuit with the switch mode power supply. check the HOT(horizontal output transistor) first then the power supply for shorts. on the HOT check for short between base to collector, and emitter to collector. base to emitter will show short because it in line with the primary coil of the fly-back transformer.
if you are unfamiliar TV repair have a tech repair this for you.
Posted on Feb 17, 2008
Why is my hampton bay fan making a constant chirping sound even when off
Never heard of a chirping noise in a fan. Did you check the inside of the housing for a bird? That's just a low-end store brand for Home Depot. Take it back!
Feb 10, 2015 | Hampton Bay Dryers
My samsung refrierator is making a chirping noise
It most likely is the fan motor. When the bearing wears out, the fan motor shaft tends to run "off center" every few seconds and it sounds like a "chirp". See if it stops when the door is open and starts after the door switch is held closed for a minute or so.
If it is the motor, find a replacement online.
Jul 13, 2014 | Samsung Refrigerators
CHIRPING SAMSUNG PROJECTION TV
Chirping is set is in shutdown---most likely in High voltage area of set.
Jun 11, 2012 | Samsung Televison & Video
There's a chirping birdlime noise when the car is
Sounds like your serpentine belt is dried out.Replace your belt make sure belt tensioner is ok,or you can make sure that it is your belt by using a old candle or belt dressing that you can purchase from your local parts store.While engine is running VERY carefully touch the candle to the ribbed side of the belt and let the wax rub off onto the belt the squeak or chirp should change or go away.Or just spray the belt dressing on per the directions on the can.
Nov 19, 2009 | 1998 Chevrolet Malibu
Chirping noise at 2000 rpm
An easy way to get a good idea of where the noise is coming from is to use a short peice of wood like a broom handle , hold it to your ear and touch different places around the where the noise seems to come from. If it is in the belt area spray brake clean in small bursts at each pulley noting when the squek quiets or goes away.
Jun 22, 2009 | 2000 Mazda Protege
Laptop locks up and re-starts at toshiba screen /chirping sound.
If you can get to the dos screen try selecting repair and either let windows attempt a repair or restore back to the factory settings.
Mar 13, 2009 | Computers & Internet
There is problem in sound IC. First check it
Feb 17, 2008 | Samsung PCL5415RB 54" Rear Projection...
Sep 13, 2007 | Samsung PCL5415RB 54" Rear Projection...
Samsung RS2630WW Side by Side Refrigerator Logo
318 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
