Question about Syntax SV266M Motherboard
I turn my computer on, and no boot, no no sound, no nothing. I looking inside and I see a red light on the motherboard that I thought should be green. right under it is the label LED1.
  • 1,606 Answers
When you see the red led that is telling you there is a motherboard problem . Really helpful isn't it?
There are only a few things that will stop it from shoing more life that that. One is a bad power supply or bad ram. Those will stop it from showing anything or doing anything. A bad cpu usually shows more of the boot sequences before it stops. If you were seeing any errors or any blue screens just before this happened then it is most likely the ram. Because it isn't showing any post codes or beeps then the problem will be in the #1 module. To do post tests the first 64k or ram or so needs to be good. If you have more than one ram module take them out and put the #2 into the #1 spot. If it works then it is your old #1 ram module.
You should also try reseating your ram and the cables and any connectors. While not common the odd time that will be the cause.
If you cannot see any change after swapping ram then you may have a more serious problem on the board itself. Probably 9 out of 10 times the cause is the ram.
Posted on Nov 13, 2010
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
Alarm is sounding
replace the memory card of your computer.
Feb 27, 2010 | E-Machines eMachines Desktop PC
Black screen on HP Pavilon dv2000. It does have the power from both ac adapter and battery as I can see all the lights on keyboard. I can hear the fan when press power button. Does not make any sound when...
Unplug the computer from the wall, hold the power button in for 1 minute. This will reset somehow the bios and remove any electricity left inside.If still doesnt work take a look to the cpu and heatsink
Jan 18, 2010 | HP Pavilion dv2000 Series Laptop Full...
Won't stay on
May be your motherboard. Uninstall your ram memory units and see what it does. Their under the laptop behind small cover that you need to unscrew. If not very tech savvy, then i suggest taking it to the nearest (and chapest) computer shop for diagnostic.
Sep 09, 2009 | Dell Inspiron 1520 Motherboard
Dimension 3000 won't fully boot with yellow light
Dell gives free tech support forever. If you are out of warranty, you pay the cost of parts; but they will give you the help you need. Just get the "tag number" from the cabinet before you call.
Dec 27, 2008 | Dell Dimension 3000 PC Desktop
HP Proliant ML370 Server: Led shows red light
Your server definetly has issue booting first of all this is a little old server model so first open and blow air from a blower (&not use vaccum cleaner)
since problem could be anything frm a struck cpu fan or anything
then poer donw theM/c and locate the RAM its a smal hardware in green color vertically fitted to the motherboard it will have locks at the both ends press them downwards the RAM will pop out then clean the side that was inside the motherboard with eraser and nothing else(it might damage the RAM) then fix it as it was aligning the notch it should work
If this does not work out then tell me exct LED and sybol near it
Bye for Now
Nov 03, 2008 | HP Compaq ProLiant ML530 Server
No display
It means your system is not booting, check the memory module look for replacement, When you get a ne memory module and fix it and with this it should boot. Good luck
Jun 12, 2008 | EliteGroup PT800CE-A Motherboard
No power
check ur smps and power connector Mother board ok
next power switch for on/off ok check front panel byy
May 17, 2008 | Intel Motherboard
Only turns on but does not boot
check for the cmos battery!! see if it still on 3 volts
Feb 28, 2008 | ASUS P4VP-MX Motherboard
Syntax SV266M Motherboard Logo
242 people viewed this question
Top Syntax Computers & Internet Experts
Roy May
Gbenga
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
