Question about Home
I need to stand 2 poles up on either side of my yard for Christmas I plan to run lights down from the top and I need to support the pole for all of winter it will be about 7-9ft and I will have 16 strands of lights going around it to the ground I may only use one pole if I need space but it still has to stay straight up and not fall any ideas Im not sure what they even call this type of setup I call it a Pole Tree because thats it essentially a pole that looks like a tree ( its the same as used in many light displays with music and they turn sections on and off
  • 565 Answers
A 10 foot stick of 1 1/4" or so of electrical EMT conduit would probably work:
http://www.homedepot.com/Electrical-Electrical-Boxes-Conduit-Fittings-Conduit/h_d1/N-5yc1vZ1xg4Zbohl/R-202068042/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
The conduit is easily driven into the ground using water. Just pour some water on the ground and start working the conduit up and down in the same spot, add more water as needed until the conduit is in the ground 2 or 3 feet.
Purchase one 1 1/4" EMT connector to fit on the top end of the conduit. That connector can be screwed into a 1 1/4" galvanized floor flange from the plumbing dept.
http://www.homedepot.com/Plumbing-Pipes-Fittings-Valves-Galvanized-Pipe-Fittings-Fittings/h_d1/N-5yc1vZ1xg4Zbuue/R-100183709/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Drill the (1/4"dia. or so) 16 holes around the perimeter of the flange for each strand. Maleable iron is easy to drill.
The conduit should be fairly secure by itself but you could use small diameter steel guy wire (14 ga. or so) and some tent stakes for added support. 4 should be enough.
Posted on Nov 14, 2010
How do you set it up
Check your manual, or look for instructions online, but the basic plan is...
1. Lay it out so the door faces where you want it.
2. Stake down the corners, yes- even if it is 'free-standing' you usually want to do this.
3. Figure out where the poles go. They usually go through cloth sleeves, or metal rings, or clips or something. They also go in arcs that may or may not cross at the top. (a manual REALLY helps with this!)
4. Slide a pole in place. if it goes through a sleeve, you usually slide it in first, then stick the ends of the poles on little metal studs at the corners. If it clips on, you usually build the pole, then run it from stud to stud, then clip the tent to the arch you made.
5. Repeat for all poles
6. Pull the rain fly in place, clip on at each pole end and as needed.
7. Pull out and stake other ties as available. This gives you more interior room, more stability and protection in weather, and improves ventilation.
May 30, 2014 | ACADEMY BROADWAY CORP Camping, Backpacking...
I need the written instructions to set up an avid screen gazebo 13x9 model 2086 that I just bought at a yard sale. PLEASE HELP.
How To Assemble Avid Outdoors Model 2086 Screen Gazebo
Start with # 4 poles. There are 4. Attach a #3A to each, and then attach #3 to the other end of the 3A.
These are the 4 legs.
There are 6 #2 and 3 #2A. Attach a #2 to 2A, and then #2 to the other end of the 2A. These 3 are the top ridge pole and the 2 side poles.
I believe there are 4 #1 and 4#1B. Attach a 1 and 1B together. Do this 3 more times. These are the gable poles.
You have 2 connectors that say gable and gable. These are for the top pole and 2 gable poles. You have 4 connectors that say gable and leg. Put the leg poles.....in the "leg" hole, the gable pole in the.....gable hole, and the side pole in the remaining hole. That shoule do it. It's easier to put the top together first, and then get 4 people to raise it onto the leg poles. Yes, the leg poles angle out, not straight down.
Jun 26, 2013 | Garden
Replacing a triple single pole (1980's) with a
DISCLAIMER:Attempting to work on house electrical systems without proper training is DANGEROUS and you stand the risk of dying.
The Cooper 7729w is a three pole single throw switch with a common (connected) hot wire that supplies it. What you had before was two separate single pole single throw switches and one single pole double throw switch that is used as a three way. The short answer is NO that replacement will not work UNLESS you don't want the other switch on the other side of the room to work.
Personally, I think that if you really need to ask this question you need to seek the advice of a professional electrician.
Dec 18, 2012 | Electrical Supplies
Avid outdoor screen gazebo instructions for set up #2086
Start with # 4 poles. There are 4. Attach a #A to each, and then attach #3 to the other end of the 3A. These are the 4 legs.
You have 2 connectors that say gable and gable. These are for the top pole and 2 gable poles. You have 4 connectors that say gable and leg. Put the leg poles.....in the "leg" hole, the gable pole in the.....gable hole, and the side pole in the remaining hole. That shoule do it. It's easier to put the top together first, and then get 4 people to raise it onto the leg poles. Yes, the leg poles angle out, not straight down. How's that?
Sep 17, 2011 | Garden
I lost instructions for my Avid Outdoors screen gazebo model #2086 13'x9'. Any help is appreciated
avid outdoor doesn't offer instructions...can someone please post instructions for some of these...it would really be helpful...its crazy that some of these boxes dont come with instructions?!
Jul 18, 2011 | Garden
Hello. I have a disney princess bed tent that my daughter recieved for christmas. We went to go and set it up and the instructions are missing. Is it possible to get a copy faxed/emailed to me?
I just put one of these up today with no instructions so I am going to share my experience. In my Disney bed tent there were two long sets of poles held together by an elastic string. 1) put these two sets of poles together. Now you should have two long poles. 2) Turn the three way brackets all the same direction on both long poles. 3) Lay out the tent and look in each corner of the tent for a little pocket to insert the end of a long pole...taking the other end insert into pocket, not diagonally, straight across the long way. 4) Do the same with the other side of the tent and long pole. 5) Now take your ten short poles and attach two together making 5 medium sized poles 6) Push these into the brackets along the long pole, kind of has a ladder effect. You are done!! I use mine with a full size blow up bed, the elastic gets stretched but I can set it up easily outside, or in the livingroom. Enjoy Nancy
May 19, 2010 | Toys
Lost the instructions for circo monster play tent...need to set up for kids asap..
2 short poles A 2 longer poles B 1 medium pole C
Slide one assembled A pole through the pole sleeve at base fold and fasten the velcro tab over the end of the inserted pole repeat with other A pole on other side Slide one assebled B pole through the pole sleeve at rafter. (across the body) fold and fasten velcro tab repeat with other pole slide one assembled C pole through the pole sleeve at top (down the middle of the monster) Put plastic mold at the end of the inserted pole into the pole at front
Feb 19, 2010 | Toys
Putting it together
Ok these are tricky, so what you need to do is check your poles and connectors. You should have long poles and assorted connectors.
A bit of mathematics and you'll have it done in no time.
Ok lay out the poles and sort into longs and shorts.
Sort the connectors into 2 pole connectors (straights) and 3 pole connectors (three way)
Now check the angles on the three way connectors, sort them into groups. some should be slightly angled, these are the roof connectors and the others ones are 90 degrees and or more squarish these are the floor corner connectors. There should be 4 floor corner connectors and There will be two connectors that fit onto the end of roof front and back of the tent.
Sort out your poles and work out how many you need for each dimention. Basically your tent is a cube with a triangular prism on the top so you will need enough poles of even length to make the base and top bit of the cube and then even lengths of poles to make the upright sides of your cube. There should also be 4 four way connectors for attaching the roof. the top of you cube is the base of the triangluar prism.
Hope this helps. TIP once you get this together, MARK the conections with NUMBERS EG: 2 / 2 / 2 one number on each bit (the connector and each pole that is attached to it), this way when you pull it apart you can reconnect it much easier later on.
Feb 03, 2010 | Pacific Play Tents Train Station
I'm replacing a single pole light switch with a timer switch and the timer switch comes with a hot (Black) and a Load (Red) as well as the netural (White). My question is how to wire it up. Does the white...
It all depends on how the light on the pole is wired. The switch you have is meant to interrupt the power between the circuit breaker and the light, just like the switch does now. The new switch uses power to run itself, so you need an additional wire. Usually the lights on a pole have the power coming in on top, and a wire coming down for the switch - black and white. Lets say there was no switch - on top of the pole there would be a black wire going to the hot, or center contact on the pole light, and the white wire would go to the ground, or outside of the bulb. If (BIG IF) things are wired like they are supposed to be, there will be a black wire (hot) coming in from the breaker, down the pole, instead of going to the light. The switch you have in place now interrupts the power so you can turn it off/on. Then when you turn the switch on, power goes up the white wire to the hot, or bottom of the bulb. Theoretically, there should be another black wire going back up to power the light once it leaves the switch. People normally use regular wire, which has a black and a white inside a plastic casing. So, bottom line - you need to run a red wire from the light to the new switch, hook the white wire up to the ground. So: power coming in on top goes down pole to new switch to black. Red wire hooks up to pole light where it is now white, goes down pole to red on switch. Old white wire gets unhooked from light on top, and hooked to common (ground) on top.
Aug 31, 2017 | Globe Electric Globe Indoor/Outdoor Lights...
How do u erect a lichfield challenger 5 tent ?
Peg out 2 back pegs of inner tent. Peg out 2 front then side pegs. Place smaller pointed pole through hole at bell end of inner tent from inside, longer pole through hole at front.Fit protective bases to each pole. Top pointed poles with separators. Assemble roof pole, put through loop and over separators. Throw outer tent over from bell end (needs 2 people) then carefully lead towards front til holes in roof match - back hole first. Fit rain hoods front and back. Peg outer tent from bell end first then back corners, front corners then sides. Place porch poles through holes at front of porch, zip door sides down with one person holding poles upright and taut and peg out door. Peg sides all along making sure they do not touch inner tent. Fix guy ropes.
Aug 06, 2009 | Sport & Outdoor - Others
Home Logo
183 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
