Question about Sanyo DP42849 42 in. HDTV
I need a sanyo dp42849 power supply circuit board. Where can I get one? Thanks, Tim
If ordering a power supply board ,make sure that you order the exact matching number board ,requires removing the panel and writing the numbers down from old board ..there are at least 2 boards for the 42849 tv
Posted on Nov 25, 2012
  • 11,361 Answers
  • 1 more comment
  • jerry emmons Dec 01, 2010
    do you fix boards if I mailed it ?
  • Bud Martin
    Bud Martin Dec 01, 2010
    I am sorry, I do not.
The picture on my Sanyo DP42849 goes dark then brightens then goes dark again. You can still see the picture and hear sound.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 26, 2016 | Sanyo Televison & Video
I realized my Sanyo tv post may have been confusing.
There always is the possibility that the replacement power board is defective.
Aug 26, 2017 | Sanyo DP42849 42 in. HDTV
Sanyo DP42849 no picture but has sound
Sounds like an inverter problem. On some of these sets, the inverter and the power supply are on the same board. These boards tend to be quite pricey, $100 + range. I've worked on your particular model with the same problem, and it was a bad inverter/power supply board. I would recommend you get a diagnosis to be sure.
Oct 28, 2012 | Sanyo DP42849 42 in. HDTV
Where is the inverter board located in the sanyo dp42849
Aug 22, 2012 | Sanyo DP42849 42 in. HDTV
Sanyo dp42849 picture is slow
Apr 22, 2017 | Sanyo DP42849 42 in. HDTV
Sanyo dp42849 tv blinks on then off has sound.was working fine?
If sound stays on and doesn't goes off then you need the video logic main board, if the audio goes out, it maybe the power supply
Dec 07, 2010 | Sanyo DP42849 42 in. HDTV
I have a 1 year old sanyo 42" lcd tv, model DP42849, The tv was running perfect till one day watching a movie, the screen went black and audio went all strange, i shut it off and on, and nothing, the power...
You need to find out if the power supply is putting out 24vdc for the backlight inverter board, it can be that the inverter board has short circuits which will cause the 24vdc to go into shutdown to protect itself, you can disconnect the power cables to the inverter board to see if you will get the 24vdc back.
Aug 05, 2010 | Sanyo DP42849 42 in. HDTV
Hello my Sanyo dp42849 42 inch has no picture and no sound. when i turn on the tv a green light in the bottom right hand corner comes on and occasionally flashes off and then back on.
First, you need to know the sub-model of your TV.
It is called "chassis" and is shown on the back of the TV on the label where the model number is shown.
For example it can be "P42849-00" or "P42849-01".
Then search at www.coppelltvrepair.com/search or just go to www.coppelltvrepair.com and enter the link for SANYO DP SERIES to search for that.
Here's an example of a repair service (note it may NOT be the one for your exact model though!):
http://www.coppelltvrepair.com/p/41/sanyo-dp42849-p42849-00-does-not-power-on-repair-service
Hope this helps!
Jul 16, 2010 | Sanyo 42 in. LCD TV
Sanyo DP42849 42 in. HDTV Logo
918 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
