Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
I installed a new garbage disposal. The way I connected electric to it was to just run a pigtail to a near by outlet. I put a switch between the outlet and the disposal. Whenever I try to turn it on it trips the circuit breaker. If I bypass the switch it works fine and doesn't trip the breaker? I've tried a 15 amp and 20 amp switch. Any ideas?
  • erik_lilly Nov 13, 2010
    The switch I used has 2 brass screws (one on each side of the switch). The dark screw and the green screw. I connected the ground to the green screw, both white wires to the dark screw, and then one black wire to each of the brass screws. Does that sound correct?
It sounds like you put in ordinary wall switch.
You use the word 'pigtail' which implies electrical knowledge, so without a photo it's hard to tell where the switch is shorting the circuit.
You need a single-pole switch with 2 screws and a ground screw.
If you use a 3-way switch, your wires are connected to dark screw and one of the brass screw
You have 2 wires running between receptacle and disposal.
The wall switch interrupts one wire. Not both wires.
So one wire from receptacle runs continuously to disposal.
The other wire is cut and one end attaches to a switch screw, the other end of the cut wire attaches on the other switch screw.
The bare ground wire connects to green screw.
Preferably the Hot wire is cut.
Posted on Nov 13, 2010
  • Anonymous Nov 14, 2010
    Your switch has 3 screws and green ground screw? Ground wire goes to green screw.
    White wires are not connected to switch. Whites are twisted together and covered with a wire nut. You have two black wires. Blacks are connected to switch. If switch has dark screw, then 1 black goes to dark screw. Other black goes to brass screw. That should work. And then add a comment if more help is needed.
I have an Ace garbage disposal model 4000 and I just want to know if it is a hard wired or plug in model. It is installed already!
They are rarely hardwired in because it is easier for the electrician to put an outlet under the sink and connect it to a switch than it is to hard wire. If it is hardwired, it would need flexible and moisture resistant conduit. This would be expensive. Disposals don't come with any wiring attached, you have to get the pigtail and wire it to the disposal and then plug it in.
Mar 30, 2017 | Electrical Supplies
How to replace gasket on garbage disposal
First unplug the disposal from the electrical outlet. Do not just shut the switch to the off position.
You will need to drain the water sitting in the trap so place a container under the trap to catch the water.
Loosen the collar on the disposal ( use a small hammer and screwdriver)
Remove the old gasket on the top of the disposal and replace with the new gasket.
Place a little plumber's silicon on the gasket and reinstall the disposal. ( it might be a little difficult due to the new gasket)
Check for leaks and then plug the disposal back into the outlet
Sep 05, 2014 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
801 sinkmaster
Disposal is rusted out, and water is leaking down near electrical connections. Disposal must be replaced
Copy following link for installation tips, and product manuals:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#install
Add a comment May 2013
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 28, 2013 | Electrical Supplies
It does not turn off at the wsitch
When you turn the wall switch can you turn it off to stop it .this will help me diagnose it .
Dec 23, 2012 | Badger 1 All Insinkerator 76039h 1/3 Hp...
When we switch on the garbage disposal, there's no sound at all..dead. Switched power cord to another outlet, plugged it in and automatically the motor turns on but the blades don't move. It doesn't...
If you plug it into the original outlet under the sink and flip the switch, nothing happens? No motor sound? And when you plug it into a different outlet, you can hear the motor, but the blades don't turn?
If this is the situation, I would guess that there's a problem with the insinkerator. Something stuck in it, or it's otherwise jammed. This could have tripped a breaker.
If the breaker failed or the circuit wasn't wired properly, this jammed condition could also have resulted in the wire at the switch or under-sink receptacle burning off of the terminals.
Turn off the circuit at the panel, double check that it's off, and remove the switch and the receptacle to see if the wires are still connected. If they've burned off, do not re-connect them. You should consult a licensed electrician to correct a hazardous situation.
Mar 17, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5 is leaking from the bottom around what seems to be the electrical cord opening. any suggestions
Your disposal is rusted out and needs replacement.
Garbage disposal mechanism cannot be disassembled for repairs.
Here are basic disposal parts:
1) Sink basket that connects to sink and is held with 3 screws from below.
2) Disposal body which connects to sink basket using metal ring.
3) Rubber washer between disposal and sink basket.
4) Dishwasher connects to upper part of disposal with a hose.
5) Electric wire coming from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connects to side of disposal
You might be able to buy time filling hole with epoxy or silicone caulk and let dry for 2 days.
10-year old garbage disposal had a good run.
Disposal will need to be replaced at some point.
When I worked apartment maintenance, we replaced disposal with same size and brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Using hammer and screwdriver, rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, black wire to black and white to white, and push in red reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Lift new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, Use new washer.
Connector ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
Image shows direction for connecting new disposal.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove 3 screws that hold sink basket, remove basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal, or any do-it-yourself project.
Jan 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Making a metal grinding sound when turns on but dont feel any forks or spoons in it
Garbage disposals can get noisy and sound like they're eating spoons instead of banana peel.
You can put vacuum hose in sink opening and see if something is in there.
As long as disposal disk rotates freely, and disposal is not shaking around and causing pipes to leak, then you can use it until it dies.
Otherwise, the bearing is probably rusted, or something is loose. Disposals rust out and eventually freeze, or the motor slows down and overheats, or they rust a hole and water leaks under sink.
I wrote tips for replacing disposals that you can use when disposal gives out.
When I worked apartment maintenance, we replaced disposal with same brand and size disposal.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Attach electric wire to new disposal, and push in reset button.
Attachment ring catches at three points, all three have to connect.
Remove old sink basket and clean sink opening.
For a price, fixya expert speaks with you over phone while you work on disposal.
Jan 08, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My Garbage disposal works and it turns but it sounds as if something is loose in there...it's the Insinkerator 5-81.....Is it possible the cutting blades are loose and if so, how do I fix this?
As long as disposal is not shaking around a lot, and causing pipes to leak, then you can use it until it dies.
Here are basic parts:
2) Disposal which connects to sink basket with metal ring.
3) There is a washer between disposal and sink basket.
4) The dishwasher connects to disposal with a hose.
Jan 04, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My garbage disposal isn't working. it doesn't even make a sound when i hit the switch. i checked the circuit breaker and it's not that...i pushed the reset button underneath and it didn't help, either.
On the bottom of the disposal there is a small red reset switch. Push it in and see if it stays. Turn on switch and see what happens. If it hums or buzzes take a 1/4 inch allen wrench and insert it into opening in the center of the bottom. Turn wrench back and forth while running hot water through disposal to help clear any blockage. Turn on switch on and see if thats helped. Thank you.
Nov 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 1/2 hp in sink erator (garbage disposal) steady stream leaks from the bottom near the reset button. It appears to be coming from a drain outlet (a small hole, dia. approx size of smallest screw ),...
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket.
How to: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Attach electric wire to new disposal.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Remove old sink basket and clean opening.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Apply good amount on washer just before pushing washer in place and attaching nut.
Nov 26, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
146 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
