Question about Bosch Dishwashers
We have a bosch model #SHU9902UC. the dishes frequently have a residue after the complete cycle is done. this is alleviated somewhat if the "power" wash cycleis used, but there is still a residue. any sugggestions? we jsut moved to a new home. the unit is probably 10 yuears old.Thank you. Bruce
Bruce, we have the same unit and had the same problem. Try using a LOT less detergent. The repair tech claims that the manual says to only fill about 25% full. Also, we tried different detergents and found that the Finish (formerly Electrosol) works the best. Another not so great feature of this dishwasher is that it does not have a disposal unit so periodically clean out the drain pump area to remove any large chunks that the kids didn't feel like rinsing off.
- Bruce
Posted on Jun 11, 2011
Were there recalls on any of ghese models
The problem of residual water in front load washers is an on going problem. Some companies had put in a small drain hose in their units to alleviate the problem. Your washer is actually built by Whirlpool. There is no available auxiliary drain for these models. These are the suggested solutions to alleviate for your particular machine.
1. Leave the door open after wash completed. This will help to evaporate the residual water. If in an area where the door cannot be left fully open then place a towel over the top of the door to keep it from closing and that will help by keeping the door open a small amount.
2. To alleviate odor, pour one cup of bleach in the drum... DO NOT PUT ANY CLOTHES IN THE MACHINE! Put the washer through a wash cycle... some models had a clean cycle if your has this then use this cycle. Once this has completed remember to do a white load following this procedure to assure that if there is any bleach residual then it wont cause problems with colors.
3. Dry the door seal after each use... this will eliminate mold from developing on the door seal. If you see mold then use a bathroom cleanser for mold removal to clean the seal... DO NOT USE A SOLUTION OF VINEGAR... THIS COULD DRY OUT THE SEAL CAUSING IT TO CRACK THUS REQUIRING REPLACEMENT.
FYI: The Maytag Company went bankrupt sometime ago, the name Maytag wash purchased by Whirlpool and appears on products to secure the business of faithful Maytag users...
Apr 19, 2014 | Maytag Neptune Washing Machines
Bosch dishwasher dw44zp/16 dishes have soap residue and are not clean
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Apr 02, 2011 | Bosch Dishwashers
Bosch Dishwasher leaves a sandy filmy residue on our glasses. Cascade Dishwasher soap is always used and dishwasher cleaner used about every 5 weeks. Dishwasher is run thru a complete cycle every 2 days. ...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 06, 2011 | Bosch SHX55M02UC Built-in Dishwasher
White residue on dishes, white smears on inside of dishwasher door. Roughness on plates when cycle is done. Have tried all dishwashers soaps. Usually Casade and a rinse worked when dishwasher was new. Have...
heatman101
Jan 29, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Having trouble with Bosch dishwasher (SHE44C06UC) .. stinks when it turns on, also getting soap residue on the dishes .. i checked the drain system/pipe and it's clear. cycle times also seem to be quite...
heatman101
Jul 31, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch model smu50e15 is 6 months old has never dried dishes properly. and now it leaves a gritty residue on dishes. repair technician from bosch hasnt got a clue. has checked everthing and all seems to be...
My wife had the same thing happen she run 1 cup of vinegar through the was cycle without any dishes etc in it. Its worth a try it worked for us. I hope it helps.
Jul 10, 2010 | Bosch Dishwashers
Dishes wont rince clean
Hello Dennis, welcome to Fixya. There are several factors which influence how your Bosch perform's. Saying that brings me to a point I have to ask a few questions. 1) How long have you had the unit...when did you buy it ? 2) do the dishes always appear dry when the cycle completes ? 3) How long does the unit take to complete a "normal" wash cycle ? 4) Do you have adequate hot water going to the unit ? Let me know as much as possible and I should be able to help. I will watch for your response. Macmarkus :)
Jun 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Our bosch shu9902uc dosnt clean the dishes,ive tryed to clean out the drains,blew compressed air thru the drain line,cleaned out the sprayers,still it dosnt clean food off the dishes. water plenty hot and...
make sure you clean the sprayers out real good,if theres debris on the end nozzles they dont spin around too good,also pull out the little service plug that protects debris from getting in the impeller.
i found a little chunk of wood in there! im still not sure how wood ended up in the dishwasher!
Jan 04, 2010 | Bosch SHU9922UC Built-in Dishwasher
Dishes are coming out with white residue after complete cycle. The filter has been cleaned. Repairman indicated that problem may be the motor and quoted $450 to replace. Any other ideas? Thanks
yes, it is your water and not the dishwasher. hard water leaves white residue when dried in a dishwasher. www.dishwasherfilter.com makes a prodcut for this problem. it filters the water entering your dishwasher and will leave your dishes looking crystal clear. it is very affordable(like 70 bucks) and has a money back guarantee. you will love it.
Aug 02, 2009 | Bosch SHU5316UC Dishwasher
Dishwashers Logo
114 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
