Question about Crosley CDE6000 Electric Dryer
Trying to put belt on drier but its to loose what im doing wrong
  • 1,531 Answers
Make sure the belt is around the motor pulley and the idler tension arm.it goes on like a serpintine belt on a car.pull the pulley to one side and then put the belt on the motor pulley and then release the idler pulley it should tighten up your belt.the outside of the belt should run along the inside of the idler pulley.it will almost look like a figure S.
Posted on Nov 13, 2010
I have a Roper drier, Model # EL5030VW0 Recently we put too much into the drier and it stopped tumbling, but there is still heat. We suspect the belt went wrong. How to open the cabinet and examine the...
here is a blow up of that model you might have to copy and paste link hope this helpshttp://www.partselect.ca/ModelFrames.aspx?ModelID=586816&ModelNum=el5030vw0&mfgModelNum=&ManufactureID=3&Selected=6QLYC5ZY&Position=0&mfg=Whirlpool&Type=&Mark=0
Feb 27, 2011 | Roper Dryers
Pressure problems
those seem to be very acceptable numbers you are stating if this is R22 running in summer temps. Im curious what pressures you are striving for?
Jul 02, 2009 | Heating & Cooling
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
How do i fit a drive belt on a hotpoint tumble drier
Hi, To fit the belt to your dryer you will need to remove the top of the appliance by removing the screws at the rear. Pull of the timer/control knob. Look inside the top of the t/dryer behind the control panel you will see little plastic stems which are attached to the facia panel. You need to knock these out to remove the facia. Once this is off then you can remove the the top 3 screws and the bottom 3 screws the front panel will now come off for you to place the belt on the drum and over the motor spindle. Becareful as the t/dryer will be very loose and will twist. it is easier to lay the appilance down on its back to stop everything falling about. Now you can put it back together in the reverse order....
Good luck.............
Jan 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Frigidaire MD# GLER642AS1 Dryer
first check you vent system it must be four inches all the way to the end not a lot of hose behind it just enough to reach the outside vent housing im going to give you the procedure for the belt but consult your owners manuel for proper venting as this will make the drier to hot if not vented prioperly unplug the drier pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and give it a quick snap forward to disengage the retaining clips and the door from the drum remove the door .Lay on the floor reach in and remove the belt from the idler pulley and blower motor pulley .once you get in there see if the drier is full of lint
Mar 13, 2008 | Frigidaire GLER642A Electric Dryer
Crosley CDE6000 Electric Dryer Logo
102 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
