Question about Dual Electronics XHD7714
My dual xhd7714 is getting an error 3 code all the time with a cd and usb drive
CD player displays error code: ER-1
The ER-1 code signifies an unknown error. Try cleaning the player itself, as well as cleaning the individual CD's prior to inserting them.
If that doesn't remedy the issue, ask for further help.
Feb 02, 2014 | Dual Electronics XD1222 Car USB Player
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
Toshiba sattelite A205 s5816 will not boot up
i suggest getting/borrowing usb cd/dvd drive and then reinstalling your OS
Mar 09, 2012 | Computers & Internet
Need instructions on setting clock on dual xhd7714 car stereo
With the unit on, press and hold DISP until the clock begins
to flash, then release. Press TUNE << to adjust the
hours and TUNE >> to adjust the minutes. Press DISP
momentarily to save the selected time.
Mar 01, 2012 | Car Audio & Video
Need manual for blaupunkt model xhd7714
You can download this manual at the link below for free.
http://www.dualav.com/support/manuals/xhd7714.pdf
Thanks for using FixYa
Dec 01, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
I'm running my laptop on win XP and I've got a problem with my CD/DVD-ROM somehow my system doesn't recognize it there for I can't use it, but I really want to upgrade my OS to Vista as originally my...
Here is what I suggest. I would go ahead and upgrade your OS. Windows Vista actually has worse performance than Windows 7/8/10. I recommend installing via USB flash drive. https://www.microsoft.com/en-us/download/windows-usb-dvd-download-tool
If you really can't get your hands on an upgraded OS. Here is a link that might help you to resolve your problem: No CD Rom drive in Device Manager No error reported by XP Windows XP
Otherwise I think it might be a driver issue. If you could supply the product serial I could point you to some proper drivers.
Jun 29, 2017 | LG GSA 4163B DVD±RW Dual Layer Burner
How do i reset my dual electronics XHD7714? why the red ligth is always blinking? please help!!!
The red light is blinking because it is in theft mode, you need to enter your anti-theft code... I have been trying to get mine from dual for a week now, hope you didnt lose it like i did. You need the remote to enter the code by the way.
May 09, 2010 | Dual Electronics XHD7714
I have a Dell E510 that will not boot up. It has power and I get error codes 3 and 4. I have reseated the memory and replaced the memory to new memory and tested them one by one in the first slot. The...
Ok what you might try is get a new hard drive and install windows on there and see what happens. Also if you are able to before you try a new hard drive you should do a system restore and restore it back to the day that windows was installed.
Jun 18, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dual Electronics XHD7714 Logo
214 people viewed this question
Top Dual Electronics Car Audio & Video Experts
xxxxxx xxx
Matthew Spark
Matthew Spark
Are you a Dual Electronics Car Audio and Video Expert? Answer questions, earn points and help others
