Question about Exonic EXD7010 Car Video Player
We just bought a new truck with two Exonic EXD-7010 DVD players installed in them. HOW DO WE USE THEM? We did not recieve the manuals with the truck. Thanks!
Can't get anny power I replaced a blown fuse in the unit and after a short it went out again and fuses are new
It appears that there is a short happening in the power to the unit, not in the unit itself. Check and trace installation for insulation cut or miswiring. Locate the installation guide from manufacturer to make sure the tapping power source is a correct one.
Aug 24, 2015 | Exonic Car Audio & Video
Why wont my exonic touch screen not working?
It could be a number of things. The touch screen could be broken, Has it got a clearfilm cover on it? like you get on cell fone screens,
Aug 05, 2014 | EXD 7095 7 Touch Screen In-Dash Multimedia...
Exonic sound no picture
Your remote has a (music mode) botton press it twice,it may be helpful to you. Or checkout the Av cord
Dec 20, 2012 | Exonic EXD 9010 Car Video Player
The screen is blank all white on my exonic touch screen radio no sound tried the reset button
Hi yolandaalen2 ,
i see you have tried reseting the Exonic EXD4500T Car Video Player and still have the issue. this must be a problem with the LCD screen itself, i would highly suggest for you to take the device to an electronic shop and ask them about your issue so that they can help solve it as nothing much can be done through the internet as this is a physical problem with your Device.
i hope this helps.
Mar 28, 2011 | Exonic EXD4500T Car Video Player
Trying to set up universal remote and need the code.
You can find the universal remote codes here - http://universalremote.manualsonline.com/
Jul 01, 2010 | Exonic EXD 9010 Car Video Player
I just bought a dvd player for this tv and I cant find any inputs. What gives?
check your nearest electronics store and ask for an RF converter, this gadget will recieve the output cables from your new dvd player and convert it to analog RF signal, this will enable you to see normal dvd playback. The unit will come with installation instructions.
Jan 15, 2010 | Daewoo DTQ-19P3FC 19" TV
I bought my vehicle used with the exd7010 and exonic drop down screen already installed. I received no remote or headsets. Only headset jacks I have are behind the center console of my 2004 Chevy Tahoe...
I have the same unit and yes, there are wireless headsets that go with. the unit will also run through your radio,although mine keeps losing the signal and no one seems to have the manual.
Jul 22, 2009 | Exonic EXD7010 Car Video Player
Mistracking on dvd player
Hello!
It turns out there is a problem using hdmi cables with integrated amplifiers Denon dvd players (the 1940 series) - the hdmi cable processes the visual signal before the audio signal. Therefore there is what appears to be a lip syncing problem because there is a short 'time delay' between the visual and audio signals. I would advise anyone to simply use an AV reciever as they incorporate time delay technology so the visual and audio signals are in perfect sync. Luckily, Richer Sounds, where I bought the intergrated amp gave me a full refund, no quibbles or hassle. I would like to add I am unsure if the problem lies with just the Denon 1940 hdmi dvd players and intergrated amps or ALL hdmi players. Also, I was trying to achieve a simple 2 speaker set up with the amp.
The forum on What Hi-Fi document this problem with much better clarity and technical explanation that my understanding of the problem. However, the lesson learned is, if you want any speaker set up with your dvd player, use a dedicated AV reciever.
Best Regards, Graeme Young.
May 17, 2009 | Denon DVD-1940CI DVD Player
Exm 1530 monitor
you need a video controll module to hook to watch tv i know i have one
Mar 08, 2008 | Exonic EXM1530 15.3 in. Car Monitor
Exonic EXD7010 Car Video Player Logo
Top Exonic Car Audio & Video Experts
xxxxxx xxx
Are you an Exonic Car Audio and Video Expert? Answer questions, earn points and help others
