Question about Haier Washing Machines
Near the end of the wash an error 3 code appears on the machine,but if i switch it of and on i can run a rinse cycle without an error.I have a HWM1260K FRONT LOADER it isonly 3 days old.
  • eric bosman
    eric bosman May 11, 2010
    can you tell me your countrie? Haier does not recognize this code. Never mind it must be australia.
    I sent them a repair request and they will contact me
    You can Email them HERE
  • 487 Answers
Hi I received an answer form Haier and this is what they sent me. As soon as you call them or email them they will help you solve this
Please send me the customers phone number.
Regards
Tracey Reinecke
Customer Service
tracey.reinecke@haier.com.au
Tel: 1300 729 948
Fax: 1300 729 961
Posted on Jun 20, 2008
  • theresaradfo
    theresaradfo Apr 17, 2012
    so bottom line is what does error 3 mean i can't find an answer anywhere?
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
Bwa91683x washer. When near the end of wash cycle. Beeps 3 times then wash light flashes, then beeps every 8 seconds. Washer still appears to carry on but doesn't start rinse cycle.
hmmm this could be a problem with the diagnostic computer having issues you may want to have the washer serviced it appears as if some sensors arent working inside the washer
Jan 08, 2017 | Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
I was washing towels on cotton (1) cold water , at the end of cycle during drying a F-02 keep flashing on the control panel. This is a new machine used about 3 months
Hello
F02 Is a suds error code or water is to soapy.You need to use the E A type soap.
Try running the machine on rinse and spin.And then go through a normal cycle with no soap.
Apr 04, 2011 | Ariston Technologies Washing Machines
When my cycle is done my washing machine read sd
Hello, W/D here.
Sd is the error code for suds lock. If suds are detected continuously by the pressure switch during the
drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again. The SD code indicates the possibility of too much detergent being used. Run a rinse and spin cycle to remove detergent residue. Then run a normal cycle without detergent.
Items to check if it is occurring at the end of the cycle would be to check the drain line and waste outlet for plugging or kinks and check the wiring harness connections to the drain pump, pressure switch and CCU (Central Control Unit). It may be necessary to check and clean the drain pump filter.
Best regards, --W/D--
Feb 15, 2011 | Kenmore HE2 Plus Front Load Washer
Suds and then f35 error code shortly afterbstarting any wash cycle.
SUDS error = SUDS LOCK (OVERDOSE OF DETERGENT
DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained
If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
F35 error = ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Dec 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tried to wash a load of clothes and keep getting an error code "sub". The machine will not complete a cycle, won't rinse, etc. What does the error code mean and how can I fix it?
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If “Sud” is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
Possible Causes / Procedure
■ If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
or kinked.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Mar 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
ZANUSSI FJR1454 W WASHING MACHINE E10 ERROR . IT TAKES NEARLY THREE HOURS TO DO A QUICK WASH. IT BLEEPS AT LEAST 4 OR 5 TIMES THROUGHOUT A WASH CYCLE AND THE CYCLE COUNTER DOESNT SEEM TO COUNT DOWN...
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
e10 means that there is a problem with the water supply.
a condenser dryer needs cold water to operate properly. the e10 code will appear if:
1. the water is turned off
2.the water pressure is too low.
3.the solenoid valve is open circuit
4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
http://www.zanussi-electrolux.co.uk/files/unitedkingdom_english/0-999/zanussi%20error%20codes.swf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 10, 2009 | Washing Machines
Washing machine fault
im having the problem now with my daewoo that every time i put a wash on its giving me a H6 message error
Nov 09, 2007 | Washing Machines
Washing Machines Logo
624 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
