Question about Dell E193FP 19" LCD Monitor
Screen comes on then goes blank after 1 or 2 seconds
  • 979 Answers
Hello NDK, use first an alternate monitor, and see if the problem is your DELL. If the alternate monitor works fine on your computer. then your DELL has power supply problems, this can be repaired by replacing the power supply board with a new one or a refurbished board. find one online or try ebay for the board. If you can do the replace thing, you need to disassemble the unit. if you cant, pay for service.
Posted on Nov 13, 2010
jaysicksix6
SOURCE: nec flat screen goes blank after 20 seconds
i got the same prob.supposedly its the cap(capacitor) ,the one for the power suppy near the cord input.im getting my shit fixxed.and i will let you know.
Posted on Nov 02, 2007
SOURCE: screen goes blank after few seconds
My screen goes black after a few seconds and will not come back on unless I turn it off. When I turn it back on it does the same thing. I can not get it to come on at all.
Posted on Nov 14, 2008
GregL
  • 49 Answers
SOURCE: screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Posted on Jan 20, 2009
  • 1684 Answers
SOURCE: Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Jun 19, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Posted on Jul 21, 2009
Thomson flat panel tv has sound but no picture (comes on for about a second then goes blank)
if you can see if the screen lights from behind when the picture apears for a second then the problem is probably the invertor or worse the screen
Jan 06, 2013 | Thomson Televison & Video
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
Screen Goes Blank
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
The screen goes blank after 5 seconds
Make sure you have the correct drivers install for you video card. Also, check to make sure your resolution is not set to high for you video card. To get to resolution; right click on Desktop > click Properties > press Settings Tab, from there you can move the slider to change your screen resolution (try different resolutions until it doesn't shut off anymore).
Let me know.
Jul 09, 2009 | ViewSonic VG900b 19" LCD Monitor
Furuno fcv-667.When powered on good screen comes on for 1-2 seconds, then goes to a solid blue screen
1. Check that you have not altered settings - HUE, that is, background colour.
2. Go to menu - select FACTORY SETTINGS and try that. The unit may go back and rectify.
3. Check depth setting - if greater than depth operating, will show just blank screen.
Hope this might be helpful
Jun 14, 2009 | Boating
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Monitor goes blank less than a second after turning on.
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Dell E193FP 19" LCD Monitor Logo
62 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
