Question about Alpine Car Audio & Video
Purchased an alpine 3011 graphic equalizer that has no wiring diagram...cannot hook it up without knowing what wires do what
You are going to need the DIN plugs for the unit, on the back there are two imput jacks. The left jack is for the imput from your head unit, as far as I know, there is no other way for the EQ to accept imput except for the jack. The right one is for a digital time delay unit (rare). Coming out of the unit there are two output jacks, one is line out front, the other is line out rear. With these, there are also your power, ground, remote power, and speaker out puts. Good luck. I had one of these back in the 80's.
Posted on Jan 01, 2011
  • selava-ek Apr 23, 2011
    oye osea que no sirve para nada?
Alpine 3011 eq wiring diagram
Request the wiring diagram directly from Alpine.
Dec 21, 2017 | Alpine Car Audio & Video
Wiring details for alpine3215
Wiring connection diagram. For Alpine 3215 7-band graphic equalizer with 4-amps. have custom scanned this item for those folks that don't have a need for the full service manual and just need a simple connection diagram. Includes wiring connection diagram and pin-outs of the din as well as output block connectors.
Sep 28, 2016 | Car Audio & Video
I have a 1998 Toyota Camry...Trying to hook up an Alpine...Need to know what wires to connect to the alpine.Car Wires are same with grey spots.....
From what I can tell you cut the wires to your factory wiring harness and that is what you want to hook up to. My advice is to reconnect the factory harness and buy the adapter harness for your car and use that to hook up to the alpine it will save you hours and possibly your sanity. If you want to hook up directly to your car without the adapter you will need to figure out what wires are the power ignition and ground with a multimeter or power light. Easiest way to find ground is to just put in a ground wire with in a foot or so from the deck. Then it's just a guess and check for the correct placement of power. I suggest turning the power placement on the deck to what speaker you want and repeat for all speakers until your finished. Or you can buy a Chiltons or Haynes manual the should have a wiring diagram
Sep 03, 2014 | Car Audio & Video
Need wiring diagram for alpine graphics equalizer
Hi there
Use the 'Google' search engine and type in support.alpine-usa.com/products. You will be able to download a pdf manual on your model.
Apr 13, 2014 | 1993 Ford Probe
Alpine CDA-7965 go ERE=G190 diagram wire
Most radios have universal wires for the most part.Yellow is 12volt constant power,red is switched power(accessory)black is ground.
the 2 gray wires are right front speaker(black stripe is always negitive)
the 2 white are left front
purple is right rear
green is left rear
orange/white is illumination
Dec 20, 2012 | Alpine ERE-G190 Car Equalizer
I have a 300 watt amp, but i just bought 12 gauge wire why wont it allow sound to come from my 12'' sub
There is no reason even if the wire was to small it would still allow ssound.make sure you have good connections.
Nov 08, 2009 | Pyramid 906 300 Watts (peak) 10 Band...
How do i wire an equalizer without any wiring diagrams
how do i hook up my equalizer color code info
Jan 16, 2009 | Car Audio & Video
Alpine MRP-M500
You need to check the Fuse on the Power Wire and check the ground wire to see if has loosened up. Also check Power Wire as well.
Hope you see what you are your looking for! Good Luck!
If you have any more problems let me know.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this answer!
Jan 10, 2009 | Alpine MRP-M500 Car Audio Amplifier
Car Audio & Video Logo
531 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
