How can i connect internet by lan - Computers & Internet
  • 27,725 Answers
First you must have an IP Internet provider which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the net or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts
hope this helps
Posted on Nov 13, 2010
Cant get on the internet
Heelo,
we need more information then this.
What make and model laptop, operating system etc.
How are you wanting to connect (wired or wireless) which make and model modem you have and they type of internet connection (ADSL, cable etc)..
Feb 17, 2011 | Computers & Internet
I have an Acer Aspire 5315 laptop and I can't get on the internet. It shows an internet connection but won't connect. I restored the computer to the factory settings and lost everything. Still can't get...
Open the internet explorer
Click on Tools tab on upper right side corner
Then click on Internet Options
Then click on Connections tab
Then click on LAN Settings
Make sure nothing is checked over there.
Then click OK OK and then try to go online.
Feb 14, 2011 | Acer Aspire 5315 15.4-inch Notebook PC
I am trying to setup a internet connection using yahoo what do i do
Sir,only using yahoo connection it will not provide to setup internet connection.
For internet connection you have to configure all the component which provides you to connect with internet.
These configuration requires LAN card,LAN driver,modem,NIC card,phone and internet service provider to assist the internet to activate the internet.
Apr 12, 2010 | Computers & Internet
Router cannot connect to the internet
I assume you are following my instructions.
Did you connect the LAN cable from the DSL or cable modem to the WAN or Internet port on the wireless router?
To test if the modem is working properly, connect the LAN cable from the modem to the LAN network card on a computer and see if you can access the Internet.
If if doesn't connect to the Internet, contact your ISP and they can check the connection to your modem to determine if it is working properly.
Dec 03, 2009 | Linksys WRH54G Wireless Router
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
Lan problem
You LAN is not connecting to your Internet Service Provider, hence the LAN has a red X and therefore cannot open a WEB page.
Check your LAN cable, make aure it is connected to both the LAN port on the modem and the LAN port on the computer.
The red X on the LAN should disappear when the network connection is re-established.
Also power off your modem for 1/2 min, and power it on again and restart your computer.
Let me know if you have further problems and any error messages.
May 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Cant connect to the internet from my laptop with either wireless or wired. its a hp dv2700 running vista premium
When wired go to Lan Settings which is under Internet Explorer>Tools>Internet Options.>Connections>Lan Settings. Make sure no boxes are checked after clicking Lan Settings.
Jul 15, 2008 | Computers & Internet
Unable to connect via LAN with wireless router NETGEAR WPN824
I recently experienced this on laptop and desktop, using a lynksys wireless. I was able to go into each system to network connections, and tell it to connect. I haven't had a problem since........hope this helps you!
Dec 24, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
