Question about Sony KP-57WS510 57" Rear Projection HDTV
3D look picture in rear projection tv is due to failure of convergence output ICs that will be replaced to fix this problem. If you have no prior experience of electronics stuff repair then local tv repair shop will help you to repair your tv problem. What is an estimate on how much this will cost to repair at a shop??
  • Sony Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
578ba6c.jpgTV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 17, 2011
My Toshiba 53H71 rear projection TV's picture looks like double vision with a heavy tint outline how can I fix this???
Double vision/ picture problem occurs due to failure of convergence output ICs in rear projection tv and it is common problem of projection tvs.
Please replace convergence output ICs in tv to solve the issue, there is convergence repair kit available for $70 on This Site that has required parts/ ICs, instructions about how to replace ICs etc for a handy person.
Hope these info will help.
Thanks.
Jun 11, 2011 | Toshiba 53H71 53 in. Rear Projection...
The picture has double images and looks kind of like it is 3D.
The tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergnece board,must have these parts changes on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Have three different color images (red,blue,green)
It is symptom of convergence output ICs failure, replace convergence output ICs located on D board to fix this problem.
Call local tv repairman to replace defective ICs if you do not have prior experience of electronics stuff repair.
Thanks.
Dec 15, 2010 | Sony KP-51WS500 51" Rear Projection...
Picture looks like a 3-d screen
This kind of problem occurs due to failure of convergence output ICs in Sony KP-51HW40 tv.
Replace convergence output ICs to solve tv problem.
Local tv repairman will do this job if you have no experience of electronics stuff repair.
Thanks.
Nov 12, 2010 | Sony KP-51HW40 51" Rear Projection...
My TV is showing up in 3D what could the problem be.
Oct 05, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Everything looks like its in 3D vision. Im pretty sure somthing isnt alined right so i was wondering what i can do to fix it.
Replace convergence output ICs in your tv to fix this 3D look picture, it happens due to convergence output chips failure.
Local tv repairman will fix it for you if you have no prior experience of part replacement in tv circuit board with proper tools.
Sep 26, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Color is not blending. double vision of picture
This problem occurs due to convergence output ICs failure and replacement of two convergence output ICs will fix tv problem.
If you are handy and can replace chips in circuit board, let me know to provide you more technical info.
Thanks.
Aug 24, 2010 | Sony KP-53HS30 53" Rear Projection...
Projecting double images
When convergence output ICs got failed, tv shows double image or 3D like picture. Replace convergence output ICs in tv to fix the issue. Local tv repair shop will replace it for you.
Jul 07, 2010 | JVC AV-56WP74 56" Rear Projection...
I'm getting an overlapping of two colors on the screen.
It is common problem with rear projection tv and 3D type picture problem occurs due to failure of convergence output ICs, replacement of convergence output ICs will fix the issue and tv will again show correct converge picture as before.
Let me know tv model number written on back of tv if you want to fix tv by yourself as it needs soldering parts in circuit board expertise and if you feel uncomfortable working in tv circuit boards than local tv repairman will do this job for you.
Thanks.
Jun 30, 2010 | Hitachi 61SWX01W 61" Rear Projection...
Sony kP-57ws500 picture is distorted not right
It calls convergence problem due to failure of convergence output ICs.
If you want to repair it at your own, let me know if you have basic electronics knowledge and little experience to guide you more.
Nov 08, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
96 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
