Hello, When i on my lappy,it didnt start directly as usual and it will be suddenly off. And i need to on again and again by using Last Known Good Configuration or start your laptop in normal mode Then my lappy will start to work. After 20-30 minutes - blue screen appear on my lappy and it say Hardware Mulfunction Please contact your hardware vendor for support System Halted My lappy is compac presario CQ20 Any solution for this problem.... Thank you.
  • yadayada
    yadayada Jun 08, 2017
    What is a "lappy"
  • Computers & ... Master
  • 1,830 Answers
Press windows Key third key on bottom left and press R key at the same time. Type last known good configuration in box and hit run. This should clear it or you can set it back to a known last configuration as by date and time you knew it was working properly.
Posted on Jun 08, 2017
  • 5 Answers
SOURCE: presario v4000 will not boot up
hey guys,
i got something that might work but for you guys, i had a similer problem.
what you do is do a full format and load windows xp, pref sp2, then connect your laptop to the internet via an ethernet cable (larger lookking phone cable) and go onto hp's website and select your model and ONLY download the drivers for every piece of hardware that is relivent to you and once you've done that install the drivers you downloaded one by one and restart where applicable.
When restarting go into the bios via the F10 key as the system starts up and change your boot order to 1: cd rom 2: hdd 3: doesn't really matter here onwards.
after installing all your drivers and and configuring your bios restart one final time and everything should be fine. But i have experienced on problem that happens upon start up for me, it won't boot off the hdd. solution - have a windows operating system cd in your drive when booting (only tested with xp and vista discs) it will say press any key to boot from cd, don't press anything and once it goes away it won't boot from the cd and will then continue to boot of th hdd. go figure.
review:
reformat and install xp (vista will work but complicates things with some drivers)
download drivers and install one by one while restarting where applicable
change bios boot order via F10 key to 1:cd rom 2:hdd
if any problems load a windows os disc (xp or vista) and where it says 'press any key to boot from cd' or something like that DO NOT PRESS ANYTHING. afterwards it will boot into windows
good luck all
Posted on Jul 20, 2008
  • 1056 Answers
SOURCE: hardware malfunction
From the error report, it sounds like you have a bad memory chip (RAM).
If it's under warranty, contact Dell for a replacement.
If it is out of warranty, go to a vendor that sells RAM and replace it (such as www.crucial.com)
Posted on Jul 28, 2008
HARDWARE MALFUNCTION CALL YOUR HARDWARE VENDOR FOR SUPPORT NMI : PARITY CHECK / MEMORY PARITY ERROR THE SYSTEM HAS HALTED
Posted on Oct 02, 2008
  • 3940 Answers
SOURCE: Hello! I've got a LG LW40 Express Laptop. Whenever
First, if you can run hard disk drive diagnostics, because many times a windows failure is based on the Hard Drive failing. If the Hard drive checks out, since you cannot access the Windows enviroment, you'll likely be re-installing Windows and loading drivers again. I hope your data is already backed up, otherwise it may be gone
Posted on Sep 05, 2009
SOURCE: hardware malfunction call your hardware vendor for
change ram.... or change PCI devices .... this problem come due to bad hardware..
Posted on Oct 27, 2009
Windows is not loading have black screen with white cursor then goes to acer and fast out again to white cursor
Hello, doing a "last known good configuration" Works most of the time. Here is how to do it:
1. Make sure your computer is powered down.
2. Turn your computer on and immediately start pressing F8 on your keyboard repeatedly until you see a black screen with white writing that gives you a list of boot options.
3. Use the down arrow on your keyboard to select the Last Known Good Configuration (Advanced) option.
4. Press Enter on your keyboard and cross your fingers.
Good Luck!
Mar 31, 2011 | Acer Computers & Internet
I was loading a new game, and all of a sudden the screen went black. I took the disk out, and restarted my laptop, but it will not show anything on the screen. is their a button i can push?
Start your System by pressing F8 during Startup and Select "Last known Good configuration that works"
Your system will work again as usual.
Dec 29, 2009 | Sony Computers & Internet
Reformat
(A) Try interrupting the boot sequence and telling the computer to boot using the last known good configuration. Here's how: 1) Turn the computer on, and press F8 repeatedly until the boot options menu appears (the menu items include "Start Windows Normally," "Use Last Known Good Configuration," etc.). Use the arrow keys to select "Last Known Good Configuration" and press ENTER. The computer should boot correctly.
if it dont this is the procedure given below to format the whole operating sys 1) Put the CD in the CD drive and turn the computer on. 2) As the computer begins to turn on, you should see the message "Press __ to enter setup" (it's usually F1, F2, or F4 - models vary). Press that key.
3) You should then see the Setup screen for the BIOS ("Built-In Operating System") - using the arrows, find the "boot disk priority" settings and select your CD Drive as the first priority.
4) Exit setup, saving changes (usually by pressing F10). The computer should then boot normally using the CD.
Jun 18, 2009 | HP Compaq Presario v3000z Notebook
Wont boot past start up to windows
hiya
when it starts to boot up repeatedly press f8 then u will get a menu, choose last known good configuration.
if this does not work then go into safe mode and uninstall any drivers and reboot to see if that works.
what u may need to do is update your system drivers
rik
Feb 24, 2009 | Intel F301 Original Fan and Heatsink for...
Error message, can't run network diagnositcs, system restore....
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores registry information and driver settings that were in effect the last time the computer started successfully.
To start your computer by using the Last Known Good Configuration feature, follow these steps:
  1. Start your computer.
  2. When you see the "Please select the operating system to start" message, press the F8 key.
  3. When the Windows Advanced Options menu appears, use the ARROW keys to select Last Known Good Configuration (your most recent settings that worked), and then press ENTER.
  4. If you are running other operating systems on your computer, use the ARROW keys to select Microsoft Windows XP, and then press ENTER.
Dec 17, 2008 | Systemax (036052) PC Desktop
Toshiba M115
Hi again and welcome back to FixYa,
Appreciate the direct "Ask Me".
Would initially suggest to clean the memory(/ies). Turn over the laptop, behind one of the panels/lid/cover secured by a screw or two would be the memory modules. Snap them out, use a hard pencil eraser to clean the little gold pins, a dry brush on the memory slots and re-insert the memories back, try again.
Should this be not corrective, it would appear that you have a video driver problem and fails to load correctly. Try booting into "Last known good configuration that worked", otherwise might require re-installing Windows all over again, sorry.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 14, 2008 | Toshiba Satellite A100-S8111TD Notebook
I cant switch on my nec versa s3200 lappy
laptop adapters are very specific and need to be exactly the same as the manufactures so if the one you switched to is not the same voltage and amp and poliarity you gain the chance of causing permanent damage to your lappy.
Sep 23, 2008 | NEC Computers & Internet
Possible Corrupted Hard Drive
is it a lappy or desktop? if its a desktop, you can make your drive a slave in order to recover those files that you want. same goes if its a lappy. however, it would give you a hard time becasue you have to take out the HD fro the lappy unlike the Desktop cpu.
seems like your froze to a point it cant pass over the startup windows loading. it may be that some window files were tampered by an illegal operation by some of your programs.
reformat will do the trick. recover your files by using another cpu of a friend and after that, reformat that drive.
May 31, 2008 | Computers & Internet
My Acer Lappy turns off automatically!
This could be a heat issue. Make sure that nothing ( eg dust) is blocking the air vents.
Jan 11, 2008 | Acer Aspire 5630 Notebook
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
