Question about Epson EMP-TW1000 LCD Projector
My Epson TW1000 projector recently developed a problem whereby it would start to display red vertical lines over the picture. This began occuring infrequently a few months ago on start up but now is permenently there. It occurs when the projector starts up and when there isn't any video source connected. The lines aren't fixed and will change position and intensity dependant on the colors being displayed from whatever source or menu being displayed. I've been through all the display setting and nothing makes any difference. I have clean out the filters and the projector seems to be getting good air flow.
  • 600 Answers
First, try using other cables you are using from the source, for example, if you are using a laptop or PC and you are using VGA cable, try using another one. This also applies to any other cable such as S-video, or the simple Video In RCA cable.
You may also want to check the plugs or the port connector, specially with the VGA or D-Sub on some models, look for obstruction or bent pins. Loose or obstructed or even corroded terminals and ports contribute to such "streaks" or even worse poor image quality.
Another thing to consider, specially if you are using a PC or Laptop, is to check the setting on the OS,(Graphics Properties). Be sure to set it according to, or as stated, or required resolution depth.
Lastly, if the lines you are referring seems to grow, or multiply as the projector heats up.Or, the lines seems to be "rolling" or "moving"- try one of these simple steps;
-- try other cables -- try locating the "SOURCE" away from the projector, put them separated, away from each other -- if you are using HDMI cable try using a new one -- if you have plugged in the projectors power cord "along" with other electronics, in the same SOCKET, or extension, consider re-locating on of them, if possible, let the projector have it on "solo" -- if your projector's Power Plug being a three prong, try plugging it in a three prong socket, or you can buy a 3-to-2 plug adapter
If none of those mentioned steps the following could be a possible fault;
-- LENS or the projector -- the board or its components, IC'S etc
wherein any of them could be costly, firstly, the availability of parts, specially that being a digital equipment,thus, its quite hard to pinpoint the "real" fault, without actually trying to test with instrument or another replacement part.
But as for my experience on our ACER projector, the Plug relocation just did the trick, somewhat an interference caused by the grounding (improper).And making the projector "solo" on an extension or wall socket.
Hope this helps.
Thank you for using Fixya.com
Posted on Nov 13, 2010
Epson ebs72 lcd
Hi Peter,
It sounds like you may be having some issues with the polarizing plates. If you are in the US, I can have one of our technicians speak with you. Feel free to check out our website and send us a message. Projector Repair Bulb Replacement
Jan 26, 2014 | Office Equipment & Supplies
I have a epson tw1000 projector i bought and i ordered two new lamps off of amazon got the lamps put one in the projector flipped the power switch on on the back of the projector light turns orange to let...
Lamp ballast is not work , you can replace a new ballast or to repair it.
Have a good day!
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Sep 23, 2013 | Office Equipment & Supplies
How do I flip the image on my Epson EMP 30 projector for ceiling mounting please?
Press MENU on the remote control (as show on picture below)
the menu window displayed
Press down arrow key to select ADVANCED
press ENTER on the remote control
use down arrow key to select ceiling (as show in picture)
press RIGHT arrow key to select OFF to ON status
press MENU key to exit menu
(the projected images are horizontally and vertically reversed.)
Feb 13, 2011 | Epson EMP 30 Multimedia Projector
After i replaced the lamp on my epson emp tw700, the red flashing warning indicate something wrong. What can i do to fix this problem?
My tw-700 warning light was flashing red (1sec) and this is what I did to fix it.
Take the top cover of the projector, you will see the PCB on top of everything.
Remove the PCB, be careful when disconnecting the ribbon cables.
Looking from the rear of the projector, you will see a metal bar held on by
2 black screws just in front of the lamp. remove this bar which is holding in a
small plastic door that has glass in the middle.
Remove this plastic door and lubricate the bottom of it with some high temp
grease. now put it all back together and with a bit of luck and if you plugged
everything back in properly, it should work.
This worked for my red light problem anyway, hope it helps you.
Oct 01, 2010 | Epson EMP-TW700 LCD Projector
Red vertical lines from top to bottom. Red lines,white lines in a uniform pattern
Try to change your VGA cable if the problem occur your A/V board was deffective.
Oct 23, 2009 | Sanyo PLC-XU73 Multimedia Projector
HP Pavillion zd8000 LCD problems
I had the same happen to me.. it started with one white vertical line.. then got the whole rainbow (red, green, blue).. Solution: Try connecting an external monitor.. if there is no problems, then it's not the video card or chipset.. it's going to be the lcd.. you can get it on ebay for about $200.. hope this helps..
Jose
Jul 16, 2008 | Computers & Internet
Picture off and shadow of back images.
Hi Grim159
I've had this once on a Epson Projector and the only way I could this right was by replacing the Mainboard.
Hope this is of help.
Apr 22, 2008 | Philips ProScreen 4600 Impact Multimedia...
Viewsonic Projector Blue Vertical Line
Hi guys
This is a common Mainboard problem on Projectors , unfortunately the Board will either need repairing or replacing.
No shortcutts on this one !
Aug 12, 2007 | ViewSonic PJ551 Multimedia Projector
Epson EMP-TW1000 LCD Projector Logo
220 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
