Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher and Paykel MW058U won't fill
I have a Fisher and Paykel SmartDrive MW058U which has a weird problem. The machine starts fine and starts to fill, then the water is shut off by the pump, it tries to fill it again, shuts off, fills, shut off (about every 3 seconds). Little jerky attempts to fill if that makes sense. The water is coming in from the tap fine, just the water inlet into the machine is shutting itself on and off for no reason.
I've tried unplugging the water level tube in case it was a level sensing problem and blowing through it but no luck.
After about half a minute of this it just starts beeping and won't move. The following lights are solid lit (where o is lit and * is unlit):
* * o * o * o o
Anyone have any ideas?
  • trigger702 Nov 19, 2008
    I have the same problem and don't no what to do either. I just had new Hot & Cold filter taps things installed a few months ago by Fisher & Paykel in Brisbane.
Fault is out of balance switch stuck on i removed and cleaned mine with crc but if still stuck on may need replacing hope this solves your problem
Posted on Oct 17, 2010
I just spoke to a Web based technical service. They recommend replacing the hot water solenoid at top of machine. They say it's easy to do and costs $20-40.
Gary A.
Posted on Nov 24, 2008
If there is a filter, try cleaning it. It might be blocked.
Posted on Jun 18, 2008
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel smartdrive 053 fills really slow
Your cold valve could be faulty & need replacing.
Try swapping hot & cold valves to see if it fills faster.
Jul 12, 2012 | Fisher and Paykel Washing Machines
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel Washing Machine "Pride 5.5" Smartdrive 8 Model MW058U. Washing tub thrashes around violently when wash cycle starts any spinning - even during rinse cycle. Load looks even around...
Hi just found your posting.Do you still require help?The problem with your machine sounds like your suspension rods are faulty.Please reply and I can help you rectify this fault.Looking forward to your reply.
Jul 14, 2010 | Fisher and Paykel Washing Machines
Fisher & paykel smartdrive 508 filling slowly
remove the hoses and check for any kind of clogging or restriction in the line there may also be a problem with your fill valves
Mar 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Washing Machines Logo
777 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
