Question about Sanyo DS20930 20" TV
Imagen negativa - Sanyo DS20930 20" TV
    Top Expert:
  • Sanyo Master
  • 74,459 Answers
Hello
Negative image is due to the absence of Luminance signal in picture. You are now seeing only the chrominace part of it. It will be surely due to the Chroma Luminance Juncle Ic fault. You just open your TV, find the chroma luminance jungle Ic, resolder it out from the board, go for a same type and number. Replacing it wil resolve your problem. You must have good concept of soldering and desoldering, as this is a quiet complex job, which may need as far as 68 soldering points, very close to each other, and have the chance to get shorted between. Ok
Posted on Nov 13, 2010
Mi problema es con mi mi televisor mitsubishi vs-50501 enciende y cuando va a entrar la imagen se apaga a veces si entra y se ve medio rara como que tiene dos imagenes un poco separada o se ve la imagen...
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Dec 19, 2013 | Mitsubishi VS-50609 50" Rear Projection...
Nesecito bajar imagenes desde la AV50 al final cut pro que tengo en mi unidad apple existe algun plugin o software adicional?
Simplemente descarga las imagenes a tu apple y despues las importas a Final Cut. En principio no necesitas ningun software puesto que esa camara, si no me equivoco graba en mp4. Puede que tengas problemas con el codec... en ese caso, tendras que convertir las imagenes a un codec que reconozca el Final Cut (por ejemplo H264).
Espero haberte ayudado.
Oct 21, 2013 | iSonic SNAPBOX AV50 Camcorder
MY 46 INCH TV WHEN IS ON THE IMAGEN GET LINES
Sounds like a defective T-con board. Worst case is your Panel, but I don't think so.
Mar 20, 2013 | RCA 46 46LA45RQ LCD TV
Se queda sin color la pantalla solo se ve la imagen pero sin colores sdolo en blanco es una magnavox de 32 pulgadas griz
Hello
Ya sea que est? viendo una pel?cula o un deportivo
caso, el televisor dispone de v?deo autom?tica
ajustes de control emparejados por su programa actual
de origen o contenido. La caracter?stica SmartPicture
restablece r?pidamente los controles de v?deo de su televisor para una
n?mero de diferentes tipos de programas y la visualizaci?n
condiciones que pueda tener en su casa. cada
SmartPicture configuraci?n se ajustan en f?brica para
ajustar autom?ticamente el brillo de la TV, el color,
Imagen, nitidez, tinte, la temperatura,
DNR, y los niveles de contraste +.
0.1 Pulse el bot?n inteligente de la imagen
en el control remoto. la corriente
Establecer SmartPicture aparecer? en la
centro de la pantalla.
2 Pulse el bot?n inteligente de la imagen
varias veces para seleccionar ya sea personal,
Pel?culas, deportes, d?bil
Se?al, o la configuraci?n MULTIMEDIA imagen
Aceptar
Jul 12, 2011 | Philips Magnavox 27MS343S 27" TV
Porque cuando tomo una foto de cerca sale borrosa la imagen
Eso sucede porque tu c?mara no ha podido enfocar la imagen, por lo general solo se necesita presionar levemente el bot?n para que el sistema de autofoco haga su trabajo y luego terminar de presionar el bot?n para capturar la imagen.
Otra causa puede ser que est?s utilizando un modo de telefoto o un enfoque largo y al tomar la imagen esto provoca que pierdas definici?n.
Jun 02, 2011 | Video Game Consoles & Games
Tengo imagen negativa kp/51hw40
Hola!
Pruebe los siguientes pasos para resolver el problema: Asegúrese de que las conexiones de los dispositivos son firmes y seguros. Trate de encender y apagar la opción de Digital Reality Creation en el televisor. Trate de ajustar la nitidez de imagen y ajustes del modo de la TV. Presione el botón FLASH FOCUS en el panel frontal del televisor. Esto modifica la convergencia. Si el problema persiste, pruebe a quitar el televisor de la pared a dejar y conectarlo a una toma de corriente directa sin ningún tipo de protector después de 1 minuto. Pruebe a pulsar el botón RESET en el tiempo remoto en el menú de vídeo y compruebe si funciona. Si el problema persiste, el servicio puede ser requerido.
Gracias por usar FixYa.
Dec 02, 2010 | Sony Televison & Video
COMO PUEDO RESETEAR EL CHIVATO DE REVISION
desconectar terminal negativa en acomulador { bateria} por cinco minutos, y reconectar, asegurar de instalar codigo de radio......Rod.
Mar 25, 2009 | 2007 Mercedes-Benz ML320 CDI
Imagen us unclear
Less than year? Check out Samsung website for warranty returns
Jul 02, 2007 | Samsung Digimax S600 Digital Camera
Sanyo DS20930 20" TV Logo
70 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
