Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
SanDisk 2 GB Cruzer
The flashdrive will not let me create new folders or transfer data to it. The memory is only half full. The error message reads "the directory or file cannot be created".
  • geobb Jun 18, 2008
    my usb key will not allow me to create new folders or to copy texts form emails or from ms word. I have tried the key on many different computers and i always get the "unable to resister folder or files".
  • Anonymous Jun 19, 2008
    I got the same problem as do many others. I already scanned for a virus and had none. There's got to be a better solution.
    Champion:
  • 214 Answers
Hai,
it seems ur flash drive is infected with some virus
scan the drive with an updated virus scaner.
if this does not succeded, copy ur data to the HDD and go for a full format.
good luck
Please don't forget to rate or accept the solution
Posted on Jun 18, 2008
I found the simple solution at this link and it worked!
www.quickonlinetips.com/archives/2007/09/how-to-fix-error-0x80070052-on-usb-flash-drives/
Posted on Jun 20, 2008
My sandisk cruzer 4 GB pendrive ws working fine but now whenever i try to format\copy\cut it shows location 0 with used space 0 free space 0 what should i do
Your flashdrive usually shows 2 drives when inserted to your computer, one is the U3 drive and the other one is the removable disk drives. U3 drive is your separate partition for the U3 system and in order for you to store, copy, format your flashdrive, you should be selecting the removable disk drive, not the U3 drive. U3 is a read only memory drive that is responsible for your U3 to work (just like portable applications). Hope this helps.
Jul 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
4 gb usb creating shortcuts folders
I think you are referring,that there are folders and shortcuts which are not created by you and its generating automatically?
if this so, Its an action of a virus. - Run full system scan using a up-to-date virus scanner.
Mar 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a new 8gb usb memory and i train to put 4.3gb movie inside then a message say that is too big.the memory is empty.please help
If your having a problem transferring the file on your flashdrive you can reformat the drive so that it you can use all the available space on it. Just Right Click on the flashdrive the select Format Drive.
Thanks for using Fixya.
Jan 31, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I cannot move a Microsoft Word file to a SanDisk 2 GB Cruzer,getting the message that "Directory or File cannot be created"...Why? What's the solution?
There is a problem with these where putting files directly on the root folder of the drive only allows X amount of files. Open the Cruzer from My Computer and create a new folder. Try dropping the Word file into that new folder and all should be well.
Hope this helps. Look forward to hearing back from you soon!
Feb 26, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Can't create new folder on memory stick
Sometimes these things get confused. try moving everything to a folder on your machine then, use the SanDisk tool to format the flash drive and move everything back.
Sep 08, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Heating up, light not coming on
cruzer micro 4GB, loaded with data. works perfectly in all systems except my xp. Problem didn't originate until after ghosting system to correct different problem. Now, error message states flashdrive not recognized. must then get behind pc, and gently work with it until i can hear the shift in the duo core processors and the orange light on the flashdrive comes on. Please help.
Mar 10, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Hi. I am trying to create a new folder on my cruzer flash drive and i am getting the error code: 0x0070052. Also, when i try to copy a file from my computer to my cruzer flash drive, i get the error code:...
Some USB drives have this issue when you have too many folders on the drive. It doesn't have to be even close to filling up the drive, just too many. Try moving some of your folders on the drive to an already existing folder, then try to create a new folder after you've cut down the number of folders on the root of the drive.
Jan 02, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer storage
Check the format. Make sure it's compatable with the operating system. Also check the size of your documents folder. If they are compatable, maybe there is something wrong with the flash drive.
Aug 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 2gb cruzer says read only, no data transfer ability
Is there a little switch somewhere on the thumbdrive. If so that would be the read-only switch. Try it in the other position.
Jan 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
323 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
