Question about Singer 6038 Mechanical Sewing Machine
I have been given a white sewing machine. but I need a manual on how to thread the bobin; ect; can you help me? thanks. someone said i could get a white;s manual on this web site.
  • 340 Answers
What's the model number?
You can download a white manual from the Singer site.
http://www.singerco.com/accessories/manuals.html
Just type in w followed by the model number and click on search.
On the next page click on the free download option that corresponds to your model.
Hope this helps!
Posted on Nov 13, 2010
I bought my daughter a White sew E-Z so she can have fun on her first sewing machine. However there is no manual and no instructions on how to thread the bobin. the bobin just sits on its flat side to go...
Check the model number of the machine. White sewing machine manuals are available from Singer at http://www.singerco.com/accessories/instruction-manuals . Enter the model number and click Search.
The White Sew E-Z model W338 manual is available here: http://www.singerco.com/uploads/download/705_white-338-x.pdf .
Unlike some machines this one doesn't really need the bobbin threaded. Place the bobbin in the bobbin holder and leave about 5" of thread extended out from the bobbin holder. With the bobbin compartment still open, lower the presser foot and turn the handwheel to move the threaded needle through the stitch cycle. (I find holding the threads helps; normally, you'll feel them pulling under your fingers.) When the needle has returned to the top of the path, lift the presser foot. Then pull both threads around to the front (the bobbin thread should wrap around the top thread). Then move the threads to the back of the presser foot.
If the needle isn't catching the bobbin thread, first try a new needle (bent or dull needles don't always function properly). Next check the bobbin holder for nicks or other damage. There is a small hook on the bobbin holder that should be where the top and bottom threads intertwine. Under rare circumstances, you will find that the bobbin tension of the bobbin holder is misadjusted. This can interfere with the bobbin thread twisting properly. There is a little set screw that allows you can tighten or loosen the bobbin tension as needed. Adjusting the screw is to be avoided when possible and done in small increments (1/8 turn) if needed. It's easy to strip the threads for the set screw and end up needing to replace the bobbin holder.
I hope this helps.
Jul 13, 2011 | White Sewing Sewing Machines
Bobin ran out and when I replaced it the thread from the needle keeps getting in a wad around the bobin holder
Sounds like there are spare thread pieces stuck in the bobbin casing/ hook area. Disassemble (it is usually self-explainitory on most machines), clean it out, then re-thread your machine, being mindful of the tension settings. Does this fix it?
Jun 21, 2011 | White Sewing 312 FS
My thread got caught inside where the bobin is so I took out the bobin and the thread was still stuck. I took out the 2 metal pieces that hold the bobin in place and now I can't get them back in. Help?!
Insert the small metal piece into the big piece. Try turning it in a circle one way. It should fall into place. It it doesn't, take the small piece, flip it, and turn again in a circle. It's very easy. Or go to ebay under bobbins so that you can see a picture.
Apr 06, 2010 | White Sewing 1866 Mechanical Sewing...
I reloaded my bobin and began to sew. The thread
Sometimes it may look like the bobbin is the problem, when it is actually the machine was threaded with the presser foot down.
Refer to the manual for your machine and recheck the direction the thread is be feeding from the bobbin and that it is going through the proper guide(s).
Always thread a sewing machine with the presser foot up.
When threaded with the foot down, the tension is closed and the thread cannot enter. When you sew, the stitches are loose and loopy.
Feb 24, 2010 | Baby Lock Sewing Machines
Need manual for model 5825c for threading
i was able to find it at www.ifixmachines.com
Oct 18, 2009 | Singer Electronic Sewing Machine
MITSUBISHI DB 130G threading instructions
I am looking for a manual for the Mitsubishi relsew DB-130. I need to know the best way to thread the bobin and the correct way to put in the needle. I will take a photocopy of the manual if someone has one?
Aug 02, 2009 | Sewing Machines
The manual doesn't explain how to thread bobbin correctly
You thread the bobin by putting spool on post and then winding around the tension thingy.
I looked on line and saw a video how to do it
Jun 29, 2009 | Singer CE-100 Futura Computerized Sewing...
I forgot how to install my bobin
Hold it in your right hand by one of the flat sides. The thread should come off the top of the spool going away from you. Lower it into the bobbin hole and replace toe top cover.
Jan 05, 2009 | Brother XR-65t Mechanical Sewing Machine
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
Singer 6038 Mechanical Sewing Machine Logo
64 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
