Question about Goodman CACF048B2A Air Conditioner
Goodman furnace draft inducer motor doesnt start so nothing happens have volts from thermo steady light on board
  • scott skala Nov 13, 2010
    when i checked it last night in the dark i wasnt getting any voltage at motor. ac works fine, isnt there a relay for that motor? i also noticed that there isnt that normal click sound at the beginning of cycle. could there be something holding relay out, some sensor, or do we have to go directly to replacing the board?
  • scott skala Nov 16, 2010
    yes it seems relay is built in board
  • Goodman Master
  • 43,501 Answers
Using a voltage meter check and see if you have 120 volts at the motor... if so then the motor is bad....
If there is no voltage to the motor then the board is bad....
Replace the motor or board as needed...
heatman101
Posted on Nov 13, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Nov 16, 2010
    Your right... the relay is in the board and you will need to install a new board...
  • Goodman Master
  • 8,220 Answers
See if you are getting power to the inducer motor. Does the motor have continuity between the 2 leads? If not then the inducer motor is bad. You either have a bad board or inducer motor. My guess is the inducer motor. You gotta do them checks to confirm that though. It starts with that board which powers the inducer then to confirm it is on the proving switch has to get suction produced by the inducer. That sets of a timing sequence and the igniter comes on. After the end of the timing sequence the gas is release and is ignited . The flame sensor then has to confirm ignition. None of which is gonna happen if the inducer does not come on. I would suspect the relay on the board or a bad inducer motor.
Heater does not come on gms80703an
There are too many reasons for this to happen so we would have to narrow it down. The sequence of operation on a Goodman furnace is usually:
1: Inducer draft motor comes on
2: Hot surface ignitor comes on and glows
3: Gas valve opens, lights burners
4: Flame sensor detects flames
5: Blower comes on
If the inducer motor never came on, then you start looking at power to the unit, thermostat issues, or inducer motor issues. Just a few places to start. Hope this helps!
Dec 05, 2013 | Goodman Heating & Cooling
Hi, I have a Goodman GMS80903BNA Furnace and recently what happens is that when the thermostat calls for heat the draft inducer motor starts. However, after this nothing seems to happen. I don't h
Youcould be loking at the pressure switch try jumping it out and see if it lights some times you can fool it in to working , check the hoses are tight and nor spilt or take a drill bit and just clean out the 2 ports where the hoses fit some times they get blocked , also check you air filter is clean and your fan
Dec 18, 2012 | Goodman GMS80903BNA Heater
Goodman furnaces gxs91155dxaa will not start> steady red light on the circut. No inducer motor. Somthing strange when I disconnect the Roll Out sensor the blower motor runs along with the inducer...
I would first try to power up the inducer motor by itself. If this works without any issue than the next step is to look at the circuit board. You will need a multimeter. Set it to 120V AC and test the leads on the circuit board that the inducer motor attach to. Turn the system on and see if you get a reading on the meter, if so, then you know the motor is getting power. I would then check the legend of your furnace with the led pattern. You mention it is steady, look up what the steady light means. It may point to a control board error, in that case you will need to replace the board.
Mar 01, 2011 | Goodman Heating & Cooling
Furnace was working fine and just stopped working...it reacts to raising the thermostat but doesnt actually flame on
This is probably a ignitor.
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks.Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. Please see "limits, rollout switches & furnace control boards" further down on this page. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Please leave feedback... Thanks...
Jan 28, 2011 | Goodman GMS90703BXA Heater
I turn my thermostat to the HEAT position, I hear the Thermostat click and the Furnace begins to hum but no air comes out of the vents. Also if i turn the fan to the ON position air will come out of the...
need to go to furnace and watch it...if your hearing a hum the enducer draft motor may have failed...it should start first if there is no fault codes...reset unit by unplugging furnace or in some cases turning power switch off...turn thermostat on heat and watch unit ..the small enducer draft motor should start first the a ignitor glows and the should light...goodman units have a control board with a light on control board when it fails should flash a code and on the door or inside on lable should give you what that code is...hope this helps good luck
Jan 07, 2011 | Goodman GMS90703BXA Heater
Hello there, I have a Goodman GMH951155DXAC furnace that I got in 2007. I have the following problem for the last 4 years: When the thermostat calls for heat the induced draft motor comes on and 30-40...
With furnace OFF ,Disconnect the top of the hose that leads to the
Bottom of Daft inducer Box, Now blow into it water will come out
of the drain hoses "condensation " this will shut the unit down if not drained. There must be a Trap on the side of the Furnace with water in it , to have positive presure to suck out condensation. This will fix problem. some installers forget to install this Trap that comes with Unit.....!!!! A little item
that will shut the whole system DOWN. :o)
Jan 06, 2011 | Goodman Heating & Cooling
What is the model number for the Draft Inducer Motor Goodman GNP075-2REVB Furnace
I think you must mean GMP075-2rev8 check this link for parts listing:
http://site.famousparts.com/goodman/PDF/RP-169C.pdf
Johnstone supply which has many locations in many cities sells Goodman and stocks parts, and available mailorder http://www.johnstonesupply.com/corp/Default.aspx
Feb 18, 2010 | Goodman Furnace Draft Inducer Blower ...
Janitrol furnace-circuit board code giving 3 blinks vent pressure switch or vent blockage where do i check on system / furnace was running fine up to this point /turned it off for about 1hr. and when i...
f this is a metal vent 80% furnace,Turn Furnace off
and remove the vent that connects to furnace and see if it is plugged.
If this is a High Eff furnace witrh pvc vents for
exhaust and intake air make sure they are not plugged on the outside.
Turn thermostat all the way up,turn furnace off and
wait a few minutes.This should reset any control
board fualt.
Turn the furnace back on, if you have a glow coil
ignitor it should glow red and then the burners should
ignite. If this doesnt happen then:
On High Eff Furnace if the glow coil does not glow red, remove the combustion door to the burners,
turn furnace back on, if the glow coil glows and
burner ignites, you have an obstruction in the intake
air side. If it still does nothing then:
Use caution and remove the exhaust vent from furnace, start furnace, if furnace runs then you
have a problem with the vent system
Feb 13, 2010 | Heating & Cooling
Goodman: My Power Venter (aka Heat and Draft Inducer) won't start
The power ventor most likely needs to be replaced. But be advised. Goodman normally will not sell parts to anyone but a certified technician. I had to show my masters certificate to buy parts from their outlet. This is a part that has a high rate of failure.
Ray
Dec 01, 2008 | Goodman Heating & Cooling
Janitrol/Goodman GMP075-3 Draft Inducer Fan Won't come on
most forced draft fans are powered by 120 volts . close to the fan is usually a plug that unsnaps. create a call for heat after turning off to clear safetys and see if your getting 120 to fan on initial call for heat. if you are then fan draft motor is bad, usually sold as an entire assembly replace exact as it came out. sequence of operation is..... stat calls for heat via common and white wire to furnace , 24 volts. ......board sences call and sends 120 volts to forced draft ........ motor runs and creates pressure on proofing switch,....... switch closes 24 to board and tells it draft fan is on......... board then energizes ignitor,....... after ignitior glows gas valve is opened and burner lights ........ either ignitor or seperate sensor rod tells board the burner lit........ and a few minutes later the fan comes on and hot air is blown out. if a step is missed or doesn't proof the furnace either trys up to three times to light or locks out. turning off power usually resets safetys and it will resume attempts to lite normally.
Oct 25, 2008 | Heating & Cooling
Goodman CACF048B2A Air Conditioner Logo
1,178 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
