Question about Antec SL350 (smartpower sl350) 350-Watt Power Supply
The fan turns on and off for the SL350 - Antec SL350 (smartpower sl350) 350-Watt Power Supply
  • Antec Master
  • 27,725 Answers
You might have a faulty PSU power supply unit or a faulty power point or lead
test the power point first by trying another electrical device then test the lead if these fail you will have to test the PSU using a multimeter making sure your psu is getting the correct amount of voltage and wattage
hope this helps
Posted on Nov 13, 2010
Unable to demist windscreen on mercedes SL350 (2004)
the actuator the changes the vent flap position is not working. Check vacuum hoses or module.
Jan 07, 2014 | Cars & Trucks
How to replace wheels on sl350 stairlift
Did you ever figure out how to replace the wheels on your Harmar stair lift? I think I got the same problem, but can't find where I can buy the replacement wheels? Can you help? dennismolgaard@yahoo.com
Dec 18, 2013 | Harmar Sl350 Stair Lift
Antec SL350 (smartpower sl350) 350-Watt Power Supply circuit diagram
As I told someone before I have been the computer business for many many years and have never needed a schematic. I am curious why?
Nov 13, 2012 | Antec SL350 (smartpower sl350) 350-Watt...
I need a free manual for my Simplicity Serger SL350
I can't find one for free, but sewingpartsonline.com show they have
one,, hardcopy or download.
I don't know if the link will work or not, if the link doens't work
go to sewingpartsonline.com
to go shop by catagory
instruction manuals
simplicity & then look for the model number sl350
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl350.aspx
Jul 10, 2012 | Sewing Machines
Computer does not power up.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 21, 2011 | Antec SL350 (smartpower sl350) 350-Watt...
I need a wiring diagram for an Antec SL350 if possible please
Why? In the many years in the computer business I never had a need for a schematic. Just curious!
Dec 17, 2010 | Antec SL350 (smartpower sl350) 350-Watt...
Front fan on the power supply is not working
Two things come to mind ...
Thing one: There is probably a small fuse inside your power supply. You can probably replace it without getting hurt. If you don't fix or replace the power supply IT WILL FAIL. On the one hand, it isn't working now ... if you try to fix it and fail, you will have to replace it. If you don't try to fix it, you will eventually have to replace it.
Remove the computer cover. Unplug all the leads. Take a pic or several and make copious notes of where they go. Remove the 4 small screws holding the supply in. Once out, determine the process to open the unit. Look closely for a very small fuse. Try to get the value before you remove it. Something else to do is to test the fuse with a volt ohm meter.
The problem with waiting is, HEAT, is the enemy of your entire computer. You don't want to fry internal parts.
Thing two:
The fan may be bad ... it plugs into the PCB or is soldered into place. It is easily removed and replaced. Get a replacement at FixYa.com advertiser or Radio Shack or similar place. Watch polarity when you replace it.
I hope this helps you ... Please don't wait for complete failure.
Thanks
Please vote
Positive comments always welcome.
a
Dec 07, 2009 | Antec SL350 (smartpower sl350) 350-Watt...
Antec SL350 (smartpower sl350) 350-Watt Power Supply Logo
121 people viewed this question
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Julie Endres
Wahs Team
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
