Question about McCulloch FG6000MK 5700Watt 13 HP 338CC Portable Generator
No spark to the spark plug when pulling the cord
  • 7,733 Answers
First change the spark plug,if the problem persist,change the coil aka=spark plug cable and coil.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
Pull Cord Stops...
could be valve needs set. if it isn't opening at the right time it wont release compression for it to start. it may be the shear key in the flywheel has sheared if you have hit something like a big rock or log or something causing it to die suddenly.
May 17, 2016 | Craftsman Garden
Cannot pull cord/ pulls easy when spark plug is out. Cannot detect fuel at spark plug, seems to be no spark. Had been using it without problem, then shut it off for a bit, now this.
Usually if you cannot pull cord with the Plug in it is because there is way too much fuel in the cylinder and that causes Hydralock. Does the cord pull at all? Something in the cylinder bumping up against the plug?
Nov 05, 2015 | Garden
Yard man pull cord will not pull
Remove spark plug and see if you can spin the blade . If the motor spins than the pull cord assembly is seized up and needs to looked at and fixed. If the blade won't spin then the motor or the cord assembly is seized . Make sure you remove the spark plug before trying to spin the blade.
Sep 08, 2014 | Yard Man Garden
U tube chainsaw pull cord wont pull start
Some saws with autotmatic oiling will leak bar oil into the cylinder and cause this. Pull out the spark plug and hold the saw so the oil runs out of the spark plug hole. Pull the starter cord till no more oil sprays out of the hole.Clean the oil off the plug and start your saw. It will smoke more than normal till the extra oil is burned out.
Sep 05, 2014 | Homelite Garden
YOU have told me to reattach the pull cord 3 different times.
Laying the spark plug against the cylinder head is not an ideal way to check for spark. The best way is with a tool designed specifically to check for spark available at most auto parts stores. Remove the spark plug from the engine. One end of the tool plugs into the plug wire the other end is a clamp and gets clipped to cooling fins or another good ground on the motor. Pull the cord and you will be able to see and hear the spark.
Jul 08, 2014 | Poulan Featherlite Gas Blower, with Low...
Are you stupid? I wrote that WHEN I PULL CORD I AM NOT GETTING ANY SPARK. YOUR ANSWER,TWICE is to REATTACH PULL CORD.
wow! That is pretty funny.
Ok....now lets check this out again. Take off the spark plug lead and then get a plug socket and remove the plug. Now reconnect the plug to the plug lead and set it on top the engine to ground it and pull the cord. If it has spark you should be able to see it. And leave the cord alone! ha ha!
Also, look at the plug when you pull it and see if it is wet with fuel or water. A lot of these small engines have gotten fussy about fuel and one bad tank will ruin your season!
Starter cord won't pull all the way to start engine. Engine 300 series 4.50 Lawn mower
Remove spark plug pull cord. This will release compression blow out cylinder. Replace spark plug try cord.
Aug 03, 2013 | Garden
When i pull the starter cord it pulls back really hard
pull off the spark plug and spray wd40 wait 15 min to 30 min and then pull without spark plug in then put the spark plug back in and then try it
Apr 15, 2010 | Craftsman 8.50 Torque Rating Dual...
Cant pull the rope but when you take the spark plug out the rope will pull
Sure its the correct spark plug? Sounds like the piston is coming in contact with the spark plug.
Aug 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
McCulloch FG6000MK 5700Watt 13 HP 338CC Portable Generator Logo
288 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
