Question about Refrigerators
Refrigreator not working - Refrigerators
  • kingbulla Nov 13, 2010
    refrigreator not colding
  • 2,973 Answers
It is a very vague statement you have made. Please clarify if it is dead, or the lights come on but the fridge does not cool. What is it with your fridge???
Posted on Nov 13, 2010
  • 10,865 Answers
Hello. Thanks for choosing Fixya! If your fridge is not working at all, there are several possible causes. If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these: Wiring Thermostat Defrost timer Compressor Overload and/or relay Unfortunately, we can't describe all of the possible problems and repair solutions here. If you are unable to troubleshoot the problem from here, you may need to contact a qualified appliance repair technician. The other option is to get back to us here with the brand name and model of your fridge, and the specific reasons why you say that it is not working. We really do want to help you but we need more information. Thank you. Joe
I have samsung refrigrator model RL729WCSW since yesterday the Fan inside refrigrator has Hitting noise and the sound will Stop When The Door Is Opened.would you explain me how to rectify the problem. the...
The defrost is not working and the fan is hitting ice buildup...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Refrigerators
Can you add refrigerant to the refrigrator. it is not cooling like it should. this an olser refrigrator side by side kenmore..934163-D
you can add if needed . but this is the last thing to do for your problem . do ck the fans and air flow first . also the derfrost system these are more common for a no cool problem .. mm
Aug 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Air conditioning not working will not cool car
hi
this may be because
1.the refrigrant is not sufficient for cooling so the cooling process is not taking place.
2.there may be some leak due to which the refrigrant may drained out
3.the cooling fan is not working properly
4.the radiator is not proper.there are blocks in it which reduces the rate of cooling.
these are the reasons
if my infrmation was useful please vote me.
Jul 12, 2010 | 1993 Jeep Grand Cherokee
Freezer and refrigrator both not cold as supposed to be
make sure the compressor is working first,if not then replace the ptc overload on the compressor,if you have had lights blow out in the refrigerator section and theres a chattering/clicking sound in the rear and the new lights strobe dimly and the digital temp read-outs are dark,then its the main board in the rear thats bad
May 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My motor is running, but the temperature is not cooling and everything is starting to melt.
The motor is running normally?so that mean there is no gas in the system,probably a leak of gas in the system,have you not smell the leak of gas?How old is the refrigerator?
Jan 25, 2010 | Whirlpool ED2FHSS Side by Side...
Shows E1
its because the thermistor in your refrigrator has failed . it controls the the temperature settings give me your model and brnd of your refrigrator i will give procedure to replace it
Aug 20, 2009 | Caravell Refrigerators
Refrigrator stopped working
Morning, This seems quite a easy problem to fix.! Check to see if the f/.freezer has to compressors (motors)? If so the you find that is more than likely to be that the fridge thermostat has broken. A very easy way of checking if you electrially minded is to remove the thermostat from the housing a connect the live and common wires together and switch on, It then should switch on if there is no other problems, Then just replace the stat.
Good luck......
Dec 29, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
Refrigrator
If you are lucky you can use a John Guest Push-Fit" connector to reconnect the two ends together..if you have enough hose to work with ..sometimes you can pull on the end that goes into the refrigerator cabinet to give you a little more hose... let me know what you do? krazytech
Sep 10, 2007 | Whirlpool GD2SHGX Refrigerator
Refrigrator
Try checking your water valve in the back and see if its still good... thats what lets the water in... if its getting power to it
Sep 01, 2007 | Jenn-Air JS42CSFXDA Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
