Question about OKI C3400n Laser Printer
Oki 3300 n won t talk to 64 bit windows 7 shows in the properties accepts documents in printing queue, prints test page but won t print documents
flopez
  • 161 Answers
SOURCE: Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Posted on Sep 22, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Posted on Jan 02, 2008
Soulvisitor
  • 1113 Answers
SOURCE: OKI C5200 laser printer
Delete driver, download latest from oki, reinstall, is this networked or USB?
Is printer free from error lights, check page settings.
more I think about it, it seems to be a network/driver issue.
If printer can stand alone print ok ie menu map, then it is either the cable but more often the driver.
Check IP config if network.
Fixya or post back
Soulvisitor
  • 1113 Answers
SOURCE: Oki c5100n printing colors offset
posted by Halfwalkeer on Nov 13, 2007 Report abuse
Just replaced the color toner cartridges in the c5100N, two OKI (cyan and yellow) and one non-OKI (magenta). Now it appears that registration is completely off.
When printing an image, there is a band of yellow at the top about 6mm high, and a band of purple (not cyan) at the bottom about 6mm high. It seems that the yellow printing LED array is printing offset. I've verified this with a typical test page that shows yellow blipped up by several mm.
What the hell happened ? How can I fix it ?
Thanks -
Dean.
Comment by Halfwalkeer, posted on Jan 02, 2008 Drums are all at 34%. Please don't tell me that the drums only have a 50% lifetime on them, because that would just suck royally. When you say the problem is most likely drums, in what way ? What could have gone wrong ?
I was able to more or less fix the problem ... It took several iterations of ColorMenu->Adjust Registration followed by Maintenence Menu->Menu Reset, but it was finally able to pull the registration back into line.
I got worried at one point - after it was "fixed" the printer was powered off. Upon powerup again, registration was off by several centimeters ! Another round of the above finally "fixed" it again, but I haven't powered it down again.
It was a cheap printer. Maybe this is why ...
postsolution.gif Post Solution addwq.gif Work Queue sameproblem.gif Have the same problem? X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Solution #1 posted on Jan 02, 2008 0%20stars.png
4d566c2.jpg Soulvisitor
Rank:guru_s.gif Guru
Rating: 86%, 674 votes
Comment by Soulvisitor, posted on Jan 02, 2008 I was thinking about the band of yellow being caused by cleaning blade wearing on drum, drums are garenteed by oki if over 50 %, under that one is on their own ie purchase new if having problems with them
If you can fix problem doing colour calibration then faulty drum is not likely the issue.
Cant stress how many problems are caused by non gen consumables in machines, highly dont recommend their use.
Posted on Jan 13, 2008
flopez
  • 161 Answers
SOURCE: oki microline 320 turbo
Your Oki model does not need drivers, for they are already contained since Windows 98 and up. However, if it still doesn't work, check that the printer emulation is set to IBM and then install a new printer using the IBM Proprinter II/III driver, also contained in Windows.
Be blessed.
Posted on Nov 07, 2008
I have a Lexmark x7350 connected to a PC running Win7. I have previously been able to print with this combo with no problems at all. I have removed the device, uninstalled the Lexmark software, rebooted,...
Please follow the steps on to properly Uninstall Lexmark Printers from your computer. After the uninstallation process is done, reboot pc when prompted.
When pc turns on, check if your Windows 7 is running on 32-bit or 64-bit. On your computer, go to Start menu > right-click on Computer > Properties. Take note of the System Type.
Use the link below to download and install the Lexmark X7350 Printer Driver on your computer. Note: Use the Vista Driver on Windows 7. - Lexmark X7350 Driver for Vista 32-bit - Lexmark X7350 Driver for Vista 64-bit
When the installation process is successful, try to print a document to verify that the problem is fixed.
Sep 11, 2011 | Lexmark X7350 All-In-One InkJet Printer
Hi I have a Windows 7 (64 Bit) laptop and im
Please check the driver weather its support Win 7 64-bit or not, because Win7 have 2 varians 32-bit and 64-bit. If its not support 64-bit windows, you can download new driver but must be compatible with 64-bit system. Even if its the latest version of driver, but not support 64-bit system it won't be work.
You can download driver from here :
http://software.canon-europe.com/products/0010891.asp
or here :
http://driverscollection.com/?H=PIXMA%20MG6150&By=Canon (choose Windows 7 64-bit).
Uninstall the driver from your PC then reinstall with the new driver.
Hope this help.
Mar 09, 2011 | Canon PIXMA All-In-One Photo Printer with...
My Lexmark x4690 all-in-one printer is not printing. It prints if I go through the touch pad menu on the printer and print an alignment page but not if I try to print anything from my computer. Text,...
You may need to uninstall the existing X4690 driver first before installing it's driver for Windows 7. Follow the instructions in this artricle on How to Uninstall Lexmark Printers. Once driver is uninstalled, reboot pc when prompted. Reinstall using the driver for Windows 7 from the Lexmark website at:
- Lexmark X4690 Driver for Windows 7 32-bit - Lexmark X4690 Driver for Windows 7 64-bit
Hope this helps.
Feb 25, 2011 | Lexmark X4690 Wireless InkJet Printer
My printer refuses to print. The Red Status light came on so I checked and found there was a paper jam - cleared that. Can get green light to come on if I press the job cancel button but still cannot get...
Perform a Factory Reset
Turn the printer power switch OFF on the right side of the printer. Check that the front cover is closed.
Turn the printer power switch ON while holding down the GO button until the Toner, Drum, and Paper LEDs are lit.
Release the GO button. All LEDs will be off.
Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the Ready LED will be lit.
Print a Test Print Page
Print the Print Settings by pressing the GO button three times.
- If the Print Settings pages do not print, check for alarm lights on the printer. Clear the printer error before trying to print again.
- If the Print Settings pages print, the problem is isolated to printing from your computer. Verify the printer cable connects from the back of the computer directly to the printer. If the cable has become disconnected, loose, or connects through another device, the printer may not be able to print.
Check the Printer Driver Properties
Follow the instructions below based on the operating system installed on your computer.
Windows 7:
Click on the Windows icon => Control Panel => View Devices and Printers.
Right mouse click the Brother printer. Left click See What's Printing. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
Click Properties from this Printer menu list.
Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
Click the General tab and Print Test Page button. The Windows test page should now print.
- If the Windows test page prints, try printing from a program.
Windows Vista:
Click on the Windows icon => Control Panel => Printers or under Hardware and Sound click Printer.
Right mouse click the Brother printer. Select Run as administrator and left click Open. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Windows XP and 2000:
1. For Windows XP Professional, click on Start => Printers and Faxes.
For Windows XP Home Edition, click on Start => Control Panel =>Printers and other hardware => Printer and Faxes.
For Windows 2000, click Start => Settings => Printers.
2. Double-click the Brother printer to open the print queue. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
3. Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
4. Click Properties from this Printer menu list.
5. Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
6. Click the General tab and Print Test Page button. The Windows test page should now print.
Nov 01, 2010 | Brother HL-5240 Laser Printer
Win 7 Ultimate PC won't print to HP C8180 network printer
You can use the Alternative Drivers to Print.
To Use the Alternative drivers, just follow the steps given below.
Go to devices and Printers
Select Add a Printer.
Click on Local Printer. Select Create a new port.
And Select Standard TCP/IP from the port list.
Enter the IP address of the Printer in Printer name or IPaddress. Click on next.
Make sure that you uncheck the automatically detect printer and install driver option.
Click Next. From the list of Manufacturer, select HP and from the list of Printers select Officejet 6500 wireless E709n. Click next.
Do not share this printer
try printing the test page.
if the issue still persists, Post back.
Apr 02, 2010 | HP Photosmart C8180 InkJet Printer
Says the documents are in queue but they never print
You need to open your printer window and clear all your documents. Either go to start, settings, printers and faxes. Double click on your Dell 720, click on the file menu and click on cancel all documents. If necessary, after you do that, you can restart your computer. Then go back to start, settings, printers and faxes. Right click on your computer and click on properties. When the properties window opens, click on print a test page. If you cannot print a test page, then you need to check your printer install.
Let me know if you can print a test page after you go thru this process.
Brian
Mar 04, 2010 | Dell Inkjet 720 Printer
I've downloaded the Vista driver for a Laserjet 1160, go through the add printer process, it confirms printer added successfully, but it still won't print. I've checked leads and USB ports and the printer...
Sandra, Do you see the HP LaserJet 1160 printer listed in Start (Windows Icon) > Control Panel > "Hardware and Sound/Printers" (Control Panel Home), or "Printers" (Classic View)?If you do not see the printer listed, run the installation from the CD that came with the printer, or you can download the drivers from the HP support site at http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=410620&lang=en&cc=us&prodTypeId=18972&prodSeriesId=410618&taskId=135note: make sure you choose the correct version (either Windows Vista, or Windows Vista x64). If you're unsure, you can check by right clicking "My Computer" and selecting "Properties". Under the system category you will see "System Type" noting either a "32-bit operating system" or "64-bit operating system". If you do see the printer listed in control panel/printers, then: Are you able to successfully print a test page? (Right-click the HP LasterJet 1160 and select "Properties", then select "Print Test Page").If not, does the test page show up in the printer queue? (You can check the queue by simply double clicking the printer). Let me know what you find!- Joshua
Jun 08, 2009 | HP LaserJet 1160 Printer
OKI C5650n USB port not working
Yes, well I can´t help you to solve that problem and in fact i´m hoping that you´ve already solven it, cuz right now i got the same problem with my c3450... It worked just fine under vista x64 but now on windows 7 x64 i have the same problem as you have/had!
Cheers
Jun 02, 2009 | OKI Office Equipment & Supplies
Printer installs but won't print
Did you check whether the printer is compatible with Windows vista. If you are not sure check from the printer company web site.
Better check also whether, when printing the printer your using is highlited in properties of the printers in control panel. Its better if you dellet the printers you are not using.
Apr 01, 2008 | OKI C5100n Laser Printer
Pagepro 1350w install/print problem, vista document stuck in queue,error
Go to control panel, printers, right click the pagepro and select properties. Click the ports tab and make sure that the port is set to a USB port. This did it for me.
Mar 17, 2008 | Konica Minolta PagePro 1350W Laser Printer
OKI C3400n Laser Printer Logo
3,224 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
