Question about Gateway MX6442 Notebook
I have a Gateway MX6442 and I would like to know if I can upgrade the Motherboard or the CPU? I have upgraded the RAM to 2 gigs.
  • Gateway Master
  • 12,061 Answers
Http://www.powerleap.ca/Downloads/GatewayGuide.htm
I don't think you can, check it out at the above website, i think these CPU's are bonded to the board i maybe wrong but i think thats the way it is.
A link to download your manual is below.
http://www.retrevo.com/support/Gateway-MX6442-Laptops-manual/id/606dj997/t/2/
Posted on Nov 13, 2010
What is the best upgrade cpu for a compaq presario sr5110nx 32 bit vista O.S... ATHLON 64 (single core) without having to go to 64 bit, and/or new drivers ?
The 400W PSU is going to limit your CPU selection to dual-core at best, although you might be able to get away with a higher-end dual-core CPU if your RAM is not ECC and not dual-channel, and you're not running anything serious in terms of a graphics or sound card or a SCSI array.
Given your current setup I'd really look for a 1.6Ghz dual-core Athlon which has a decent amount of KB in its Level 1 and Level 2 cache, but 3MB for its Level 3 cache.
Anything beyond that ballpark of a CPU upgrade is certainly well within the bounds of diminishing returns, and you should look at getting a new PSU, motherboard, and probably RAM (I'm guessing you're using DDR2 RAM currently).
May 24, 2014 | Compaq Presario SR1050NX (DW257A) PC...
Asus f3j bios mod for upgraded ram
Not sure what you are asking about. Asus site says the motherboard will take DDR2 533/667MHz SDRAM, 2x SO-DIMM socket expandable to 2GB
Which means DDR2 533mhz 1 gig per slot total 2gig
or DDR2 667mhz 1 gig per slot total 2 gig
To enter BIOs press F2 at boot up, but no setting should need to be changed.
They do not have a BIOs update for increasing the memory limits.
BIOs upgrades from first to current are.
BIOS 304
Update new CPU Microcode
System plays wave file and causes garbage sound.
BIOS 305
To fix system cannot do battery pre-charge process when an unknown/failure battery insert.
Support Intel Extend ID CPU:Merom Celeron 530 CPU.
BIOS 306
BIOS 307
Fix System hang at ASUS LOGO on SATA HDD with factory recovery image
Last upgrade date is 2008 7 14
Mar 14, 2014 | ASUS F3Jc Notebook
How to get more than 2 Gigs of RAM to read on the current Sony motherboard?
No you cannot trick it. A BIOS upgrade MAY allow you to install more than 2 Gb of RAM.
Sep 02, 2012 | Sony VAIO VGC-RB42G PC Desktop
Can you please advise the best CPU for my motherboard as I am upgrading my pc
your board gose too 2g a 3200 cpu with 400 fsb is the max you can go jim.
Nov 11, 2011 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
I increased memory from 512 to 768 on Dell desktop with 2.4 celeron but did'nt seem to increase speed.what is the problem? Ray.
That minimal amount of increase is not going to be a very noticeable increase also the processor or a faster RPM hard drive is more for the speed. you can go to the system properties in control panel and then the advanced tab and then the settings tab on performance then to the Advanced Tab then to change tab in virtual memory then to custom size make the initial setting 1.5 times the amount of memory installed in your case 768 x 1.5 = 1152
on the max 3 x the amount of memory again, in you case 768
768 x 3 = 2304
Jul 07, 2010 | Dell Dimension 2400 PC Desktop
Cpu speed for ddr 400 ram
cpu speed has nothing to do with ram. they are completely independant. ram speed is important to the FSB (front serial bus) this is the speed at which your motherboard communicates with the devives attached to it. cpu speed refers to how fast a cpu can process info. or how fast it "thinks". most motherboards have the capability of upgrading cpu's. your mobo (motherboard will support the following cpu's:
any pentium 4 up to 3.0 ghz
it supports the following ram
ddr (nott ddr 2 or 3) up to 2 gigs (1 gig each slot) of 533mhz speed (or less)
it also supports up to 2 gigs of sdram either pc133 or pc100
you are using 400 speed ram as you stated i would upgrade to a 533 speed ram as it will be faster, but this is not necessary. as for the cpu just get any P4 (pentium 4) that is 3.0 ghz or less and it will work.
Jun 27, 2010 | ASUS P4S533-MX Motherboard
Processor upgrade
You have a P4 Processor.... a 3.0 was the fastest. I would not upgrade the processor. You can however upgrade the Motherboard if you can do it yourself. That will take you to a SATA Hard Drive system and allow you to afford some faster RAM and Cheeper RAM.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138079
Another option: get 1 gig of ram, new Hard Drive and Win7. Speed improvement will be double.
Dec 27, 2009 | Gateway 835GM (835GH) PC Desktop
MT3705 Gateway, what motherboards will work with this laptop. I want to upgrade this laptop, so i want to get a motherboard able to really max out my ram but still use this chip set and everything else on...
You don't get different mainboards for laptops.....sorry. It's not like desktop pc's where pretty much any mainboard will fit. And even if you could, it's not really going to improve things, as you are using the same speed cpu. Your laptop has 2 ram slots. That's the most you will see on laptop mainboards.
Adding ram is probably the best bet. That laptop shipped with 1 gig of ram.....which is not enough for Vista. I bet it's quite slow. Vista wants 2 gig of ram to be happy, and 4 gig to really motor along. Laptop ram is cheap for that machine, so check it out. Ram is not expensive, and will give you an immediate, very noticeable improvement in performance.
Hope this helps. Post a comment and let me know how you make out
Sep 04, 2009 | Gateway Computers & Internet
System speed
Your CPU speed depends on your front side bus speed. Overclock is an option but never recommended. The upgrading ram is cheapest and most noticable upgrade you can do. If your do want to upgrade your computer i would recommend upgrading ram. Remember any computer with a 32-bit processor can only reconize 4 gig's of ram.
Jan 15, 2009 | Intel Motherboard
Sony Vaio VGN CR-220E
Haha!
I had such dreams too with one of my old Vaio. I really wanted to upgrade the processor and graphic chipset. Turns out that the latter is impossible (it was soldered to the motherboard - it wasn't a graphics card, just an all-in-one chip), as for the processor I was able to take it out but I ran into several problems:
1) vaio added electronic components to the motherboard that made higher CPU speeds unachievable even if the motherboard's cipset (VIA) was able to do that.
2) the cpu maker (AMD in my case) kept telling me that their mobile cpu were custom designed for that specific laptop, so new cpu would be incompatible. Also mobile CPUs are, apparently, only sold to laptop makers, unlike OEMs... (eBay but at ur own risk!).
3) When buying a new CPU, u need to check factors such as the number of pins (mobile cpu are much smaller), voltage, current, wattage and heat dissipation (very important, ur current heat sink was designed for ur current cpu).
But maybe things have changed now. In my case, I could only upgrade the RAM and the hard-drive to larger and faster versions, and the difference was quite significant difference. Faster booting and better internet experience.
May 03, 2008 | Sony VAIO VGN-220E/B Notebook
Gateway MX6442 Notebook Logo
51 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
