Question about Bose Companion 2 Series II Multimedia Speaker System (2-Piece)
Both speakers have just stopped working. I use with an ipod. I believe the ipod output cable (headphone type jack) was at one point plugged into the left speaker input. Could I have somehow blown the speakers? Just wondering if it's possible to fix or do I need to chuck out and buy new ones!
  • kategorman Nov 13, 2010
    Thanks for your response. I tried a new connector wire, but still nothing.
    Red & white ends in the Audio Output of right speaker and other end into the headphone socket of my ipod. This is how I've always used them and it used to work just fine.
    When the red and white Audio Output plugs are in, I used to get a feedback noise when I touched the other end of the wire - now there is nothing.
    Any other ideas?
  • kategorman Nov 15, 2010
    I have tried new leads and it is still not working. Any more ideas?
  • 13,433 Answers
Hey, test the speakers on another device a computer, stereo, radio etc. anything.
also you mentioned that you don't hear any "static" if you touch the plugs or if you plug it into a connector, that does sound like the speakers are not playing back any sound anymore, most likely the small circuit board inside the main speaker with the volume knob has blown.
It might be fixable, you would have to take it apart and see if its something obvious and then replace the blown component.
Posted on Nov 15, 2010
  • 2,973 Answers
Kate,
No, you could not have blown the speaker as the output current of the ipod is way too low to burn anything but itself first. Show the system to the Bose Service Center for the needful. Only if they tell you to chuck them that you should give up on then.
Posted on Nov 13, 2010
  • 12,061 Answers
Hi often this is the actual jack itself, the Ipod socket is a special socket and will ONLY work correctly with the corresponding Plug, please check this out.
Often these plugs break right at the place where they join the wire.
The ONLY real way to test is by substitution testing by swapping out components and seeing if it is actually working...
If the Ipod still drives your earphones then most likely it is OK.
It is unlikely that an Ipod has enough output power to damage anything.....
Looking for old Logitech S-100 driver
These are analog speakers and do not need a driver. First, make sure they're plugged into the speaker/headphone jack and not the microphone jack. Second, make sure the computer's sound output is enabled and set the headphone/speaker jack. Third, verify that the sound output is working by plugging in a headphone set or a different pair of speakers. If the computer sound checks out, the speaker cable is bad or the power supply is not working.
Nov 14, 2017 | Dell Computers & Internet
No sound from the Ipod jack side of the bose L1 system
There is no iPod jack side output (or headphone output) on any of the Bose L1® Systems.
If you are seeing an image that looks like an iPod, that is the iPod INPUT on the Bose Compact.
Here is more information about the Bose L1® Compact
L1 Compact Bose L1 Encyclopedia FAQ Wiki (fixya has picked up the wrong image - but just click the link and it will take you there).
Oct 31, 2013 | Bose Wave music system large Remote...
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
My QC2 headphones work intermittently at best. I believe it is the connection. It would not work with my ipad or with United's in-flight system on my last flight. This has been happening for some time.
Try plugging your headphones into other sources, like a computer's audio output or someone else's ipod/mp3 player.
If the problem persists, try moving the cable around near where it connects to the device (the jack) and see if you can get it to come on more often. Also try moving the cable near the headphones themselves, and at other points along the cable.
If you've had the headphones for a long time, it's more than possible that the cable is lose somewhere, and needs to be repaired.
Most common geeks will be able to fix this problem for you, so ask around if you know any.
May 04, 2011 | Bose Audio Players & Recorders
Don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Instructions
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
Feb 23, 2011 | Audio Players & Recorders
MY IPOD IS CONECTED TO A GRIFFIN AUDIO AUX CABLE IN MY CAR, IT WAS WORKING THRU BOTH SPEAKERS AT UNTIL YESTERDAY WHEN I REALIZED IT WAS ONLY COMING OUT OF ONE SPEAKER. WHEN I MOVE THE IPOD IN CERTAIN...
It's one of 3 things.  Either you have a bad aux cable, the cable isn't pushed in all the way into the ipod/stereo, or you have a bad connection on the ipod itself.
To test theory #3, plug in some headphones and wiggle the cord around... good?
To test theory #2, give a good push on the ipod.  sometimes it appears to be seated all the way but isn't.
To test theory #1, well.... you just need to buy a new cord and give it a go.
It would be very hard to believe that it's your vehicle causing the problem.  Ipods get a lot of use/abuse out of them with tension on the headphones.  This can cause internal loose headphone connections on the ipod itself.  Hopefully it's just not seated properly or your cord gave out on you.  Ipods aren't cheap.
Good Luck
Jun 10, 2009 | Kicker (ZX350.4) Car Audio Amplifier
Speakers work with ipod not with laptop
ok you need to plug the speakers into the green jack it is the speaker output jack
Apr 13, 2009 | Creative Labs Inspire T3030 Computer...
First thing, you have plugged in to the wrong point, plug in the speaker to the headphone slot(mostly light green in color).
MIC point is specifically for MIC not speakers.
The point which works for your headphones would work perfectly for speakers.
Mar 15, 2009 | Logitech X-240 Computer Speakers
NO SOUND
the make and model of your computer dont matter to what speakers you hook up. i can take those speakers and plug them into my ipod, my computer, even my psp and will work.
i would first check ALL wiring and make sure is all conected corectly.
try plugging them into your ipod/mp3 and see if you hear sound? if not, its the speakers. If yes lets move on.
Plug them into your audio jack on your computer (THE BACK, Green audio Jack) usually your front audio jack if you have one is set to head phones and your rear audio jack is set to speakers.
Plug them in.
Go to Start, Control Panel, Sound.
Now make sure your speakers are conected and it notices it.
Me i have 3 Input devices that show up.
1) Speakers
2) Headphones or Audio 2nd Output
3) Digital Output
If you plug them into the back they will most likely but under #1.
Click Option #1 or the one that is labeled speakers and says "plugged in"
Towards the bottom select, Set As Default.
Apply Changes, Ok, and exit.
Now try listening to something on your computer.
If this still doesnt work, let me know.
Thanks
Feb 15, 2009 | Boston Acoustics BA735 Computer Speakers
Bose Companion 2 Series II Multimedia Speaker System (2-Piece) Logo
129 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
