Question about Powerware 9120 UPS System
Powering up I need to reboot the ups after power failing
    Genius:
  • 1,027 Answers
Either you are not plugged into the backed-up outlets on the UPS (many brands have both on them), or the battery pack inside is dead.
Posted on Jun 19, 2008
CODE F9-88
F9-88 is a printer board communication error, either printer board has failed or the memory chip is no longer working. try unplugging printer cable and rebooting machine, or unplugging machine for 10 seconds and powering up again to reset the code.
Mar 22, 2014 | Sharp AR-M317 Black and White Copier
Reboots when plugged in
Please define reboot. Do you mean it keeps powering on and off displaying the Garmin logo or does a window pop up saying it is powering down in 30 seconds? Did this happen after you tried to update the firmware or map?
Mar 27, 2013 | Garmin nuvi 1450 GPS Receiver
When I press "Feature 981"
The inactive feature response means that the phone system and the voicemail are not communicating with each other. I would first check that the voicemail is powered on. If it does have power, I would reboot it by unplugging it for a minute and then plugging it back in(startup can take 15 minutes).StarTalk, Flash, and NAM are some of the names of the voicemail units for small to medium size Norstar phone systems. Occasionally, both the phone system and voicemail need to be rebooted to allow the two to sync up and "see" each other. Occasionally the Norstar voicemails go bad where they will not power up or after powering up they cannot complete the boot up process or after powering on and booting up they will not answer when called. If your unit will not work after trying to reboot a few times, I would recommend you consider having the unit repaired before replacing it. If you need advice on where to send for repair, send a comment and I will help.
Feb 23, 2011 | NorStar M7310 Corded Phone
When trying to connect the headset to my Blackberry Curve it wont connect
If you are getting a connection failed message, I would suggest powering off the headset. Then remove the battery from your cellphone while it is powered on, leave it out for 10 seconds, put it back in and reboot the phone. Power the device back up and put it into pair mode if necessary, then re-search in your bluetooth menu and select the device.
Rylan
Dec 15, 2010 | Jabra Bluetooth Headset - BT2070
Hughes sd-dvr-80 rebooting randomly now stays on powering up when
This is common with drive problems.
Could also be a power supply getting hot.
Apr 12, 2010 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Mobo does not power up Dead cpu dead mobo?
A dead CPU will not hinder a board from powering up. The board is unlikely to POST. However, you should heard attempts at powering up and immediate shutdown. Or, you will see the PSU comes on but system not boot.
No mobo, but, CPU.
If no failed attempts at boot, no indicator lights, then you have either a failed power supply or DEAD motherboard.
Good luck
Sep 27, 2009 | Fujitsu Siemens Computers & Internet
Reboot my hp laptop
Hold and press the power button down ( and dont let go ) for at least 10 seconds or untill laptop shuts down and you can reboot by powering it back up by pressing power again. If it still shows access denied after you rebooted then more than likely you need a password.
Jan 02, 2009 | HP Pavilion DV6405US Laptop
Continuous reboot problem
Most likely, if your unit is not powering up to the TiVo Central screen, you have a hard drive problem. You might consider a replacement TiVo hard drive.
Jul 30, 2008 | Sony SVR-3000 TiVo
When powering up my computer, I get a failure. Primary hard drive 1 not found Strike the F1 to continue F2 to run the set up utility. I think the power supply fan is not working. What do I do?
your system can not detect your primary hard disk which host the operating systems,so you check the data cable to the hard drive and the power supply to the hard drive for supply
Jul 19, 2008 | Computers & Internet
Powerware 9120 UPS System Logo
35 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
