Question about Samsung LA40A450 40 in. LCD TV
When i try to turn the tv on the little red light on front of the tv turns on and the tv makes a sound but before even showing any image the tv turns off itself and it keeps turning on and off on its own.
  • 608 Answers
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
My little sister's RCA TruFlat 27" TV won't turn on. I don't know it's model number. I have it connected to cable and it works, and I know the wall plug works. The little red light that I press to turn on...
She changed the Frequencies per second (in the Americas it has to be 60 hertz, In Europe, Asia, and elsewhere it has to be 50 hertz). Changing that will cause the tv to self destruct.
Oct 20, 2013 | Televison & Video
Cant get tv to turn on
Try leaving it out of the power overnight. Also, check all the cable connections.
Apr 05, 2008 | Ultra LCD30-500 Television
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
When I turn on my television, the picture is bright white and it is hard to make out any figures on the screen for a few seconds, then the TV shuts off itself, the little red light will go off and it will...
HI, thank you for visit fixya.
Do you have two possibles solutions:
1.--Vertical IC and capacitors need be replace.
2..-- Convergence IC's is defective, need be replace.
Disconnect convergence plugs ( wires go to yoke) and turn the tv, see if any changes happenings.
Any question, I will be here, Thank you
Nov 11, 2009 | Toshiba 57H82 57" Rear Projection...
I initially turned on ps3 system on tv. image
Turn off the system, Then when its in standby mode when the red light is on, press and hold the button to turn it on, Wait untill you hear 3 beeps then let go if the system turns off try it again its a master reset then just restore factory settings
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
My 32in sdtv red power light,no pic no sound
hi there, this may seem like a sstandard problem, but differs from mfg. to mfg. in the sony tv's it is usually an open cap in the stand-by power supply, since you werent specific in your problem, there can be many solutions even for a single series or group of tv's even within the same mfg. give me specifics and i can answer more precise. hope this helps even a little.
Jun 12, 2008 | Televison & Video
Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Jan 05, 2008 | Sony Grand WEGA KF-50WE620 Television
Sony KP-53HS10
I've had my T.V for about 5 years, and the other day the screen just died and I have no audio, but the when I plug it in the red light in the front flashes, have any idea on what to do.
Nov 21, 2007 | Sony KP-53HS10 TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Mar 21, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Samsung LA40A450 40 in. LCD TV Logo
132 people viewed this question
Henry  Thomas
Henry Thomas
