Question about Porter Cable 6,500 Watt Contractor Portable Generator #H650IS W
This is for the Porter Cable H650IS-W-1 Contractor Generator. It has an idle/RPM control solenoid that adjusts to the load on the generator. I can see that the solenoid works because 9VDC applied to it activates it. The stop control switch seemed to test out OK with an ohmeter, and the wires leading to the solenoid are ok. So I think the problem is in the power being provided to the solenoid by the generator/alternator. Where can I find out the correct voltage and/or how to troubleshoot further?
    President:
  • Porter Cable Master
  • 1,388 Answers
I do not think that your generator has a voltage regulator. The solenoid is for idle only when there is no demand (power being used). You can verify this by examing the governor spring /tension adjuster on the engine. Idle control switch on panel and the assembly board control the solenoid. When the assembly board fails generally the generator will function the same however there will be no idle. I have checked with Dewalt and parts are available however expensive. If idle is the only problem you may consider ignoring issue. If there is another problem with gen. please email.
Posted on Nov 13, 2010
  • 2 more comments
  • gmilo2 Nov 13, 2010
    Thanks, this generator was made in 2004 and does not have the GS-0663 ASSY BOARD CIRCUIT I as I see in the diagrams for this model out on the web now. There is a red wire coming out of the end of the alternator that connects right up to the 4 pin rocker switch/idle control stop switch, a wire that goes to ground, and then the other two pins are the two wires that go directly to the solenoid. I have yet to check the voltage at the red wire but I had checked it at the wires coming out of the switch before (assuming my testing on the switch was correct, I'd expect the measurement to be the same/low..)
    Doesn't that solenoid adjust the rpm to the load on the generator so that it isn't revved up any more than it has to? The issue I was having with letting it rev where it wants - is the voltage output was up over 150 I think. Plus it is very noisy.
  • John Trevino Nov 13, 2010
    The soleniod is for idle only. Try easy test. start generator engine and hold the throttle linkage or at carb so that you can manually govern engine speed. Hold the engine speed low and gradually open throttle, as you speed up engine you should feel the governor push against you (it should push very hard at high speed). If you do not feel this then could be problem with internal engine governor (or could be hanging up on solenoid). If you feel governor push against you then let go of throttle and adjust governor spring /adjusting tension screw or tab to correct rpm. What is correct rpm? Adjust governor spring until voltage reaches 115v or if your meter has rpm setting set to 3600 or if meter has hz setting set to 60 cycles. Do not turn on idle control during test.
  • gmilo2 Nov 27, 2010
    Thanks, I think the governor does push back but I'll check it. What should a tachometer cost me and where's the best place to get an inexpensive one?
  • John Trevino Nov 27, 2010
    I would not use tach. Get a digital meter that shows/measures Htz. That way you could adjust governor by setting governor at 60hz which converts to 3600 rpm. If gen is working correctly, at 60 hz you should produce aprox 115v ~ 120v. Good holiday
Throttle on generator question
The idle control switch allows the generator to go into idle when there is no demand form the appliances connected. This saves gas and increases the life of the generator. Damage can occur for some appliances like a refrigerator/freezer because the voltage and frequency are not prepared for the load resulting in a low voltage bad startup that will damage the appliance. Suggest that you leave the idle control switch off while any motor/electronic devices are connected.
The throttle control is likely a choke function for starting. These generators are designed for only one running speed to produce the necessary 60 cycles per second and voltage.
The following link is to a Canadian web site that later in the detail report describes the concern of idle control. In addition it provides good insight to the operation and use of portable generators
Hope this helps?
Understanding Portable Generators
The user manual see pages:
http://www.mikestools.com/download/Porter-Cable-Manuals/Porter-Cable-CTE300.pdf
May 06, 2017 | Porter Cable Portable Generator BSV750
I have a PC 6500 watts generator. The 120 volt receptacle is already occupied. I have an appliance120volt/30 amps that has a 10/3 cord and is furnished with a standard 3 pin twist plug. How can I used...
How many amps is the 120/240 volt circuit? I can tell you how to split it into two 120 volt circuits. A twist loc cord end, a piece of four conductor cord, two electric boxes, two receptacles would be needed.
How many amps?
Nov 12, 2017 | Porter Cable 6,500 Watt Contractor...
My generator runs but doesnt put out to the electrical outlets
You may have to check the wiring, With the engine off check the following: they may be a loose wire, the brushes on the generator may be too worn. Check for continuity from the outlet all the way to the generator.
Jun 06, 2010 | Porter Cable 6,500 Watt Contractor...
Not generating power
check
avr / brushes if it has them
if not capacitor and diodes on the end of the armature
Nov 15, 2009 | Porter Cable 6,500 Watt Contractor...
Porter-Cable generator won't power anything; engine runs, low rpm
You have a simple problem and it has nothing to do with the octane, honda's love better gas, thats all I use in all my equipment and even my 4000 psi pressure washer runs better and cooler with higher more efficient octane, Your problem is in the carb, clean and service it, make sure the air breather is clean (soap and water only if it is a foam unit and do not spray it with any oil) then check for water in the gas by draining the tank into a large clear glass container 1/2 gal at a time. and after all this is done and needs to be done anyway, change the spark plug run the unit and make sure the throttle up solenoid is adjusted properly or even working if this unit is equipped with one. good luck
Dec 22, 2008 | Porter Cable 10,000 Watt 20 Hp Portable...
Auto idle on a reddy rgh11000 ie will not idle down
This sounds like the idle control solenoid has become misadjusted. To check that this is the case, locate the throttle lever and follow it back towards the governor arm until you find the solenoid. Start the generator and switch on the idle control while watching the governor arm where it passes near the solenoid, if the arm snaps back and forth you probably have a bad adjustment. To readjust the solenoid loosen the jam nut on the core of the solenoid just enough that you can turn the core by the square bit on the end. Adjust the core 1/4 turn or so at a time until the governor arm stays in position when the idle control is on, then turn idle control off and make sure that the governor arm goes back to the full throttle position. You may have to fiddle with the adjustment a little until you find the right spot. Tighten the jam nut back down and you're good to go.
Carl
Dec 09, 2008 | Honda 6370C - Parallel Power Kit For ...
Porter Cable 6,500 Watt Contractor Portable Generator #H650IS W Logo
367 people viewed this question
Top Porter Cable Electrical Supplies Experts
John Trevino
Spud Howell
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
