Question about MSI Computers & Internet
What is the P2 button displayed on the top of the keyboard
  • 29 Answers
I tried on google and found that, It is for turning on/off the webcam. It has some issues with Windows 7 / Vista - when pressed, It launches Search
Posted on Nov 13, 2010
Portable AC model # LG 1010SNR. There is a message(P2) on the screen and it will stay on for more than a few seconds.
Easy easy!
Remove the batteries and put it again now your remote will function properly. Regarding P2, it means defective air senor. replace it.
Aug 17, 2012 | Heating & Cooling
Casio tk-6500 sub-total and cash amount keys don't work.
This is very unusal as far as programming goes, so I don't think you have lost them due to programming. The most common reason is water in the keyboard. To check, turn the key to PROGRAM mode, press 2 then subtotal. You should see P2 on the display. If it is still P1, you have a keyboard fault
Jun 17, 2011 | Casio Parts Cash Register PC Desktop
What is the P2 button on top on my laptop? above the keyboard , i am using cr420... please let me know abt its functions
I believe the P2 button can be used for whatever you want it for. It's programmable to be used as a shortcut to start software or things such as a webcam.
Mar 12, 2011 | MSI Computers & Internet
My samsung yp-p2 mp3 player locked up. how do i unlock it?
i had the same problem, it locked by itself, On the right side of the yp-p2 there are two bottons (see picture) one to put it on and the other on top("hold" word is on it)
I pushed the on botton until i saw the lock in the screen and then i swiped my finger up to the hold button and it started working again. _1836.jpg
Nov 03, 2010 | Samsung Yepp YP-P2 Digital Media Player
Hobart AM15T ML-130039 with p2 message, what does this code mean
p2 would mean your rinse thermistor is open or shorted. its located on top near the the right side, after the vac. brkr. part# is 328994. remove old, istall new . dont forget to vote,hope this helps , monomoy
Jan 29, 2010 | Hobart 29 in. AM15-1 Free-Standing...
The top drawer will not drain, it stays about half full of water. how can i get it to drain?
Go to Diagnostic Test mode by:
Hold the lock button and Ress the start/pause for 10 seconds
1- When you see the display show up, press Power button to have the HO display
2- Now press the tart/pause button once a time to scroll through the letter until you see P2.
3- If you miss it, keep going then it will go back in a circle loop.
4- Once at P2, press lock button one to turn it on.
5- When it is on your water will drain.
6- To turn it off, press lock button again.
7- To get out of the deiagnostic mode, press the power button.
Happily cheerful.
Aug 08, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Water will not drain out of top drawer
To determine if your pump work, before attempting access from the bottom of the top drawer: You can manually pump the water out by doing the following:
1- Press the Power button to turn off the display.
2- Press the Lock button and then the start button the same tim. Hold them until the display showing up.
3- If the display is not clear with all the characters, press power button to see clear the display.
4- The first display is bL, then Er,Ld..dd, FU, P1, P2...by pressing the Start button to go by the sequence until P2 (drain). If you miss, be patient to continue press and release the start button to get back to P2.
5 When is is at P2, press Lock button to tun on the drain. When you hear the water flowing to the drain, you could pull the top drain to see how the water is draining.
6- When the water is out, press the lock button again to stop it.
7-When it is done, press the Power button to get out of manual mode.
If this is working, then your water is there because you are running the bottom and your air gap allow back flow to the top drawer.
Please let me know if this is not the case.
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water won't drain
To determine if your pump works, before attempting access from the bottom of the top drawer or from the bottom of lower drawer: You can manually pump the water out by doing the following:
If this is working, then your water is there because you are running the bottom and your air gap allow back flow to the top drawer and or you are running the top and your air gap allows a back flow to the bottom drawer.
For the HV #1+ embroidery unit, using the plus hoop and embroider
Hi!
You can find the solution by following these steps-
Slide in embroidery card 21 and companion cassette. Touch Embroidery ON.
Touch FUNC to Program mode, The “E” inside the hoop will appear on the left end of the Program display window. If Plus Hoop programming is desired, touch the rotational arrow E one time and you will see the hoop in the Programdisplay window change into a Plus Hoop with a small arrow pointing to the top portion of the hoop, indicating position 1.
Toward the right side of the Program display window are
F1 S1 M1. F1 = Font style (1, 2 or 3), S1 = Size (1 or 2) and M1 = Menu (1, 2 or 3).
FONT: Select 1. Palace Script 2. Clarendon (block) 3. Kalligraphia
(Note: Programmed letters are always displayed in block)
SIZE: Select 1. Large 30mm 2. Small 12mm
MENU: Select 1. Upper case, 2. Lower case, or 3. Numbers and Symbols—check Program display for upper or lower case indication.
Note: You must select the Font, Size and Menu before selecting the letter desired.
Do rate the solution accordingly.
Thanks
Rylee
Mar 16, 2009 | Husqvarna Viking 1
Samsung p2 won't turn on
HEYY. okay. mine did the exact same thing but i took a toothpick and pressed the "reset" button on the back of the player. after i hit it once or twice, i tried turning it on and it worked.
Mar 18, 2008 | Samsung Yepp YP-P2 Digital Media Player
Computers & Internet Logo
141 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
