Question about Garmin nuvi 255W GPS Receiver
Unit shows that No detail maps found that support routing.
  • Garmin Master
  • 589 Answers
Make sure you have your Map selected in your settings..... go to Tools.... Settings.... Map.....on bottom of screen press Map Info.
Is there a check mark in City Navigator North American NT..........if not you must have one in there to chose that map or whatever map you are looking for
Posted on Nov 13, 2010
No detailed maps found that support routing
Please connect your Nuvi up to a PC and look to see if you have the map file "gmapprom.img" in the Garmin directory. The file should be around 1.5 to 2 GB in size. If the file is missing you will need to replace it. If you have registered your unit with Garmin, you may be able to log into your Garmin account and download the map file again. If you can't, then you will need to send the unit to have the map file restored by a service shop. More info on missing maps can be found here:
http://www.sharc.net/gps_lost_map.htm
Apr 15, 2013 | Garmin nuvi 205W GPS Receiver
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
My garmin nuvi 200 it say no detailed maps
my garmin 200 nuvi say no detailed maps found that support routing
May 21, 2010 | Garmin nuvi 200 Car GPS Receiver
Garmin nuvi 205 shows no detailed maps found that support routing
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
this resolves the problem for you.
Regards
Richard.
May 15, 2009 | Garmin nuvi 205 GPS Receiver
No detailed maps found to support routing
Have you tried updating the unit at Garmin's Website?
Let me know if you need help, I can get you the right web-link if needed.
Benjamin
Feb 28, 2009 | Garmin nuvi 255W GPS Receiver
Garmin nuvi says, "no detailed maps found to support routing."
I am very sorry to hear that you are having problems with the unit. You
may need to switch the unit on and press and hold the centre of the
screen until the message ?No detailed maps? message disappears.
If your map detail is missing, then the map information may have been
disabled. To check to see if the mapping has been disabled, follow the
steps below:
From the Where to? and View Map page, touch the Spanner icon, settings
(Tools).
Touch Map.
Touch Map Info.
The unit should display the name of the map that is loaded to the unit.
The box in front of the map name should have a tick in it. If it does
not, touch the box to place a tick in it.
Then please test by searching for an address.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
No detailed maps found. Help! Please
my email address is ada @ ebucksmail.com.
Can u please help with my sons nuvi 200 that shows no detailed mapsfound. Thanks A Million, Ada.
Jan 22, 2009 | Garmin nuvi 350 GPS Receiver
No detailed maps found that support routing.
You're unit is probably missing the gmapprom.img file (failed update maybe?).
Try contacting Garmin - if you've got registered maps they may send you another copy (although big file - 100+MB)
Jan 07, 2009 | Garmin StreetPilot c510 Deluxe GPS...
Route problem
If you don't have "Detailed Maps" for the area you are travelling in, it will not have adequate map detail to create routes that are not on major highways.
To remedy this, you will need to use another of GARMIN's products... I believe it's called Mapsource City Navigator, and will have to be purchased for the area you are concerned with. This PC software will then allow you to load additional Map Data onto an SD card, which will slip into the slot on the left side of the unit.
You can find out about it at their website www.garmin.com then look in Maps
Oct 01, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
81 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
