Question about HP Deskjet D4260 Printer
The red light by side of power switch is on constantly. What are the two red lights by side of the power switch?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 544 Answers
These light indicated ink cartridges problems.
Additional information at this web page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00877377&cc=us&lc=en&dlc=en&product=2510771&tmp_track_link=ot_search
Posted on Dec 18, 2010
Why does my red light next to on off switch flashing constantly
This typically means either you need to recharge or it is recharging. Does this change depending on whether it is plugged into the power or not.
May 23, 2014 | Acer Computers & Internet
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1980 - 1982 Honda Civic...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1980
1981
1982
STEREO WIRING COLOR CHART:
Constant Power: White/Blue
Switched Power: Yellow/Red
Ground: To Chassis Metal
Illumination: N/A
Dimmer: N/A
Antenna: Drivers Side Pillar
Left Front (+): Red/Green
Left Front (-): Brown
Right Front (+): Blue/Green
Right Front (-): Gray
Left Rear (+): Red/Yellow
Left Rear (-): Brown
Right Rear (+): Blue/Yellow
Right Rear (-): Gray/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1388
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 01, 2010 | Honda Civic Cars & Trucks
Ariete 1357 red light constant flashing
check if there is water , maty be the thermostat is broken, bring to service
Jul 07, 2012 | Ariete Coffee Makers & Espresso Machines
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
I am trying to replace a two wire light switch(both white) with a leviton photoelectric 3 wire motion activated light control(red, black and green). I am trying to determine which wire goes to which?
one of the white wires has power on it constantly....that wire connects to the black wire of the leviton.......the other white wire which has no power to it is going to whatever needs power so that wire connects to the red wire of the leviton....the green wire connects to the metal box where your mounting the leviton.
Feb 08, 2010 | Leviton Decora Light Dimmer Switch
Light and fan work but does not work with wall switch
This would mean that that constant power to the fan and light is not wired through the switch right, or not wired into the switch at all. Most ceiling fans that have a light kit will have a Black, White, Green, and Red wire that comes from the ceiling and hooks into the fan and light. If it was done correctly, then the Green wire would be ground, the White is your neutral which is hooked to the other White wire, the Black wire is usually power to the light kit which will also hook to another black wire, and the Red is to the fan. Sometimes the Red and Black are reversed. If any of these wires are wired wrong, that could possibly lead to a constant power to the fan and light kit.
Feb 02, 2010 | Hunter Dryers
Two Red lights blinking constantly. unable to
Epson -R 230 desktop printer. Two Red lights blinking constantly on the control panel (beside main switch). unable to print.
Oct 24, 2009 | Epson STYLUS R230 InkJet Photo Printer
Sony TV goes to standby - constant red light
The Power Supply has gone. It needs replacing.
Jan 04, 2009 | Televison & Video
HP Deskjet D4260 Printer Logo
61 people viewed this question
Seeker5211
Seeker5211
