Wil not agertate on wash cycle - Washing Machines
  • 3,051 Answers
Hello there
I will explain this in 2 seperate posts for you so be sure to read them fully ok
f your washer doesn't agitate, check these: Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Posted on Nov 13, 2010
  • Michael Thomas
    Michael Thomas Nov 13, 2010
    Drive pulleys
    The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
    Transmission
    The transmission could have either of these problems:
    Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
    The transmission may have a worn or broken gear, or some other internal problem.
    If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
    Agitator
    The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Why my washing machine will start the wash cycle but will not spin or rinse?
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
Aug 17, 2014 | Fisher and Paykel Washing Machines
I'm looking for a service manual for Miele WS 5425 washing machine, any ideas where i can obtain one?
i have a Miele ws 5425. it wil not open even though though the cycle has finished. It still full of water. The red fault light flashes on the drain symbol.
Jun 17, 2010 | Miele Washing Machines
Lights on, no wash cycle starts
Check that the machine is heating the water. if it is not, then it is likely the heating element at fault, or one of the two thermostat switches that control it.
It will not continue if it is waiting for the water to heat.
Try it with just a rinse and spin. If it rotates on this, then it will be a heater fault, as no heating is selected in this cycle.
If it will not spin on that cycle, troubleshoot the drive and motor. Check belt condition and motor brushes for wear.
Feb 16, 2010 | Indesit WA 115 Front Load Washer
Hotpoint washing machine wont spin
this wil be because there could hav got stuck some dust like things
make a clean to tat
also check if the baring is good
Mar 07, 2009 | Hotpoint Washing Machines
Indesit wil 103 door won't open...
Welcome to Fixya.
Try holding the Start/cancel button in for at least 2 seconds.
If there is another lamp flashing at the same time as the door lamp, then you will have to call an engineer.
Dec 18, 2008 | Indesit W 123 Front Load Washer
Indesit washeing machine
Karen, that was nice.........
May 31, 2008 | Indesit W 123 Front Load Washer
Machine has power but not moving through cycle
Hi there. I have a candy cwb110 and the bearing on the motor went. I replaced this put it all back together and now when you set it to wash it wil only spin for 30secs and then it will end it's cycle and do no more!? wil drain it's water fine on that mode just wont run it's wash cycle. motor sounds healthy when it is spining.
Is there a reset on the computer side of things or something i may have done wrong?
Cheers
Wyn
Mar 10, 2008 | Candy AQ130 Front Load Washer
Door on washer will not open
Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
312 people viewed this question
Top Washing Machines Experts
