Question about Porter Cable C2002 150 Psi 6 Gal Compressor
The drain valve does not close all the way. When compressor is on air constantly leaks out.
  • 3 Answers
I have the same problem and haedly use this thing! no way should this one year old unit leak like it does, Either defective or a scam going on here.
Posted on Dec 11, 2011
  • 134 Answers
Probably just need to be replaced or you can try to spray some wd-40 on it see if it is not just hanging up.
Posted on Nov 13, 2010
  • john Dec 11, 2011
    wrong, wd40 isn't going to stop leaky pressure valves. I suspect the company is taking a lot of American by surprise and such engineering defects be they deliberate or overlooked must be exposed to the community.for quality assurance purposes.
Husky 26 gallon air compressor doesnot get any higher than 25 psi and keeps running
If the compressor isn't shutting off then there is a leak somewhere. Have you closed the drain valve under the tank? if the valve is closed, remove any attachments from the air hose and check the hose from end to end for leaks. Also check that the safety release valve is closed. It is usually brass and has a small split ring on top. If no leak can be found in the above locations then it is internal to the compressor, the piston rings or valves are not sealing.
Dec 15, 2013 | Air Tools & Compressors
Drain valve leaks air -- no pressure in tank
Replace drain valve, its a 5.99$ at your local home depot, or hardware store. Cheers
Jul 26, 2013 | Porter Cable C2002 150 Psi 6 Gal...
Husky air compressor
Josh:
Your compressor shouldn't run more than ten to fifteen minutes before shutting off. The pressure should be posted on the machine somewhere ( a decal usually says xxxpsi). You evidently have an air leak somewhere. On the bottom of the air tank there is a valve for draining the tank of air and any moisture. Make sure to close that valve by hand only (Screw it in all the way by hand and remember, you are working upside down, so don't get confused as to which way to turn it). If the valve will not unscrew to drain the tank, you can use a pliers to loosen the valve to let the air out, but be sure you are turning it in the correct direction or you'll break the drain valve!! Now that you have the drain valve closed, turn the compressor on and watch the pressure gauge. When the pressure gauge reads the pressure on the decal, the machine should turn off. If the pressure gauge stops climbing before it reaches the specified pressure, you have an air leak somewhere. You can either feel for the leak at the air line connectors by hand or mix a dish soap and water solution the pour on the air line connectors to look for the leak. Keep the soap solution away from the motor!! When you find the leak, drain the tank using the drain valve at the bottom of the tank, disconnect the hose coupling that is leaking and wrap Teflon tape around the threaded portion of the male end of the fitting (3 wraps should do it) and reconnect the coupling ( tighten it well). Close the drain valve and start the compressor again. and check all fittings for leaks again.
Jun 04, 2013 | Air Tools & Compressors
Air leaking from air pressure controller when compressor knocks off
It is normal for there to be a hiss from the pressure switch for a second when the unit stops, this allow any pressure in the line to be dissipated so next time the unit starts it doesn't have a pressure to start against. If it is constantly leaking it will be a problem with the non return valve. It is normally a brass fitting on the tank that the compressor pipe goes to. It may just have a bit of debris not allowing it to close properly, You need to drain down all air and remove the cap on the brass fitting, there should be a rubber shuttle with a spring behind, if it is hard an cracked it will need replacing or it may just need a clean.
Hope this helps,
James
Feb 05, 2011 | Clarke Power Products Inc AC2001 2HP 4...
It will not build pressure in the tank.
There is a pressure relief valve somewhere around the motor. Make sure it is closed. If the relief valve isnt leaking air while the compressor is running you probably have a loose hose on the line going from the compressor to the guages or the overpressure valve. Something under the motor/compressor cover.
Jun 30, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Craftsman Air compressor while trying to fill tan...
the drain is closed in the out position
May 20, 2010 | Garden
Dewalt 4 gal air compressor will not build pressure in take.
The bleed valve is an unloader of sorts that allows the compressor to start with-out a load. It closes when the pressure in the airline reaches about 20-25lbs with good volume. If air volume is not sufficient, the valve will not close. To solve the problem lets do a few tests. A long cord will reduce power and reduce air volume. Try powering the compressor with-out extension cord. If bleed valve closes when you do not use a cord, the compressor is not getting enough voltage, use shorter cord of the 12 gauge quality and more hose to reach work. If valve still does not close, check for air leaks on all fittings including around pressure switch and drain valve with soapy water. Repair as necessary and retest. If no leaks were found, temporarily plug bleed valve port with screw/bolt and run compressor till set pressure cut-off while counting minuites/seconds. The compressor should fill and shut off within three minutes or so. If it takes an unusually long time to fill, then the reed valves /valve plate is worn and leaking pressure back into cylinger. Leaking valves will usually result in very hot discharge airline/air. Reinstall the bleed valve after test. Parts and partslist are available at www.toolpartsdirect.com . Good luck on the repair and email if you have other questions.
May 06, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
Unloader valve leaks on my compressor leaks air constant and I think that it must need replacing, does it? just old or what?
THE VALVE COULD BE BAD BUT IT MORE LIKELY THE CHECK VALVE IN THE TANK ISNT CLOSING. DRAIN PRESSURE AND REMOVE CHECK VALVE FROM THE TANK AND INSPECT.
Mar 08, 2009 | Campbell Hausfeld Single Stage Air...
Dewalt compressor not filling with air drained tank closed valve
Some dewalt air compressors with single cylinder are known to develop trouble with reed valves and /or failed gaskets in head. Parts lists and parts are available at WWW.toolpartsdirect.com Simple test is to remove air filter and check for suction at intake. Bad reeds will tend to blow air out intake as pressure increases. Failed gaskets in head will cause very high temp at discharge hose. Parts are not too expensive. Enjoy
Dec 05, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Porter Cable C2002 150 Psi 6 Gal Compressor Logo
89 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
